Syncros 29er Wheelset?!?!- Mtbr.com
Results 1 to 6 of 6
    May 2005
    I sent an email to Syncros about the possibility of making their DS28 26" rim in a 29er version and this is the response i got...................
    Marc: We are currently testing a 29" rim based on the DS28. Release date is probably Sea Otter (hopefully). The wheel set will follow by Interbike. It will be the DS28 29" with FL Hubs. Also it will be available in white.
    Marc, we also make a wide flat bar for 29" called the Big Fixed Bar. 690mm width with a 10 degree bend. Very trick for the big wheels.
    Regards,
    Marshall
    i was super stoked that he responded so fast and even more excited to hear they are stepping up to the 29er plate. now we just need some 'white wall' tire to match. hehehe
    anyway, just thought you guys might be interested if you hadn't already heard. later
    Reputation: shiggy's Avatar
    Dec 1998
    Cool. Marshal was asking me about 29er stuff at interbike. Good to see them working on it.
    mtbtires.com
    Back in the Saddle Again!
    Thanks for the info - figures, I just ordered a DT Swiss/Hope wheelset...
    *Hotter than Hell*
    Aug 2005
    Syncros
    Regards,
    Marshall
    This bar lowers your front end by a minimum of 25mm with no
    change in steering leverage and control, and maintains a natural
    wrist and hand position
    http://www.syncros.com/bars.htm
    The DS-28 rim looks like the Halo Freedom Disc's profile.
    Reputation: Ottoreni's Avatar
    Any Sightings?
    Well?
    Has anybody seen these at Sea Otter?
    You cannot go against nature, because when you do, its part of nature too.
    rider
    Jan 2005
    Nice, but will they be available in 36h for 29er's?
