Page 6 of 7 FirstFirst ... 234567 LastLast
Results 501 to 600 of 672
  1. #501
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Wife's new winter build...
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  2. #502
    Self Appointed Judge&Jury
    Oct 2000
    Sweet! Tell her congrats. Looking forward to some ride photos with it.
  3. #503
    the half breed devil
    Reputation: shekky's Avatar
    Oct 2011
    i checked and inflated tires of all three bikes. each has been sitting for a while since my injury and the singlespeed is seriously collecting dust. also, air pressure check on the hardtail's fork--all this time i've been running it a little too stiff. the dualie got a good wipe down and quick look-see since i'll be riding tomorrow.
  4. #504
    DFL
    Reputation: askibum02's Avatar
    Added two more tokens to my fork, and two volume reducers to my shock.
    I wouldn't **** you, you're my favorite turd.
  5. #505
    Reputation: BADDANDY's Avatar
    Feb 2012
    Fixed my slipping seatpost.
    2015 Giant Stance 2 - 1 X 10 11/42 30T
    2016 Diamondback Insight 2
  6. #506
    Oct 2011
    took a photo of the serial number on my bottom bracket shell just to have in case the unspeakable and unimaginable happens. i should have done this before i rode the bike out of the shop.
    bike theft in san francisco is something of a cottage industry:
    Attached Thumbnails Attached Thumbnails What did you do FOR your bike today??-img_3326.jpg
  7. #507
    Salute my bike for new year , absolutely nothing , eat and drink and film on pc
  8. #508
    Oct 2011
    Quote Originally Posted by Maurizio View Post
    maurizio, you're always good for a smile!
  9. #509
    DFL
    Took out one of the bottomless tokens I added to my fork yesterday, and lubed my chain.
  10. #510
    Jan 2015
    Dropped it off at the shop for F/R suspension service. Side note about how great my LBS is. The manager meet me 3 hours before they opened today so that I could drop it off on my way to the airport.
  11. #511
    Dec 2011
    Replaced my broken front derailleur mount on my Borealis Echo (my winter rig). Another reason to convert to 1x. The front der frequently gets packed with snow and ice and won't move without a firm tap from my foot. Enough of those firm taps (3 seasons) and you get a broken mount. Easy enough fix. Although the damn mount was $50. It seems like such a simple little aluminum thing - two bolts and a pivot - to cost $50. The same day I bought it I also bought a light switch for my living room that was 79 cents. Got me to wondering. Economies of scale I reckon.
  12. #512
    DFL
    New fender, Wolf Tooth 49tGC, new grips, and some new bling from Kustom Caps. All done in my garage in 20 degree temps. I really need to get my kerosene heater looked at.
  13. #513
    Magically Delicious
    Quote Originally Posted by askibum02 View Post
    Post a photo and we'll take a look at it.
  14. #514
    slow
    Reputation: sgltrak's Avatar
    Feb 2005
    Replaced a cracked faceplate on the gravel bike before it results in a cracked face for me.
  15. #515
    Feb 2012
    New bike rack.
    Did I mention it was connected to this?
    What did you do FOR your bike today??-e91afa59-f337-472b-a6a7-bfb6b6e7872b.jpg
  16. #516
    DFL
    Quote Originally Posted by Cleared2land View Post
    You would do that for me?! You da man!!!
  17. #517
    Magically Delicious
    Quote Originally Posted by BADDANDY View Post
    Very sweet.
    Have you posted anything about your Paseo in any other MTBR threads?
  18. #518
    Feb 2012
    Not yet, will pick it up Friday. Replaces my Sprinter van. There's only one RV thread in the Over 50 that I know of.
  19. #519
    Oct 2000
    Quote Originally Posted by sgltrak View Post
    Ahh.. did you know that Thomson had a recall on those face plates way back in the early 2000's. The bad ones have a machined groove on the inside that didn't sit flush to the bar. Just send the old one to them and they'll send a new revised one back, no charge. Happened to me way back.
  20. #520
    Oct 2000
    Sweet! Congrats.
  21. #521
    DFL
    Set my son’s bike up tubeless today. It went smoothly aside from the fact that I could get the bead to seat with my pump. And I couldn’t find a presta/schrader adapter to use my compressor. I ended up driving on icy roads to my LBS for a $1 adapter.
  22. #522
    Magically Delicious
    Just remove the valve and use a blow nozzle to seat the tire. Reinstall valve and pump up with pump.
