Switchblade V2 Pictures & Tech Talk- Mtbr.com
Results 1 to 84 of 84
    I thought it makes sense to share some pictures & experiences between SB V2 owners.
    Here are some pictures of my large SB V2 that I took during our vacation on Madeira.
    First issue I have is that the lower shock bushing has play after only 4-5 rides. Anyone else has play in the rear end?
    My V1 Switchblade had the same bushings for nearly 3 years without any issues. I'll take the shock out this weekend and get in contact with my Pivot dealer on Monday.
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Switchblade V2
    Pivot Vault
    Orbea Alma
    Had time to take a closer look today at the issue with the play in the rear end. Turns out that my lower shock screw has play within the bushing.
    I'm pretty sure that was an issue from the beginning. I guess just a tolerance issue that should be no big deal to get replaced/fixed.
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Vault
    Orbea Alma
    Already got an answer with a fix.
    The lower shock screw needs to be tightened with 16nm instead of the recommended 13nm. Now the problem seems to be gone.
    Apparently this happened before so might be worth checking when you have your new bike.
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Vault
    Orbea Alma
    May 2016
    I'm going to pull the trigger on one this week assuming theyre available. Really torn on color, would prefer the green but the blue may look better with the build kit that's going on it. Have some silver accents with the cane creek ti cranks, xtr 4 piston brakes, and silver I9's on my Enve's. Going to run A Lyrik and a Super Deluxe Ultimate Coil. Hopefully one one isn't available in XL so that can make the decision for me.
    Had the same lower bolt problem, tightened it and it fixed it.
    Sent from my SM-N960U using Tapatalk
    A few more things from my side.
    Race Face Next R Cranks: I installed the upgrade cranks (supplied by Pivot). One thick and one thin spacer on each side works out well and gives the correct chain line.
    Seat Post Cable: The original Jagwire cable housing is pretty thin (I believe its 4mm). This means it's not well clamped and things become noise pretty quickly. I switched to a 5mm Shimano cable which improved things. Would still be interested in how others handle this issue (it's the same on every Pivot frame I believe).
    I also installed a -1 angle set from Works components. Good improvement. I wonder if -1.5 would have been even better.
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Vault
    Orbea Alma
    May 2018
    220/200mm Hope rotors, 30t Wolftooth chainring, OneUp composite flats, tubeless and fully Ridewrapped. Have a few items left to install like crank boots, 35mm rise Renthal Fatbar and Apex stem, Chromag Squarewave XL grips and Trailmaster DT seat. Iíll give the stock seat/bars a chance first though.
    Attached Thumbnails Attached Thumbnails Switchblade V2 Pictures & Tech Talk-37a11a17-0ddf-42d2-ba28-77b4fc6b0b45.jpeg
    May 2013
    Looks great! I wonít be able to hold off much longer.....
    Love this color
    May 2018
    Got the new bike home. I hung it on my scale and I was surprised itís reading 34.0lbs. Anyone else have an XL that theyíve weighed?
    This is an XL Team XTR with 30t Wolftooth chainring, 220/203mm Hope floating rotors, Ridewrap vinyl kit, OneUp composite pedals, Raceface crank boots, Renthal Carbon 35mm rise Fatbar with Chromag Squarewave XL grips, tires converted to tubeless and Shockwiz attached. I guess some of that stuff adds up fast but according to specs should only have added 1.5lbs and shoukd have maybe lost a little with the tubeless conversion. Anyone else have an XL, whatís it weigh? 32.5lb shipping weight seem about right?
    Iím not a weight weenie, just a bike geek. My scale might be inaccurate too, itís a cheapo Performance Tools hanging unit rated for 600lbs so bicycles are definitely very low on itís spectrum.
    Sim
    Sim is online now
    My XL Pro XT with xt pedals weighed 32.9 on my bathroom digital scales. I replaced the DHRII with a Mountain King so it would roll and dropped a pound. It's a pig but it's a fun pig!
    rubber side down
    Has anyone swapped to a coil yet on the SB? I've been itching to try one out, thinking Hazzard or DHX2.
    Just got mine today. Blue size L. Came off of a 2018 mach 6, the sb is so much fun to ride. I am looking at carbon wheels for my next upgrade.
