429 axle backing out- Mtbr.com
Results 1 to 14 of 14
    May 2014
    I have been riding my 2018 Mach 429 trail for several years without any issues until last week. I was riding and noticed my shifting went from good to terrible within 10 miles. I got off the bike for a quick look and saw the rear axle had started to backout. I screwed in tight and all was good.
    Now I am checking the axle every 5 miles which is annoying. Any thoughts on why all of the sudden this is a issue?
    Hardmix
    Jan 2016
    Have not had an issue over the years----is it a one time deal that who knows what caused or is it happening again ?
    Nor experienced it myself. However perhaps a dab of locitite will help?
    Sent from my HD1900 using Tapatalk
    David '09 YETI 575 '91 GT Zaskar #2010 '97 Bully Piston '90 Klein Quantum
    change is good
    Sep 2004
    Quote Originally Posted by Hardmix View Post
    Hardmix
    It just happens. It also happens on my Switchblade. I check every 2-4 months riding 4-5 times a week. No biggie. Just don’t over tighten it because getting the wheel off on the trail can be difficult.
    Sent from my iPad using Tapatalk Pro
    Reputation: joby's Avatar
    Hardmix
    I switched to one of these years ago:
    https://www.backcountry.com/shimano-...xoCRjcQAvD_BwE
    May 2014
    The axle continues to come loose. I am going to apply some locktite and see how that works. I find it strange after all this time/miles that this problem just now arises. It makes me think there could be another problem lurking in the shadows.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Those DTs have to be pretty damn tight IME. Usually tighter than you’d think. Otherwise they loosen on you.
    Jun 2019
    What problem do you imagine could be "lurking in the shadows?" How tight do you tighten the axle?
    change is good
    Sep 2004
    I wouldn’t locktite it. It’s slightly annoying, but infrequent. I do tighten the 429T more frequently than my Switchblade so I crank it down harder. The loosening of the axle was disconcerting at first, but I got over it.
    May 2014
    This just speculation on my part. It doesn’t make sense to me that the axle all of the sudden startS giving me problems.
    It has not come loose in the past 3 rides..go figure!
    Apr 2014
    Try greasing the axle bolt. You could have bad wheel bearings.
    May 2014
    I installed a new rear axle and hanger that I purchased from Pivot. On my first ride the axle started backing out. I guess I will take the bike to a lbs and see if they can figure this out.
    change is good
    Sep 2004
    Could put a lock washer on it. Or crank the hell out of it and carry a long handle Allen. Or my favorite, wipe the threads clean, put some sandy dirt on it, wipe it off and tighten. Or like you said, locktite it. Sometimes shite doesn’t want to stay tight. Like RaceFace cranks.....
    May 2014
    I received a good tip today, plumbers tape.
  1. Replies: 4
    Last Post: 06-02-2019, 07:41 PM
  2. Replies: 6
    Last Post: 09-08-2013, 02:16 PM
  3. BB92 bottom bracket backing out
    By Ltdan12a in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-03-2013, 08:54 AM
  4. ATAC XS spring pins backing out
    By fat_weasel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-26-2011, 09:38 PM
Members who have read this thread: 58