    No need for a presta/schrader adapter.
  23. #523
    tire to rim ratio tester
    Reputation: richj8990's Avatar
    Apr 2017
    Quote Originally Posted by noose View Post
    Other than dumping oil all over the floor no. There were 3 settings on my Sweep; 160, 140 and 120mm. The travel adjust video on x-fusions site described the process perfectly. RL2 Fork Travel Adjust You can get a customer version of the damper removal tool much cheaper here: Bikeman X-Fusion Consumer RL2 Damper Removal and Installation Tool (threads onto damper shaft in place of footnut)
    I will say reducing to 140mm tightened up my steering and helps climbing.
    I'm still learning about this but can't you just put it on lockout when climbing?
    "A $1700 bike is not fit to be hucked from a curb"
    MTB B'Dos
  24. #524
    Apr 2017
    This was actually last week but I changed the rear shifter cable and it's so much nicer now. I kept messing with the derailleur thinking it was that when it was the right cable. I don't think a bad shifter cable is mentioned enough for beginners when it comes to shifting problems in the back. No front shifter cable problems yet probably because it's not used as much.
    MTB B'Dos
  25. #525
    Reputation: roughster's Avatar
    Dec 2017
    Relacing my back wheel with some decent spokes. Bought bike used and broke two spokes. 2's my limit before action must be taken!
    Just put a new seat and flats on my sons bike. Ordered a e10 dropper for him. He doesn't ride that much so figure start him off on something cheap and see if he likes it. I know he will but who knows...
  26. #526
    Jan 2009
    New bike rack.
    Nice. I like the Fiamma racks. I put some Fiamma arms on my Thule.
    EDIT: Or is that a Fiamma? It looks a little different, but I know they also have a lot of RV specific stuff too...
    Also this one:
    http://forums.mtbr.com/cars-bike-rac...nd-258287.html
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
  27. #527
    Feb 2012
    Quote Originally Posted by J_Westy View Post
    Or is that a Fiamma? It looks a little different, but I know they also have a lot of RV specific stuff too...Also this one:
    It looks like one to me too, but there's no manf/part/serial # on it. Maybe just made for Winnie.
    Thanks for the link.
  28. #528
    Oct 2011
    i rode it.
  29. #529
    Mudhorse
    Reputation: Grassington's Avatar
    Jun 2017
    Pulled loads of thorns out of the tyres. Most were little things that probably didn't make it all the way through the tyre, but three of them were sizeable and would have stuck through by a good 5 mm. No hisses upon removal - yay latex tubes!
    Rear brakes pads died from mud early into a ride yesterday, so I had to ride for 2 hours without touching the rear brake for fear of ploughing furrows in the rotor. Today revealed only one tiny gouge on the rotor, which I reckon was when the pad spreader spring chewed itself up. A light rub with a whetstone sorted the gouge out, and the rear brakes got new pads, caliper realignment, and a rotor truing.
    Graunched my outer chainring on concrete yesterday, so filed three teeth back into some sort of acceptable profile. I was shocked at how soft the alloy on a big XT (3X) chainring is. Also found out by chance I'd knacked the chain somehow* - noticed the end of an outer plate had been bent a little, and it probably wouldn't have been long before that broke on the trail. Dodged a bullet there.
    Before yesterday's ride I got around to implementing a Seth's Bike Hacks trick, which was to stick a bit of skateboard grip tape on the dropper remote lever. I've got one of those Reverb plunger remotes, and it's cold and muddy here at the moment, and though I haven't really been having any issues with the remote lever in these conditions, the little bit of grip tape is a huge improvement to the operation of the thing. Wish I'd have done it sooner. Meanwhile, I'll be closely monitoring the wear in the thumb of my right-hand glove...
    * Can't have been the concrete incident, I was in the middle chainring for that and the outer chainring stepped in as a bashguard.
    Hose me down till the water runs clear.
  30. #530
    Reputation: natas1321's Avatar
    Nov 2017
    lubed the chain and took it to the park since it was so nice out.
  31. #531
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    I abused it......
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
  32. #532
    DFL
    Couldn't ride today because the trails were thawing and snow was melting, so I washed my bike for the first time, ever, adjusted the pivot bearings, and lubed the chain. Played with portrait mode on my phone while it. You can tell where the software gets confused, but it's a cool little toy to play with.
