Pivot's warranty policy in action- Mtbr.com
Results 1 to 21 of 21
    Reputation: GhisalloWheels's Avatar
    Oct 2007
    Last week while cleaning my bike I discovered two cracks in the frame.
    One on the front triangle.
    And one on the rear triangle.
    I called Pivot and let them know of the problem. After several conversations it was decided that I needed to send in my frame. They were concerned about whether or not the aftermarket PUSHed shock was valved correctly and whether or not that contributed to the problem. I had called Darren at PUSH and he had volunteered to call them and talk with them if there ended up being a problem with the warranty being honored.
    I communicated with Brien at Pivot. He did a great job with prompt and professional communications. I'm not sure if Pivot ever talked with Darren, but I received my bike back with a new front and rear triangle. Thanks.
    I did notice one small change in the frame. It seems they have reinforced the part of the front triangle that cracked on mine.
    Anyways. I was impressed with Pivot and how they handled the situation. But I will be leery about putting an aftermarket shock on my bike from here on out. If I decide to get another aftermarket shock, I'll make sure to get an email confirmation that a particular shock will not void the warranty.
    Cycle tracks will abound in Utopia. ~H.G. Wells
    Professional Slacker
    Good to hear, what was the turnaround time?
    Oct 2007
    Quick. It was sent out last Thurs and it returned to the shop on Weds.
    Trying to be helpful
    Reputation: Guy.Ford's Avatar
    AWESOME!!! Congrats man, glad to hear no drama!!! Now build it up and pics pleez.
    The OMEN
    Reputation: Prodigy's Avatar
    Wow Thats great service.
    (now to go check my frame)
    Pivoteer
    Reputation: tiSS'er's Avatar
    Good to hear they replaced your frame. The PUSH thing is just rediculous though.
    Employed by Pivot Cycles - www.pivotcycles.com
    Black Lion
    Reputation: yogreg's Avatar
    Quote Originally Posted by tiSS'er
    beyond ridiculous !!!!
    Voltron
    Oct 2007
    Quote Originally Posted by yogreg
    I felt the same way at first. However, I can understand them wanting to test the setup of the shock themselves. To take others word on how it was valved, might not be too wise. In the end they honored the warranty and I am a happy rider.
    Let'er Buck
    Reputation: kdimon's Avatar
    Good to hear they took care of you, I have been nothing short of impressed in any dealings I have had with pivot.
    "Powder River, Let 'er Buck"
    Pivoteer
    I've heard that Pivot will not warranty any shocks outside of the spec'd Fox stuff. Any truth to this?
    Black Lion
    truth
    but what i think you mean to say is warranty frames that have used other than Fox spec'd shocks
    Voltron
    Pivoteer
    truth
    Ah yes, thanks for correcting me.
    Reputation: robertj's Avatar
    Feb 2005
    It was reported recently in another thread that along with Fox spec'd shocks, the CCDB is also ok to run, but not an Elka coil.
    Feb 2005
    Excellent customer service and turnaround, BTW.
    Quote Originally Posted by robertj
    Yeah I gotta say Pivot is a little more than confusing with this, you can't run anything other than Fox!!!! Oh yeah........except CCDB. Well I can tell you from experience you cant run a ROMIC or XFusion, also Elka according to the email I got from pivot.
    Reputation: seandm's Avatar
    Interesting. My old Mach 5 cracked in almost the same spot and I had a pushed shock as well. I often wondered if that was indeed the issue.
    Pivot replaced my frame as well with hardly any fuss.
    Reputation: gticlay's Avatar
    Quote Originally Posted by kdimon
    Plus one here. I like how Ken and Dan are on here answering questions.
    "It looks flexy"
    dog
    dog is offline
    sit! stay!
    Reputation: dog's Avatar
    Quote Originally Posted by gticlay
    heck yeah!!!
    i need to develop my crashing skills...
    change is good
    Sep 2004
    My 429 rear triangle cracked and Pivot replaced it promptly, although I had to purchase a new one. The main pivot bolt backed out and the frame is so stiff, I didn't notice it. It finally started creaking, and that's how I discovered it. Later the creaking returned and the crack in the rear triangle was the culprit. I couldn't refute their claim that the loose bolt led to the frame failure, especially since I have a habit of breaking frames. Man, I love this bike. It is the best bike I have ever owned. It has a magical combination of toughness, pedaling efficiency and stiffness. If even works well with different travel forks. Well worth the price.
    www.derbyrims.com
    Reputation: derby's Avatar
    A company can't blindly warranty their suspension bike using after sale shocks or forks they haven't tested.
    Pivot warranty is doing their job by wanting to inspect the bike. Maybe the shock was rubbing, maybe bottoming harshly. Damage from those two examples while using and aftermarket shock or fork are abuse and technically would not be covered the way a warranty is written, to guarantee against manufacturing defects for a limited time.
    However, they may settle upon replacing an abused broken frame if the public relations cost would be more than the cost of the frame replacement.
    (I'm not saying the OP's frame was abused. It probably wasn't abused by a PUSH tuned shock)
    Just my opinion.
    In fact a good friend and a very strong rider has cracked two Mach 4 frames (with OEM shock) and Pivot replaced both swingarms quickly. Excellent customer service.
    Oct 2007
    Quote Originally Posted by derby
    Just my opinion.
    I agree. However, I think it would be in everyone's interest if there was some clarity on the webpage about the issue.
