Rubberized seatstay protector on Mach 6 starting too peel off- Mtbr.com
Results 1 to 11 of 11
    Sep 2004
    Any Mach 6 owners starting to have this problem. I have about 6 good rides on it and noticed the seatstay protector is starting to peel away from the frame. This one is small, hate to see the downtube one peel off. is there a fix for this? special glue etc....... thx
    Yep. Mines starting to peel off a bit. The down tube a bit also, but to a lesser degree. Not to the point where I feel it's going to fall off anytime soon, but I'd be surprised if it was still hanging on very well in a year.
    Mine is doing the same...
    Reputation: vikb's Avatar
    Use Seam Seal/Shoe Goo or some similar adhesive and stick it back on. Clean the area under the pulled up area first with some rubbing alcohol.
    Safe riding,
    Vik
    www.vikapproved.com
    Sep 2004
    Quote Originally Posted by vikb View Post
    I dont know what seam/seal is but I have some shoe goo, i'll try that thx
    Quote Originally Posted by stokerslo View Post
    Seam Seal is runny Shoe Goo.
    Safe riding,
    Vik
    www.vikapproved.com
    Rocks belong
    Its used to seal the seams on tents. Buy it at Walmart, REI, or any outdoors store. Comes in a small bottle with a brush built into the cap.
    bad reputation
    Reputation: turfnsurf's Avatar
    Nov 2007
    Mine was showing signs of coming off right out of the box, seat and chain stays. I pressed them back onto the adhesive and expect it to become a problem down the line.
    Isn't this the same rubberized protector design used on the 575Cs and 429Cs? Maybe some owners of those could give a heads up as to if this is going to become a problem and, if so, what they did to mitigate it.
    Yes, it is the same stuff. I think they may have a manufacturing issue with the adhesive on the M6's because none of my friends M429's have this issue.
    May 2013
    Mine's peeling also, right out of the box :/
  1. Rubberized Paint???
    By Shin Pond Hunter in forum Bike and Frame discussion
    Last Post: 02-21-2014, 12:46 AM
  2. Replies: 9
    Last Post: 11-02-2013, 05:15 PM
  3. Peel me off this velcro seat...
    By baker in forum Riding Passion
    Last Post: 10-28-2012, 04:21 PM
  4. Frame Protector for Mach 5.7?
    By Lustful_Demon in forum Pivot Cycles
    Last Post: 05-17-2011, 08:03 AM
  5. Mach 4 build starting...
    By Gene46 in forum Pivot Cycles
    Last Post: 02-02-2011, 07:30 AM