    May 2018
    Question, I was surprised my Team XTR build didnít come with the i-spec shifter/brake clamp. Did anyone elseís? Is there an adapter I can use to integrate them without changing components?
    Reputation: Dogboy's Avatar
    Quote Originally Posted by Camstyn View Post
    Shimano part number Y0FA98050
    Retail is $51.
    Mine came with full i-spec setup.
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Vault
    Orbea Alma
    Mine did both brake and dropper
    Had to warranty the raceface cranks because they were clicking like crazy. While doing that picked up an absolute black chain ring
    Reputation: weaver84's Avatar
    Bike looks great, same color I went with and I have to say I donít think pictures do this color of blue justice!
    How did you come up with the number of spacers on each side with the race face next r crank install? Does anyone know how pivot is setting up the spacers to optimize chainline?
    Quote Originally Posted by weaver84 View Post
    Yes! Check what I wrote here reg. the cranks:
    https://forums.mtbr.com/pivot-cycles...l#post14607901
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Vault
    Orbea Alma
    TRANCER
    Reputation: Biohazard74's Avatar
    I love blue bikes but that green had really won me over. So many good beautiful bikes these days. 😎🤙
    Ride
    Were you able to measure if this gave you the recommended 65.5 mm chainline recommended by Pivot?
    I did not measure it but it was the specs that my dealer gave me and the shifting works flawless now!
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Vault
    Orbea Alma
    Shot from yesterday. Love how this bike rides with a -1 AngleSet.
    Also it's rolling so much better with the 2.5 Aggressor in the back. I wonder if the OEM tires are heavier than aftermarket tires?
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Vault
    Orbea Alma
    Yup! This was the ticket! The OCD side of me also confirmed with the online chat Pivot offers quick response! Thanks Again!
    Oct 2018
    Had my 2018 Santa Cruz Hightower LT XX1 stolen two weeks ago from a locked garage.
    Went to my LBS and demo'd a pivot switchblade. First time on a shimano drive train. What a treat it was. Thing climbed exceptionally well compared to my 160mm forked hightower LT with an x2.
    Those short chainstays are sick.
    Placed my order today for a Large Team XTR in green and also ordered a Fox DHX2 coil to check it out.
    I'm hoping since I placed that order today it'll come with the newly announced Fox 2021 36 fork. LBS told me it'd be about a month out until my bike arrived.
    Quote Originally Posted by bliz2z View Post
    Just installed the same tire on the rear of mine as well. We'll see how well it does this weekend.
    Me too, but I havenít yet...
    I did put a PUSH ACS3 in though...
    What are people using for a chain guide/bash guard? I tried to use my OneUp components V1 bash guide and it did not seem to be compatible with the superboost spacing?
    Reputation: BikinAggie's Avatar
    I have the same bashguide on my Firebird 29. No spacers under the ISCG mount, and I think all but one spacer for the guide is what worked for me.
    Quote Originally Posted by Owler
    Do not dispute right of way with a tree.
    Anyone besides me looking at upgrading to carbon wheels? I did not have the option when I bought as I purchased the demo bike. I like the Nobl's with onyx hubs.
    I have the OneUp with bash guard on mine. Fits great when you use the included spacers.
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Vault
    Orbea Alma
    Oct 2018
    Been six days since I ordered.
    Bike hasn't got here yet and I've already ordered an ergon sm seat, wolftooth grips, wolftooth lever, ridewrap, crank boots, mrp bash guard, fidlock bottle mount, fox dhx2 coil with a 550lb spring.
    Anybody else thrown a coil on this bike yet? What's your weight and spring you've used with sag %? I'm 225lbs 6'0" and bought a 550lb sls hoping that'll put me in the ballpark. Hoping I don't have to swap too many to get it right.
    Here's to hoping pivot receives that shipment of 2020 fox suspension before they ship mine out, but in all honesty I've bikeless for going on 3 weeks post theft and I'm feigning hard.
    The little tube/CO2 holder works pretty well. At least it didn't make any noises or fell off during two the last two rides .
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Vault
    Orbea Alma
    Oct 2018
    Haven't taken it out yet, been busy. But just got here.
    I just built my medium last night. Can't wait for the maiden voyage later today. I'm glad I waited till now to pick one up because I was able to score the new Fox Factory suspension on both ends and the new Transfer drop post.
