DT Swiss Onyx/5.1D vs Syncros All Mountain- Mtbr.com
Results 1 to 2 of 2
    This is for a Turner 5 Spot build. It's been so long since I got a bike I'm having problems figuring out what to get. Intended use would be for aggressive XC and all mountain type (more XC then downhill). I'm 6'2" 175lbs. The white rim syncros look pretty sweet but I want the best set when it comes down to it. Any comments or experience with these wheels?
    DT Swiss Wheelset:
    Hub: Onyx
    Rim: DT Swiss 5.1d
    Spokes: DT Swiss
    vs.
    Syncros
    All Mountain Wheelset
    Intended use: Lightweight Freeride / All Mountain
    / syncros white DS 28 sleeved and eyeleted rims with Bead Lock Systemô
    / syncros FL hubs
    / syncros signature QRís
    / DT Swiss Comp 1.8mm black spokes
    / DT Swiss spoke nipples
    / syncros Snap On rim strips
    / 32 hole, 3x build
    / 100% hand-built
    / Lightweight and bombproof
    white
    check out the DT Swiss 340 Trail
    See the DT Swiss Classic wheel line here:
    http://www.dtswiss-us.com/340-trail.htm
    This set has the same EX5.1 rims, Competition 2.0/1.8/2.0mm spokes, but with the 340 ratchet drive hubs. 100% hand made. Plus, the rear can be had with a 10mm thru-bolt (bolt on), which is a great way to stiffen up any frame.
