Results 1 to 20 of 20
    Reputation: sunny_fruit's Avatar
    New GENUS ...of Bicycle... Can you make this Sunnycle
    A few days ago accidentally invented a new kind of recumbent bicycle
    I made pictures(drawings) of this bike
    and because I am unable to do it ...
    ... and looks forward to seeing who will do it first
    It is:
    ...FrontWheelsDrive (lever)
    ...BothWheelsSteering (body)
    - lighter
    - faster
    - Front wheel drive
    - With an excellent aero-dynamic
    - The pedals move independently of one another
    - multi - speed lever drive
    - Free - Hands bicycle
    - Turbo Mode
    Hooded menace
    Reputation: papanoel's Avatar
    Nov 2008
    Good to see some new ideas, here.
    I'd be curious to know how it rides as you seem to steer with the back wheel...
    I'd like to see some climbing/tech section reviews with that FWD. And is this a singlespeed?
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    So that backwards looking thing is front wheel drive I assume. Looks like that wheel is frighteningly close to the riders package area.
    Interesting concept, but that hta looks to be about 50 deg. Might be a little floppy.
    yeah, uh............bikes
    Reputation: FloridaFish's Avatar
    very creative.
    When you're lying through ... body steering
    Oct 2010
    I must be immature. That last pick made me snicker.
    Gr8 idea btw!
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    Reminds me of that South Park episode with Mr. Garrison on the Wheel thing.
    "...like sex with the trail." - Boe
    it's called a rear-steer recumbent.
    http://www.google.ca/images?q=rear-s...w=1239&bih=790
    If steel is real then aluminium is supercallafragiliniun!
    Yes, that's fonetic
    Feb 2005
    Except he seems to be laying on the steering linkage. Another recumbent that'd do okay on the road but would have virtually zero use on trails.
    Better than anything I've ever designed though.
    Reputation: stnewt's Avatar
    Feb 2010
    I hope he doesn't slip off the pedals !!!
    ...bws
    ?? ... with Lever Drive
    The power transmitted through human ... x ... pedal to the whee
    If he rode a bicycle to drive with Lever Support (shoulders) ... he will be able to exercise this power, pressure on the pedals - x3 - x6 X-Bwt(Exact Bodyweight)
    If he rode a bicycle with a simple round Chainring
    ... under pressure on the pedals will vary between X 0.3 - X 1 X-Bwt (support is gravity)
    Adding:
    ... simple construction
    ... the possibility of simultaneously pressing both pedals
    ... short pressure or pressure long ... you choose !..
    ?? ... Is it a one-speed drive only?
    ...multi-speed lever drive system
    …ratio is x1 to x5
    ?? ... Control and support of the saddle-back
    Rolling
    Reputation: lidarman's Avatar
    Quote Originally Posted by byknuts
    actually, it looks like a combo of a recumbant and a eliptigo--using the eliptigo drive.
    http://www.elliptigo.com/product/description/
    My problem with this is that powerlifting does not translate to endurance effort. Going to ride this as fast as you can for 100 yards?
    BTW, sunny fruit, although you gave this a lot of thought, you should research the literature. There is a lot out there, most invented around 1900. Also, on a normal bike, one can exert more than their body weight. You simply use the handlebars to pull against when you are out of the saddle (like doing a deadlift). Singlespeeders use this as part of the normal riding style. Also, for exercise sake, this is great because it helps work out the upper body.
    is buachail foighneach me
    Reputation: sean salach's Avatar
    It's interesting enough to want to see a built version and at least ride it around at interbike for shlitz and giggles. I love these types of designs, and this one is a unique combination of ideas. I like it.
    Re-newal ... joint between the two parts of the bicycle frame is a little more specific ... when cornering, the front wheel tilt ... so both tires move after another ...
    Attached Thumbnails Attached Thumbnails A few days ago accidentally invented a new kind of bicycle-bsb.jpg
    Reputation: phirebug's Avatar
    the prone position/lever drive can't be that bad of an idea. Graeme Obree is about to take a crack at the world human-powered land speed record on one of his own design in less than two weeks.
    Don't buy all the lies that they feed ya.
    Reputation: woahey's Avatar
    Looks like something from a Southpark Episode...I know, I'm a d!ck
    The secret to mountain biking is pretty simple. The slower you go the more likely it is you’ll crash.
    - Julie Furtado