    The bike went together pretty well. I wasn't sure about the spacing for the cranks so I called Pivot. They recommended the following:
    Non-Drive side: 3 1mm spacers and 1 1.5mm spacer
    Drive side: 1 1mm spacer and 1 1.5mm spacer
    This seemed to put the chain line somewhere in the 55-58mm range.
    I plan to swap out the headset to a Chris King, the seat clamp to Wolf Tooth, and the chainring to a oval Wolf Tooth. I open to suggestions for color(s) on all three.
    I'll post more as I put some miles on it.Switchblade V2 Pictures & Tech Talk-img_1497.jpgSwitchblade V2 Pictures & Tech Talk-img_1496.jpgSwitchblade V2 Pictures & Tech Talk-img_1495.jpgSwitchblade V2 Pictures & Tech Talk-img_1494.jpgSwitchblade V2 Pictures & Tech Talk-img_1502.jpgSwitchblade V2 Pictures & Tech Talk-img_1499.jpgSwitchblade V2 Pictures & Tech Talk-img_1501.jpg
    2019 Pivot Trail 429
    TRANCER
    That green really is growing on me.
    Ride
    Oct 2018
    Quote Originally Posted by JOE2465 View Post
    Super envious my friend, I picked up my large green on sunday and didnt get the new 36 fork. Now Im just going to have to upgrade it to the new fox 36 when it's time to service instead of paying the $200 for the service. haha.
    Jun 2019
    Nice bike. Re colors:
    Chris King headset - black
    Wolf Tooth seat clamp - black
    Wolf Tooth oval chainring - black
    pap
    pap is offline
    I'll post more as I put some miles on it.Click image for larger version.
ID:	1326879Click image for larger version.
ID:	1326881Click image for larger version.
ID:	1326883Click image for larger version.
ID:	1326885Click image for larger version.
ID:	1326887Click image for larger version.
ID:	1326889Click image for larger version.
    Looks great! You ordered the entire bike? So, pivot is shipping them with all new 2021 fox shocks now? I ask because I'm about to order mine today.
    Sent from my Pixel 4 XL using Tapatalk
    I called Pivot ahead of time to inquire about the bike specs and was told Switchblades are being shipped with 2021 Fox products. I'm not sure about other bike models. I ordered a complete XTR bike.
    pap
    pap is offline
    That's great news. I'll be ordering your exact bike setup today. Was thinking about the live valve but not sure it's worth it with this bike considering how efficient it is. Thank you.
    Hello !
    My first 29 "
    I owned before a Mach 5.5
    A bike that I managed to limit in weight to 13.1 kgs
    Sep 2015
    I have three questions, not sure someone could answer...
    1. What is the weight of a Large Xt/Xtr with Reynolds carbon wheels or stock stocks Swiss wheels?
    2. I know it says that the Reynolds wheels are Reynolds Blacklabel Enduro Wide Trail w/ Industry Nine hub, 34mm - is the 34mm internal width or external. I went to the Reynolds website and I think they are these ones? 34mm inside 39 mm outer
    https://hayesbicycle.com/collections...rail-349-hydra
    3. Are Reynolds wheels decent? If not Reynolds, what else would you guys get? Not too many options with super boost.
    Thanks for your responses.
    Oct 2018
    Quote Originally Posted by pap View Post
    Mtbyumyumís video review talks about how he enjoyed the bike more without the live valve vs with it. Less muted feeling and more playful without it.
    pap
    pap is offline
    Quote Originally Posted by wmm1985 View Post
    Thank you. I'll check out the video.
    Quote Originally Posted by bachey View Post
    Thanks for your responses.[/QUOTE]
    Yes Black label 34mm internal width
    I've had a couple sets of Reynolds wheels. They are great quality and ride very nicely for me. I enjoy the stiffness and ride characteristics which compliments the switchblade very well. Also now that Hayes owns Reynolds they are offering a lifetime warranty. The Hydra hubs are great but the Reynolds hub shells are understated compared to he non oem shells from i9
    You won't go wrong with other wheelsets but TBH I've ridden Derby's/we are one/enve wheelsets and Reynolds is on par. I've done some questionable drops that have pinged the rim with Reynolds and they hold up very wheel in my day to day riding in the rocky Southwest
    In my opinion pivot has done a solid job specing their bike components and they all work very well in tandem.