    Untitled by Brett Valentine, on Flickr
  33. #533
    Reputation: screamingbunny's Avatar
    Hand-me-down 1 X 11 annnnnnndddddd camo
  34. #534
    Mar 2017
    I swapped out the tires on my son’s bike and got my old school mtb out to ride in the snow.
  35. #535
    Mar 2017
    I’ve been eyeing this frame! She’s one lucky lady.
  36. #536
    Magically Delicious
    A little rear wheel effort
  37. #537
    Cycologist
    Reputation: chazpat's Avatar
    Quote Originally Posted by screamingbunny View Post
Name:	camo gunnar.jpg
    Nice! I've got two Gunnars but they are both road bikes.
    Quote Originally Posted by Oh My Sack! View Post
    Remember, there's always quilting and knitting if pedalling becomes too tough.
  38. #538
    Having a nice day!
    Reputation: LoneStar's Avatar
    Ordered a new Hope rear hub and feel so sneaky typing this with my unknowing wife sitting beside me
  39. #539
    Magically Delicious
    Settle down there cowboy.
  40. #540
    slow
    Feb 2005
    Downgraded drive train, fork, pedals, and wheels. Upgraded tires, seat post, stem, and bars. Main bike is now more personalized and has parts interchangeable with my other favorite bikes.
  41. #541
    Sep 2012
    2018 will see the beginning of the 3rd year on my '16 Trek Fuel EX 9.9. I try to ride my bikes a full 4 seasons before replacing them.
    While each of the previous 2 seasons have seen loads of chain, brake pad, front ring, and a few cassette replacements, this is the first full drivetrain replacement. I am going from a full Shimano XT to Sram GX Eagle. This way I will run a 34 front instead of the 32. Gear inch wise, I will have the same low end but gain substantially through the top end.
    Also, each season I changed all the dust seals/wipers on the fork and shock. Last year I sent the shock to DirtLabs to have them work their magic on it. It was great! I sent it back again along with the Pike RCT3 and the Fox Transfer dropper post. It all needed new seals, oil, nitrogen charging, etc.
    I am also changing all of the suspension bearings and ABP pivots as well as a new BB (changing standards from Shimano to Sram, remember?). Brake pads/rotors are being replaced (keeping Shimano XT stuff--I love it). Brake fluid will also be changed out. All new cables and housing are being put on too. And new bearings/springs in the eggbeater pedals.
    Basically, it is a full tune plus. It will wind up being a full rebuild; completely striped down and all parts inspected/replaced/lubed. Yes, it is going to be a little expensive, but its worth it. I ride a lot and will get my money's worth for sure.
    At the beginning of each year I do this stuff. Normally it all happens during ski season, so I don't miss the bike at all. This year we are having a very bad ski season--worst in 38 years. I normally would have skied almost 25 days by now and I have yet to go! Not good.
    Good news is, I get the bike back today!
  42. #542
    DFL
    I had to replace my brand new chain yesterday. First ride on it and it snapped twice in 10 minutes.😡 I’m never buying another Shimano chain as long as I live.
  43. #543
    Magically Delicious
    ^^^ There should a valid reason for a new chain snapping as you've described. Any more to the story?
  44. #544
    DFL
    I replaced it at the same time as I added my 49t rear cog. It was a straight forward install, with the included pin, and it broke in two different places. I replaced it with a SRAM chain and rode yesterday afternoon with no issue.
  45. #545
    Reputation: J.B. Weld's Avatar
    There has to be, Shimano's are all I use and I have never broken one.
    I brake for stinkbugs
  46. #546
    Reputation: Rngspnr's Avatar
    Feb 2016
    What did you do FOR your bike today??-img_5200.jpgWhat did you do FOR your bike today??-img_1588.jpg
    New hoops for new year. Increasing carbon footprint!
    2016 Evil Following V1
    2016 Dartmoor Primal+
  47. #547
    Nutrailer
    Reputation: JackWare's Avatar
    Aug 2016
    Quote Originally Posted by LoneStar View Post
    You were very considerate but what's the plan when the delivery guy knocks at the door?
  48. #548
    Bikesexual
    Reputation: jcd46's Avatar
    Quote Originally Posted by JackWare View Post
    Pandora jewelry..delivered at the same time?
