Does it make sense to go from a DSLR setup to Mirrorless?- Mtbr.com
Results 1 to 68 of 68
    always licking the glass
    Reputation: stripes's Avatar
    Sep 2016
    After a non-biking trip and carting around 3 lenses and my DSLR for two weeks, I realized how much I like shooting with a nice camera over my phone. I'm not looking to upgrade my phone, but possibly change to a lighter camera setup.
    That said, does mirrorless camera make sense? I'm looking for:
    - Still the same functionality as my Canon 60D
    - The ability to switch to different lenses
    - Be lighter so I can actually carry it around more often, even possibly biking.
    I realize it's a bit of an investment, but before I even start going down the research of it of all, can someone who's done this give me the positives and negatives of doing this (other than the lighter part)? Thanks!
    Guerrilla Gravity BAMF, Colorado Front Range
    https://classifieds.mtbr.com/showpro...product=116154
    Young, Shawn Young
    Reputation: Redmon's Avatar
    There is no getting around that mirrorless is smaller. Weight savings? I guess to a degree until you start carrying multiple lenses. I had the Nikon d50 I think it was and went Sony mirrorless and never looked back. I have the a6000 and the a6500 with about 7 lenses and love it . Also I carry a Sony rx100mva in my top bar bag that has the same sensor as above and takes great pictures! If you want to carry the a6000 you can. Throw the very. Small Sony 35 on there and you have a very small set up that your happy with all day!
    Sent from my SM-G965U1 using Tapatalk
    "Im just going to explore a little bit..."
    Dont make me be the bad guy...
    Do I need a pass to ride this trail?
    Reputation: ocnLogan's Avatar
    Aug 2018
    I shoot with a Nikon D750 (full frame DSLR), but I only recently acquired it. I shot with a D7000 (crop sensor, similar to your 60D) for 6 years before that, but never took it biking (but have hiked on several multi-night trips with it).
    Mirror less is lighter... but not as much as you may think, if comparing apples to apples. The body is smaller, but many of the lenses have extra length to them (not all though). So depending on which mirrorless camera you are thinking, and which lenses, you may not save as much weight/bulk as you are thinking.
    Have you considered going micro 4/3? Itís a step below a crop sensor in sensor size, but still fairly large, and has a huge selection of lenses (since the standard is used by many manufactures, instead of just one).
    Full disclosure, Iíve never used a mirrorless ILC. But in my mind they have a few main advantages over a DSLR.
    No autofocus fine tune worries. A mirrorless always focuses exactly.
    WYSIWYG viewfinder. So what you see, in the viewfinder, is what the photo will look like so you donít have to check afterwards to see how exposed the photo is.
    Good at video.
    Wider autofocus area coverage than a DSLR (not always, but often).
    And a few negatives.
    Battery life
    Electronic viewfinder is imperfect, sometimes laggy
    Autofocus performance is not always up to the same level as DSLRs (though the high end ones now are very good. Just really depends on the model).
    And the ideal camera for you will likely depend on what you want to use the camera for.
    After a lot of research and thinking about it, I stuck with a DSLR (vs going mirrorless) when I upgraded to the d750, because I love long battery life, never take video, already had a lens or two that worked with it... and it worked with my version of Lightroom (pre-subscription version). Not sure if Iíd be ever cycle with it though, unless maybe if I was doing bike packing or something like that anyway.
    But mirrorless options are better than ever now. Just really depends on what youíre looking for.
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Mirrorless is ideal for outdoor use, much smaller gear bag, still enough weight to produce good sharp images. I use an a5000 primarily, great images, tough as my impact driver, battered but not broken, utterly reliable, a digital shrunken M Leica.
    Do you use Photoshop for editing?
    I ride with the best dogs.
    Reputation: johnnyspoke's Avatar
    camera size is a website I've found handy. For instance, here's what your 60d would look like with attached 18-135mm lens, vs a M6 mark ii with 18-150mm lens. *************/37R1pQx
    HTML Code:
    Ok, so sorry, I can't figure out how to attach a link. Anyway, camerasize.com Look for the tab cameras with lenses, and play to your hearts content.
