Ritchey brake lever setup- Mtbr.com
Results 1 to 13 of 13
    SSasquatch
    Reputation: galleywench's Avatar
    Did anyone notice the brake lever setup on Tom Ritchey's bike in the last Dirt Rag issue (Riding Rwanda)? They appear to be out on the end of the bar ends. I often think while I am riding that the only reason I ever go to the main handle bars is because I need to brake. It seems that having the brake levers out on the bar ends would make sense since my hands spend about 90% of my time there.
    Anyone ever experiment with a similar setup? Pros? Cons?
    Reputation: logbiter's Avatar
    Quote Originally Posted by galleywench
    looks like some bullhorn bar brake levers, no? why not?!
    hmm, also looks like v-brakes (an' I don't spy a travel agent, but w/ TR who knows what kinda of one off levers those might be... the levers have an interesting flare to 'em.)
    I also spy an allsop/jp morgan type of suspension stem on there actually probably a good alternative suspension for this kind of tour.
    Front tire
    Is his front tire on backwards? Ritchey's, not the other guy...
    Reputation: shiggy's Avatar
    Dec 1998
    No, it is not.
    mtbtires.com
    Dec 1998
    You sound like a candidate for Jones Hbars.
    Tom's levers look like aero bar levers. He have probably been riding something like this setup for years. Note the Softride stem.
    mtbtires.com
    Got Mojo?
    Reputation: BikeMojo's Avatar
    Jan 2005
    Great article. Look for the Rwandan SS MTB team in the future.
    Could one not set up a set of cross style interupter brake levers like that?
    aLaN AT BikeMojo DOT com
    Sofa King We Todd Did
    Reputation: SpinWheelz's Avatar
    I've never seen aero bar levers where the cable comes out of the end. The ones I use run parallel to the blade. Presume that he's jacked them up in some custom fashion?
    I wish Ritchey made real frames again and not that silly break away s**t.
    Bet he could make a real cool ss ...always liked his stuff.
    Raw power's got a healing hand
    Raw power can destroy a man
    Raw power is so more than soul
    Got a son called rock and roll
    98 % of all teens do drugs or have tried drugs if you are in the 98 % range copy and paste this in to your Signature
    SSasquatch
    Quote Originally Posted by shiggy
    I've considered it, but not sure if I am ready to experiment with such an expensive item. Right now I am running cane creek bar ends (the rubbery ones) and I really like the position (parallel to the bike) and I'm not sure I could get used to the positions the Hbars present.
    Dec 1998
    Quote Originally Posted by SpinWheelz
    All you have to do is run the cable through the lever in the other direction.
    mtbtires.com
    That's not making a ton of sense to me, mate. Threading the cable the normal way would, as expected, pull the cable. Threading it the other way would effectively 'push' the cable, no?
    Dec 1998
    No. It pushes the housing. Same way the 'cross bar top levers work.
    mtbtires.com
    Glad to Be Alive
    man I need a woody!!!