    The Orange Fleet:
    '16 SC Heckler
    '14 All City MMD
    '12 Kona Unit Rigid
  49. #549
    Oct 2000
    Quote Originally Posted by jcd46 View Post
    If he times it right he can hide the goods and exchange it, walk into the house with a box for her. Good luck though, I’ve been in situations waiting for a delivery like that on pins and needles at every truck sound passing by.
  50. #550
    Nutrailer
    Aug 2016
    I nominate a local collection site like our local gas station instead of home delivery.
    How sad are we?
  51. #551
    Oct 2000
    How sad are we? 😂😂
    I’ve had packages delivered to my local UPS or FedEx outlet. More out of convenience and worry free of someone stealing it off the porch. It would work for this though.
  52. #552
    Nutrailer
    Aug 2016
    I purchased some some new weighing scales to see how my Nutrail's January diet is going
  53. #553
    Magically Delicious
    A fresh set of Straight Pull I-9 245's for the wife's build
  54. #554
    Aug 2013
    I have my expensive packages delivered to my work. If work is closed the shipper will keep the package until it can be delivered and signed off for. Business deliveries are NEVER left on a porch or door-side in public view.
    Goodbye '95 ZJ. Just so you know, transfering box of left behind womens panties to next truck. Thank you ZJ!
  55. #555
    Oct 2000
    Happy wife happy life. You learn well Grasshopper.
  56. #556
    All my bikes are clean and ready to be ridden. One bike is just sitting patiently waiting to get built up. Only one problem. Weather happens.
  57. #557
    Danger Zone
    Reputation: GoldFly's Avatar
    Nov 2015
    Tubeless conversion on my new Jeffsy. By far the most difficult one I've ever done. Love the bike but not so sure about the DT Swiss M1900 wheels.
  58. #558
    nvphatty
    Guest
    A thorough cleaning of my older steed before the sale to a friend tomorrow.......bitter sweet as it was my 1st, but i know it will be both ridden and cared for as i once did.
  59. #559
    Oct 2000
    Quote Originally Posted by nvphatty View Post
    Did you at least give her a good flogging before her send off?
  60. #560
    nvphatty
    Guest
    sadly no......i will see it as we ride together on occasion.
  61. #561
    Oct 2000
    sadly no......i will see her as we ride together on occasion.
    You are a bigger man that I. Letting her go is one thing but to a friend and then on top of that seeing her with him on occasion. That would kill me.
  62. #562
    Reputation: targnik's Avatar
    Jan 2014
    Rode it like I stole it ^^
    Give the ole girl a clean in the morning ;-)
    'We'll all make it to the top... Some of us, might not make it to the bottom'
    "Mountain biking: the under-rated and drug-free antidepressant"
  63. #563
    nvphatty
    Guest
    i see what you did there young man!! and BTW the friend is a gal, so a gal receiving a gal of sorts one might say
  64. #564
    Bikesexual
    Hmm thought she was a no show?
    Did u sell your roadie?
    The Orange Fleet:
    '16 SC Heckler
    '14 All City MMD
    '12 Kona Unit Rigid
  65. #565
    nvphatty
    Guest
    she was, not that any formal invite was offered....
    sold my 1st mtb, an 08 iron horse mk111
  66. #566
    Oct 2000
    Well, that they say can hurt even more. You drove her to switch teams and then were big enough to hand her off to another. Much kudos to you my friend.
  67. #567
    nvphatty
    Guest
    sale is final with an in depth tutorial before i handed it over...
  68. #568
    Oct 2011
    installed the shorter stem:
    Attached Thumbnails Attached Thumbnails What did you do FOR your bike today??-img-3435.jpg
  69. #569
    Cycologist
    Quote Originally Posted by shekky View Post
    Where? I can't see it!
  70. #570
    nvphatty
    Guest
    is that a luggage mount i see??
  71. #571
    Magically Delicious
    It kinda looks like he's saddled up.
  72. #572
    Oct 2011
    niterider COULD make their mounts a little more low-profile...
  73. #573
    Oct 2000
    Yeah, maybe I carried that one a bit too far.
  74. #574
    nvphatty
    Guest
    seriously??
  75. #575
    Reputation: demonlarry's Avatar
    For my bike, I stayed on track with my weight loss regimen!
    I promised her she wouldn't have to carry such a load!!
  76. #576
    Jan 2014
    Raining cats & dogs outside... so no riding today.
    Bit of black spray paint put on to cover up scratches etc. on both my mules.
