Ritchey Ultra with mechanical disc brakes?- Mtbr.com
Results 1 to 8 of 8
    Hey all,
    Iím very interested in getting a Ritchey Ultra frame and build it up as my mountainbike / bikepacking bike.
    I would like to use mechanical brakes (yes, I knowÖ but thatís my personal preference) but the way the brake hose is routed on this frame does not work for mechanicals brakes as it goes up the seat stay.
    I see that there are cable mounts for the dropper post (that I donít use) on the down tube, so I assume I could make it work.
    Iím also not sure about the brake mount inside the rear triangle and wonder if there is enough space for a mechanical brake (BB7, Tektro) using a 180mm or 160mm disc?
    So, has anyone used mechanicals on an Ultra and how did you make it work?
    Reputation: NZPeterG's Avatar
    Quote Originally Posted by annoying crack View Post
    Hey all,
    Hi
    So I do have a Ritchey Ultra myself and I have get my rear disc brake setup with a 180mm disc rotor.
    So I have been using my Ritchey with XT 8000 brakes
    But
    I'm about to change them out for my Paul Components Klamper cable brakes.
    Them room for the Klamper brakes, I'm planning to run the cable along the chainstay and up the Dropper Post cable mounts.
    Why am I doing this?
    Because I'm a Bikepacker and a fulltime Service Manager/Mechanic in a LBS in New Zealand, when I'm on holiday bleeding brakes or repairing them is not my idea of fun.
    Before someone asks when was the last time a hydraulic it was yesterday.
    Loving my Ritchey Ultra
    Sent from my SM-T590 using Tapatalk
    Alive so go for a ride
    Hi,
    Thanks for the reply.
    Iíve seen your bike in the other thread. Sort of my inspiration to go that way.
    Can you confirm the caliper has room to fit in the rear triangle? (was not clear if you have already tried it or not)
    I know that sometimes, there is no room to tighten the cable clamp bolt, or the arm does not go.
    Hi,
    Well here you go
    Shimano XT 8000 brake
    Sent from my SM-G960F using Tapatalk
    It looks a good fit?
    And missing riding in the summer sun.
    Because new brakes need for my upcoming Bikepacking adventure.
    New brakes fit a 100%
    Time to enjoy riding again
    Quote Originally Posted by NZPeterG View Post
    Thank you.
    Just what I needed to see.
    Thank you.
    Your welcome
  1. Big Bear Lake Ultra & Ultra Lite (WV) - August 1, 2015
    By BigBearLake - WV in forum Endurance XC Racing
    Last Post: 07-09-2015, 04:48 AM
  2. Replies: 7
    Last Post: 09-03-2013, 06:34 PM
  3. Replies: 8
    Last Post: 04-03-2011, 04:07 AM
  4. Are mechanical disc brakes wrth the cost over v-brakes?
    By Strong Steve in forum Brake Time
    Last Post: 05-05-2008, 06:43 PM
  5. Hayes Mechanical Vs. Avid Mechanical
    By Turt99 in forum Brake Time
    Last Post: 10-27-2005, 08:11 PM
Members who have read this thread: 4
