Custom Built syncros wheel...this looks wrong??- Mtbr.com
Results 1 to 3 of 3
    Calm like a Bomb
    Reputation: stunzeed's Avatar
    So I had a set of syncros rims built up with hope pro 2 hubs...when I mounted the front wheel on its not in the center completly but shifted over? What could cause this? I removed the front brake caliper to make sure that was causing it. The hub is 20mm and has a thru axle
    A builder could have dished a wheel wrong but with this pic I can't tell anything. At the angle you took it also makes it look like the whole wheel is canted over which would be a hub/fork fit thing. I'd take the tire off and measure the rim to each fork lower to give us a better idea and maybe take a picture from straight on while the tire is off.
    it's....
    Reputation: Strafer's Avatar
    Tire doesn't look even, like left bead isn't seated correctly.