  77. #577
    Reputation: sturge's Avatar
    Separated shoulder 10 days ago so on the mend...converting my Heckler from 3X9 to 1X9. Also working on the new Kona Process that pulled a stick into rear derailleur and fukked it up on 5th ride. Have a Park derailleur hangar alignment tool on order to see if I can salvage the GX12 derailleur. At least one bike will be ready when I'm healed!
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...
  78. #578
    nvphatty
    Guest
    Quote Originally Posted by targnik View Post
    i've always been curious of this quote and it's relative meaning.
    “raining cats and dogs” may refer to a storm with wind (dogs) and heavy rain (cats). If it is raining cats and dogs, it is raining unusually or unbelievably hard.
  79. #579
    Jan 2014
    https://i.stuff.co.nz/otago/10107643...e-of-emergency
  80. #580
    Reputation: Darth Lefty's Avatar
    Sep 2014
    My Dad would say "It's raining cats, dogs, and little fishes." What do the fishes represent?
    Also "It's raining pitchforks and axe handles"
  81. #581
    Oct 2000
    It means: It’s raining buckets outside, jeez do I have to explain everything around here?
  82. #582
    Nov 2017
    Nothing much, replaced the pins on the pedals, lubed the chain and gave the bike a decent wipe down and took it out for a few hours.
    Sent from my HTC6535LVW using Tapatalk
  83. #583
    Cycologist
    I know, I just stepped in a poodle.
    (sorry, couldn't resist)
  84. #584
    Oct 2011
    Quote Originally Posted by Darth Lefty View Post
    when it was raining at the same time the sun was shining my grandmother would say "the devil's beatin' his wife"...
  85. #585
    Reputation: OwenM's Avatar
    Oct 2012
    That also means it will rain the next day.
  86. #586
    Feb 2018
    I did look at my bike today...does that count.
    Of course is was 28 deg when I woke up this morning.
  87. #587
    DFL
    Did the 54T ratchet upgrade on my DT350 and successfully swapped out my rear 180mm rotor for a 203mm. Unsuccessfully tried to swap out my front 180mm rotor for a 203mm, I bought the wrong f*cking adapter. Hello $10 shipping because I need it by Wednesday, and the closest bike shop that has one is an hour away. I get off too late at night to make it there during the week.
  88. #588
    Magically Delicious
    ^^^ Did you swap from a stock 18t or the 36t?
  89. #589
    DFL
    Turns out it was a 36T, I thought it was an 18T.
  90. #590
    Oct 2012
    It's a good upgrade, either way. I've seen people comment they can't tell much difference. The internet being what it is, I have to wonder if they've ever even seen a 54T ratchet outside of pictures, much less ridden one. The more POE I try, the more I want...
  91. #591
    Jan 2014
    Took spacers out from flat pedals ^^
  92. #592
    Magically Delicious
    Wife's build all but fitted & 'dialed-in'
  93. #593
    Reputation: MRMOLE's Avatar
    New rear tire for the Mukluk!
  94. #594
    Oct 2011
    the sun glare from my top tube was getting to me.
    some gaffer's tape took care of that:
  95. #595
    Feb 2018
    New Raceface Next R cranks, 203mm front disk, and a full teardown and clean getting it ready for spring.
  96. #596
    Magically Delicious
    Get a Grip...
  97. #597
    Nov 2017
    Cleaned the bike and ordered some new grips, have to do something while the weather is bad.
  98. #598
    Magically Delicious
    Get a Grip with some Old Grips...
  99. #599
    Oct 2000
    MacGyver ^
  100. #600
    Oct 2011
    rode it to the shop for a new rockshox reverb, a pair of hope hubs laced to WTB rims and new rotors and pads.
    more to follow.
  1. New bike came in today ... Now what?
    By Pocket Lint in forum Beginner's Corner
    Last Post: 05-04-2014, 05:51 PM
  2. Well got my new bike today!!!
    By Jaysrubi in forum 29er Bikes
    Last Post: 03-30-2014, 05:14 PM
  3. What did you do to/for your bike today?
    By Hollyw00d in forum Riding Passion and Stories
    Last Post: 02-17-2013, 09:06 PM
  4. Saw my old bike today...
    By Sorebuttbiker in forum General Discussion
    Last Post: 04-25-2012, 08:23 AM
  5. New bike today!!!
    By jurichar in forum Colorado - Front Range
    Last Post: 01-13-2011, 12:04 PM
Members who have read this thread: 53