    I'm looking forward to regretting this.......
    Aug 2018
    The camera body of a mirrorless camera is always going to have the ability to be smaller (it doesn't have a mirror box), there is no way "around" that. And on the camera forums out there, this has been a topic of hot debate for years and years. Plenty of articles/forum posts out there if you want to dig deeper into that.
    But basically, lenses for any given sensor size, will always need to be fairly similar in size, because its the size of the image circle (and the aperture) that determines most of the lens size, not the size of the body it connects to.
    That said, in some cases, the shorter potential mounting distance of the mirrorless does allow for a different optical design technique, making for smaller lenses (wide angle lenses only AFAIK).
    So if depending on how many lenses you carry, and what type they are, the total system weight/size may not be all that much different.
    A flip side to the smaller physical size, is often times mirrorless cameras have less physical places for buttons, and are smaller/slipperier to hold, especially if wet. This is primarily an issue with larger lenses (large aperture telephoto lenses) that are weighty. Just because it gives the camera/lens setup an unbalanced weight distribution. Most smaller cameras are harder to use with gloves too (again, probably not an issue, but some people care a lot about that).
    Anyway, just pointing out that while there are clear differences, its not quite as clear cut as "mirrorless is better". Like most things, its better at some things, and not as good at others.
    If you're looking for smaller/lighter kit, the easiest way to do it is to shrink the sensor size. Because that shrinks the required size of lenses, and everything else.
    I'd seriously consider the Panisonic GX85 (or similar micro 4:3 camera) if you're looking for a small ILC (Interchangeable Lens Camera).
    https://www.amazon.com/PANASONIC-12-...2569274&sr=8-3
    It is listed in DPReviews most recent "Best bargain cameras of 2020" list as well. You can find a link there to their full review if you're interested.
    https://www.dpreview.com/reviews/buy...-bargains#gx85
    And here is a useful tool comparing sizes of cameras and lenses. You can see how much smaller the GX85 is than your 60D.
    https://camerasize.com/compare/#100,673
    Anyway, good luck with whatever you do .
    Reputation: chrisx's Avatar
    Nikon Z mirrorless looks the best to me.
    https://www.nikonusa.com/en/nikon-pr.../overview.page
    They have been out for a while now, so it should be about time for a sale of some kind.
    Be sure to get the lens adaptor so you can use over 300 Nikor lenses, while you wait for and save up for the newest Z line lens.
    I will get mine before to much longer.
    Best part of their sales pitch,
    weatherproof and robust.
    A couple of things to consider;
    Weatherproofing. This is a mt bike forum, not a photos out the window of a Cadillac forum.
    Sensor size. Bigger sensors take better pictures, for a price.
    Lens compatibility. Camera lenses are not universal. If you buy a Fuji camera body, you will be buying Fugi lenses. Nikon Body? = Nikor lenses. Get it?
    Choose your brand carefully. You get to expand on that brand for years to come.
    Lens adapters do exist, and have a down side as well as an up side.
    I resisted and thought about it long enough. Nikon Z is in the near future for me.
    Aug 2018
    Quote Originally Posted by chrisx View Post
    I can confirm weatherproofing being useful, even if you're not necessarily buying a camera exclusively for mountain biking photos. It really does bring some peace and mind.
    This last summer I hiked 35 miles of the "wonderland" trail around Mt Rainier. Three days/4 nights of hiking, and it rained ~75% of the time (including the entirety of at least one 12hr day of hiking).
    I carried my D7000 in my hand/around my neck for almost the entirety of the trip (I did put i in my pack a few times during more intense rain periods a few times). The D7000 has weather sealing, and while it got rained on a lot, it never once had a problem.
    Thats a more extreme example (4 days of constant rain, being out in the open, and stored wet). But its also come in handy shooting portraits of friends/family (a cloudburst when out at the park/etc).
    And I nearly went for the Z series. Its wonderful... but the lenses are very expensive right now. I went for an older DSLR, as it let me reuse my current SD cards, a lens or two, and not need to pay for a new editing program. But the next one after this one might be mirrorless.
