Thirsty Mach 4 rider needs to mount water bottle- Mtbr.com
Results 1 to 7 of 7
    Aug 2005
    Anyone worked out how to fit a water bottle to a Small Mach 4 - 2012 model?
    Even with a side swipe cage I'm not sure if a bottle will fit into the frame?
    No point purchasing one if it just doesn't fit.
    Anyone here with experience?
    Paterfamilias
    Feb 2006
    You can turn the RP23 around the other direction. This will allow you to have more room for your water bottle.
    turning the shock around will have no affect on it's function. The RP23 is an air shock, regardless of it's placement on your frame it will function correctly. We install them on the frame with the air canister forward for aesthetic purposes.
    Happy Trails!
    "The face of a child can say it all, especially the mouth part of the face".
    Jack Handy
    Missouri sucks...
    Aug 2005
    Thanks for the reply but Pfftt... Handlebar mount.
    rather go thirsty.
    I'll try reversing the shock...
    Just need to work out how to take out the bushings that hold the shock in place without damaging them?
    Missouri sucks...
    I was suggesting mounting it on the seatpost I wouldn't want a bar mount either!
    Reputation: metelhead's Avatar
    water makes your bike heavier:
    CamelBak® - Home
    "Be Good or Be Good at it"
    Aug 2005
    Quote Originally Posted by metelhead View Post
    CamelBak® - Home
    Water can get heavy!
    Want it for those enduro races when were only doing one lap at a time.
    Won't bother with a camel back then.
  1. Water Bottle on Medium Mach 5?
    By rocdog in forum Pivot Cycles
    Last Post: 10-03-2009, 08:51 PM
  2. Mach 5 Water Bottle Mount
    By zx6rpete in forum Pivot Cycles
    Last Post: 11-10-2008, 08:12 PM
  3. ideas on how to mount another water bottle?
    By fran in forum Rocky Mountain
    Last Post: 12-12-2007, 08:40 PM
  4. Double water bottle mount?
    By wallyh3 in forum General Discussion
    Last Post: 07-27-2007, 12:26 PM
  5. Replies: 2
    Last Post: 05-25-2006, 08:21 AM