    Sep 2015
    Thanks for the reply InJ3cted. Just to be clear you are talking about the ďlookĒ of the outside of the hubs are nothing special compared to buying the I9 hubs say directly from Ibis? There is not a lot of distinguishing marks on the Reynolds version hubs? They are still 100% I9 hydra internally though correct?
    Thanks for the response on the Reynolds. I think Iím getting ready to pull the trigger on a new switchblade. Test rode one a few days ago and itís just so different than my current ride. Hard to compare.
    Do you happen to have a weight for your green bike.. nice bike by the way.
    Thanks again,
    Don
    Thanks again,
    Don
    Haha man you opened a can of worms. I did some searching and can't say 100% they sound like hydras I have torches next to it and they're definitely different sounding. I dropped pivot support a note to ask because it's not completely clear.
    Maybe someone else here can confirm
    I have a team xtr medium and I didn't weigh it
    Oct 2018
    Quote Originally Posted by InJ3cted View Post
    coming from torches. These def have more engagement buzz. My lbs told me they were hydras :shrug: The exterior hub body doesnít look the same as i9ís hydras though. The factory i9ís hubs look cooler.
    pap
    pap is offline
    A tell tale would be to pull the rear wheel off then you can slide the cassette off with the freehub without a tool. That would be the Hydra.
    Sep 2015
    Thanks for the responses guys. Hmmm, I do know that torches and hydras sound very different. I guess if it has crazy amounts of engagement it would have to be some form of a hydra. One would hope they wouldnít use an lesser internal hydra (if thatís even possible).
    To bad one couldnít get a coloured ďlegitĒ hydra as an option on the wheels.
    Good call, They look like hydras with the smaller groves and the driver has the new leaf springs vs those micro springs.
    Excuse the dust
    pap
    pap is offline
    Excuse the dust
    That is certainly Hydra! Enjoy.
    Sep 2015
    Thanks so much for doing that. Awesome.
    Fragilie
    Reputation: Eric B's Avatar
    How tall are you guys on the mediums and larges? Pulling the trigger on one today and on the fence as to which size to get. I'm right at 5'9.5.
    It's Better To Die On Your Feet Than To Live On Your Knees. (Emiliano Zapata)
    Oct 2018
    Quote Originally Posted by Eric B View Post
    Iím 6í0Ē on a large and sat on a medium because the pivot large felt larger than my Santa Cruz Hightower large. I know some pros like Matt walker ride medium and they are 6 foot.
    I like the large, if I was a few inches shorter Iíd probably size down to a medium.
    Sep 2015
    Iím 5í10Ē and wear 30Ē length jeans and tested a large. Seemed pretty good to me and personally I wouldnít want to go smaller. However, I donít own the bike, so take it for what itís worth.
    Oct 2013
    I'm 5'10" and had a large v1 switchblade. Thought about sizing down for the v2 switchblade but I didn't like the feel of it in the parking lot compared to the large. Went with the large and it feels good out on the trail.
    change is good
    Sep 2004
    5í11, 35in inseam, so long legs, very short torso. Large with a 32mm stem.
    Sent from my iPad using Tapatalk Pro
    mnt bike laws of physics
    Reputation: yogiprophet's Avatar
    https://classifieds.mtbr.com/showproduct.php?
    Industry Nine Carbon Super Boost Wheel for cheap
    Jun 2016
    Jealous of those who got the 2021 Fox stuff! I received my XL Blue 2 weeks ago and unfortunately got the old fork. Am I correct in thinking the shock is the same aside from the stickers?
    Sep 2015
    A little help, Iím looking at a large pro build with carbon wheels. Iím not a weight weenie, but is there a way to get this bike under 30 lbs. maybe in the 29 range. From what I have seen, a team build (highest end) is weighing in around 30.5 lbs.
    the only thing thatís left would be crankset, chain, cassette I imagine. Everything else is carbon. And tires.
    Any thoughts on how to get weight down already with the carbon wheels?
    Int'l Sales - PIVOT
    Reputation: John P.'s Avatar
    Wheels, tires, and cranks.
