Ritchey 44mm Press Fit Headset for Reign- Mtbr.com
Results 1 to 2 of 2
    ...is still one gear
    Reputation: onetothepowerofn's Avatar
    Jan 2005
    I purchased an 07 reign frame without headset recently. I know a lot of you use the Orbit Z from FSA. I can get a great deal on Ritchey products and was wondering whether the Ritchey WCS or Pro Press fit headsets would fit? Apparently these are only available in Europe - donīt ask me why. Specs are as follows (taken from the Ritcheylogic.com website):
    WCS Press Fit
    : Full complement angular contact cartridge bearings
    : Compatible with Campy style headtubes
    Stack Height : 12.9/18/25mm
    Cup Material : Alloy
    Headtube ID/depth : 44mm/9mm
    Bearings : Sealed Cartridge Stainless
    Weight : 110g (10mm)
    Availability = Europe Only
    Firstly, is there anyone out there who is using one of these successfully? If not, I believe the 44 ID is the critical dimension (not sure about the depth) - is there anything else I should check? Should it fit? Thanks in advance.
    it might work but i would be a little unsure about that because it doesnt press in very far. Giant makes adapters that you can use to put a normal headset in their head tubes, but i would get the FSA or a giant integraded
