Ritchey Bottom Bracket Fix- Mtbr.com
Results 1 to 7 of 7
    I donít like the fact that my derailleur and brake cables are digging into my bottom bracket by going through those cable noodles. Eventually, I am going to wear through the bottom bracket considering how much I ride. Is there a fix for this?
    Reputation: Fillet-brazed's Avatar
    Quote Originally Posted by ibike4fun
    I reckon in the year 3176 your BB shell will be toast.
    Quote Originally Posted by Fillet-brazed
    It will take me that long to get where I need to go and then I will not be able to return because my bottom bracket will be toast.
    resident crackpot
    Reputation: loonyOne's Avatar
    Maybe a coupla years sooner...hehehe. Keep those little guides clean and oiled/greased and you'll be OK. OR...you can strip the vinyl coating from a length (per) of brake cable housing. Thread it through during a cable change and keep it in place with some Loctite 430. I have done stuff like this on a coupla builds with great results...you can also add some heat shrink to the outer portion to keep the gunk out.
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    Even if it does wear though...shouldn't hurt anything I don't think.
    Nothing better than a well used bike!
    -eric-
    http://www.rumpfy.com
    Dec 2004
    Good job! I would worry more about frayed cables.
    But hey, keep those cables lubed and you should be fine. I have the same set up on one of my bikes.
    Reputation: shiggy's Avatar
    Dec 1998
    Convert it to fixed gear. No need for any of those cables.
    If there is room, use 1-2" pieces of housing liner at the BB.
    mtbtires.com