    Wheels - The black labels are light, but you can do a custom set that are lighter (and more expensive, and probably less bombproof). I did i9's laced to E13 TRS Race SL's, and they've been pretty good for 18mos now (ran them on my Trail429 last year).
    Tires - I ditched the Minions that we spec for some Schwalbes that work well here in New England (Hans Dampf F, Nobby Nic R).
    Cranks - Assuming you're talking about the Pro XT/XTR kit with the alloy cranks, you can get some RF NEXT SL's that will save you almost 200g.
    I made all of these changes to my build. The wheels/tires saved 500g (over AL rims), and the cranks saved another 200g. 700g is 1.54 lbs.
    Obviously, there are trade-offs here, mostly in the form of strength and price. I ride pretty 'light', so the wheels have held up fine, and I've only gotten a couple of pinch flats on those light casing tires over the course of a 18mos. I'm also doing fine on my NEXT SL cranks that are 3 years old (knocking on wood as I type), though I have heard of others breaking them.
    JP
    PIVOT Cycles
    Please Email rather than PM: johnp AT pivotcycles DOT com
    Instagram: @heyjohnp
    Sep 2015
    Thanks JP. Thanks for confirming those are the spots to save some weight. Yeah, cranks and tires I see as my only options if I decide to buy the bike. I think I will leave the Reynolds rims as Iím not a featherlight. The easiest thing to save some weight I guess would be if I lost some. But thatís the easy answer. Also much less expensive answer.
    I took a large out for a rip, short one, and I liked it. Just so hard to compare to what I am used to which is a 2016 giant trance advanced with carbon rims and 27.5Ē tires. The geometry is different, I sit on the trance and in the switchblade. The switchblade feels heavier donít know actual pound differences. Iím a chunky monkey and my bike does feel flexy but not the switchblade.
    The other hard part is the $$$. There is nothing really wrong with my bike and so spending close to $10,000 Canadian on a pedal bike seems absurd. I know pivot is a good brand and it is quality, but Iím questioning the $$$ as well. I mean I can justify my health is important and all that...but I got a bike that so far has held up and keeps me going. So do I need a new one? Uh, I kind of want one, but donít need one. Common sense isnít helping me right now.
    If youíre not in perfect physical shape and racing competitively, why is a few pounds of bike weight important?
    Sep 2018
    Quote Originally Posted by John P. View Post
    Tires - I ditched the Minions that we spec for some Schwalbes that work well here in New England (Hans Dampf F, Dirty Dan R).
    JP
    Thats a strange combo, Dirty Dan is a mud tire... at list i would mount them the opposite way, if not taking it down and change it to Magic Mary (F) / Hans Dapmf (R).
  67. #67
    Sep 2015
    Quote Originally Posted by itsky View Post
    Yeah, you got a point there.
  68. #68
    Nov 2006
    No, he doesn't really. What, do we now need to meet some silly metric like BMI before we're allowed to upgrade our bikes?
    If you have the cash, want to upgrade your bike and it makes you happy I say go for it regardless of how much you weigh or what kind of shape you are in.
  69. #69
    Sep 2015
    Also true. Okay, well, I feel bad for derailing this thread about my weight, so letís feel free to get back to talking about tech about switchblade
    Iím going to take the bike at my shop out for one more ride just to confirm that itís the one bike for me.
  70. #70
    Int'l Sales - PIVOT
    Quote Originally Posted by Muddy-Runs View Post
    Whoops... meant to say Nobby Nic on the rear (went back and fixed it). All of Schwalbe's alliterative names get mixed up in my head. Haha
    PIVOT Cycles
  71. #71
    change is good
    Sep 2004
    Because Iím heavy I need to buy expensive parts because my body morphology puts me at an disadvantage
    Personally, I feel us clydes that ride often donít have much info made available to us.
    The SB is stiff. At first I felt V1 was stiffer, but now I feel the current gen frame is stiffer. Rock gardens are much easier to transverse.
    Iím thinking of getting the Fox 38. Not because I can send it but once again, in the tech, stiffness inspires confidence.
    The bike is heavy. Iím not afraid of it breaking like so many of my past bikes. The bike is fun. So.....
    157 boost has meant less wheel rebuilds, and it does feel stiffer to me.
