difference in Ritchey stems- Mtbr.com
Results 1 to 12 of 12
    Reputation: pop_martian's Avatar
    Anyone know the difference between a ritchey WCS 4axis stem and a WCS stem (not the 4axis) like this one at nasbar?http://www.nashbar.com/profile.cfm?c...%20ATB%20Stems
    Reputation: Some Guy's Avatar
    Mar 2005
    The 4axis has a once pleice clamp, with the four bolts next to each other rather than at the edges. I believe they did it to make the clamp stiffer, and the 4axis is definately heavier. I'm not sure the plain WCS comes in 31.8 either.
    www.yourtrails.net/weights/ - Kick ass weights listing
    racing.thylacinecycles.com - Racing silliness
    DGB
    DGB is offline
    The 4-axis is the new version of the WCS stem in the link. As Some Guy said, it has athe 4 bolts close together rather than spread out. This was created for lightweight carbon bars to reduce the stress.
    It's not heavier than the WCS in the link - they are both WCS series stems and weigh the same, but the 4-axis is the newer version.
    Both old and new versions are available in 25.4 and 31.8.
    DGB
    DGB is offline
    The 4-axis is the new version of the WCS stem in the link. As Some Guy said, it has the 4 bolts close together rather than spread out. This was created for lightweight carbon bars to reduce the stress.
    Hope this helps
    DGB
    DGB is offline
    Hope this helps
    DGB
    DGB is offline
    Hope this helps
    DGB
    DGB is offline
    Hope this helps
    DGB
    DGB is offline
    The 4-axis is the newer version of the WCS stem in the link. As Some Guy said, it has the 4 bolts close together rather than spread out. This was created for lightweight carbon bars to reduce the stress.
    It's not heavier than the WCS in the link - they are both WCS series stems and the new 4-axis weighs about 15g less.
    Hope this helps.
    DGB
    DGB is offline
    Hope this helps.
    DGB
    DGB is offline
    Hope this helps.
    DGB
    DGB is offline
    Bonking ... not feelin' well
    Oops. Had problems posting the above reply but didn't expect it to be posted so many times!!
    Mar 2005
    I think you'll find it is a bit heavier. The 4axis faceplate contains more material and is therefor heavier.
    Judging by http://weightweenies.starbike.com/li...php?type=stems , the difference is about 10gr (31.8 WCS vs 4axis in same length).