  72. #72
    Binge Rider
    Reputation: Spine Shank's Avatar
    Sep 2004
    Any luck with the cable slap problem inside the DT? Did the Shimano housing fix it? Its pretty loud.
    "Courage is fear holding on a minute longer" General Patton
    CAUTION: ADJUSTABLE SUSPENSION CONFUSES ME
  73. #73
    Sep 2015
    I bought the SB in Large Blue. You can read my demo report on the other SB thread in the Pivot forum. Feel like it is more robust bike like Dr Don mentioned.
  74. #74
    Int'l Sales - PIVOT
    Quote Originally Posted by Spine Shank View Post
    I haven't heard of this issue. A couple things to check:
    1. Make sure your cable housing and brake hose are under tension and secure via the cable port covers. Tighten one end down, pull it taught, and tighten the other end down. If the hose or housing can pull loose easily, wrap a little electrical tape around the housing where it's clamped down by the cable port cover, and this will secure it. Once that hose and housing are under tension, there won't be any way for it to rattle around in there.
    2. Make sure the cable rattle you're hearing aren't 2 cables slapping together in front of your cockpit. I spent the better part of a month trying to silence cable rattle that I thought was coming from inside my bike until I realized it was my front brake cable rattling against my dropper cable.
    Best of luck,
    JP
    PIVOT Cycles
  75. #75
    I have the same issue.. I just put some tape around the housing and cinched it down. Little annoying
  76. #76
    Rider
    Reputation: TylerVernon's Avatar
    Nov 2019
  77. #77
    Best of luck,
    JP
    Both my Switchblades had this issue with noise from the cables. Both times it was the seat post cables only.
    What fixed it now was to switch to a slightly thicker cable housing (5mm instead of 4mm) so that the cable port cover can actually hold it in place. Look for Shimano SIS-SP51.
    Would be nice if Pivot could do this from the beginning..
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Vault
    Orbea Alma
  78. #78
    Paterfamilias
    Feb 2006
    My Switchblade did the same. I used a little electrical tape to so I could tighten it down on the cable, now it is silent. I understand that now the upper cable port clamp comes with a piece of rubber to help solve this issue. I don't think it is something that happens on all bikes, but now the clamp comes with a solution, so people won't have the same issue.
    "The face of a child can say it all, especially the mouth part of the face".
    Jack Handy
  79. #79
    Quote Originally Posted by dan23 View Post
    Good to know that Pivot addressed the issue now.
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Vault
    Orbea Alma
  80. #80
    Sunday riding, treeline green fits right in with the
  81. #81
    Amazing picture! 👍
    Filme von Draussen
    Instagram Profile
    Current bikes:
    Pivot Vault
    Orbea Alma
  82. #82
    Switchblade in action in the French Basque country
    https://www.youtube.com/watch?v=3Dd32yaoqW0&t=
  83. #83
    Reputation: Chaseco's Avatar
    Dang, I didn't know what that rubber was for! I'll have to look for it. Hahaha. I bought a medium. I'm 5'11 with a 30" inseam. It fits great. Switchblade V2 Pictures & Tech Talk-916c3fe9-96a0-477b-b99e-9ba142403ebc.jpeg
  84. #84
    Jul 2013
    I just built mine and can confirm this is true.
    And I think someone asked about weight... medium Team XTR build with no changes other than Candy pedals... 30.5 lbs.
    Sent from my SM-T813 using Tapatalk
  1. Can you convert a V2 Bronson to a V2 Solo
    By VicP in forum Santa Cruz
    Last Post: 04-07-2016, 05:06 PM
  2. Bronson v2 or 5010 v2 for N. Cal Bay Area?
    By Jukas in forum Santa Cruz
    Last Post: 03-31-2016, 06:59 PM
  3. Wildcard 2009 vs. Rune V2 vs. Spitfire V2
    By endlessrider in forum Banshee Bikes
    Last Post: 04-04-2015, 11:53 PM
  4. Replies: 42
    Last Post: 12-01-2014, 08:26 AM
  5. Switchblade vs. Race X-lite Switchblade???
    By sammypants in forum 29er Bikes
    Last Post: 04-28-2007, 10:15 AM
Members who have read this thread: 311