    Anecdotally, the camera I HAVE carried with my on a few rides, has been my Panasonic ZS100. Its a 1in sensor non interchangeable lens camera. But it is very compact, has a 25-250mm equivalent lens, thats F2.8 -5.6, and has very accessible manual controls. If the Micro 4/3 cameras are still too large for the OP, this might be another type of camera to consider.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    The only real drawback to modern mirrorless is the investment.
    If you can afford it, do it.
    Jan 2019
    no more Canon EF mount lenses
    Quote Originally Posted by stripes View Post
    Keep in mind that Canon announced recently they will no longer be releasing EF mount lenses, the ones found on their DSLR bodies like 5D4, 1DX3, i don't think that means EF-S lenses on crop bodies like the 60D, but Canon and any major player has made the move to mirrorless. Eventually Canon crop system DSLR's might go away too, or at least get smaller. Nikon ditched 1/3 of its line up in DSLR cameras to mirrorless as well, hoping to bring back some much lost ground financially in their camera business. Mirrorless, It is where the companies are now spending the majority of their money and effort developing imaging tools.
    Sony ILC's like the A6400 is a really good compact aps-c format with excellent image quality, even their full frame bodies are smaller than some micro 4/3 cameras. You could consider this.....rent a camera and a few lenses from Lenserentals.com or borrowlenses.com and see what mirrorless is like.
    Quote Originally Posted by mikesee View Post
    All full frame cameras are to expensive.
    A plan for the next ten or fifteen years is what a person needs. Choose carefully the brand and type of camera you want.
    Me. As I grow older I will spend less time riding my bicycle for weeks in the desert, or getting rained on in the pnw. And more time walking the hills of nw Wyoming, like I did as a child.
    Nikon mirrorless sounds like what I need to photograph animals around Clouds Home, Wy.
    Keep in mind where you travel to vs how much you spend.
    I am in Barranquilla Colombia. Home of the world's second largest carnaval. An industrial port town where cocaine is expensive and wages are low. (I drink water and smoke nothing at all.) I still have the rx100v I paid $900 and something for. I got a couple of bruises holding onto it with both hands as tight as I could. I stopped taking pictures of the parades and only take pictures of my little friend Venezolana Nikky the last few days.
    Jan 2019
    Full frame is expensive, but like most things, you get what you pay for. If you want the best IQ, nothing beats full frame. Does crop have good IQ? Yes if executed well they can deliver the goods. Though Nikon might work for you, there are good and better choices out there depending on what a person wants or needs.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    I'm still going strong with a Nikon D5600 DSLR. It is quite small (especially when I go out with just a prime lens). Also, the newer/lighter kit lenses have a lock position which is kina nice particularly on some of the rocky/rooty trails I ride.
    If I go mirrorless, it is definitely going to be a Fuji XT-4
    【ツ】 eDub 【ツ】
    Aug 2003
    Quote Originally Posted by DeeGeeCee View Post
    Acceptable until you're talking low light, and then crop isn't even close to full frame.
    Aug 2018
    As Mike said, that is basically true. To be more specific, a full frame sensor should always have ~1 stop better low light performance, as the sensor is twice the size of a crop sensor.
    The other factor though, is that it kind of depends on which generation of sensors we're talking about though. As newer sensors have better high ISO performance than old sensors.
    But if you're talking roughly the same generation, then full frame will pretty much always be better. And this is assuming you're using the same aperature lenses on both cameras.
    Also, for reference, a Micro 4/3 camera should be almost another stop worse than the crop sensors (its 30% smaller than a crop sensor). But its still 9 times larger than what you'd get with your stereotypical point and shoot camera/phone.
    If you look at the reviews on DPreview.com, they have a test scene they shoot with every camera. They let you do side by side comparisons with a bunch of different models all at once, at either the same, or different ISO values.
    https://www.dpreview.com/reviews/nikon-d780-review/6
    The list of cameras in the tool isn't exhaustive, but its pretty good. You can easily compare a 70D(cannon crop sensor), to a micro 4/3 camera , and modern full frame pretty easily.
    Care to elaborate on that?
    But kindly read what Logan posted first?
    Quote Originally Posted by ocnLogan View Post
    Aug 2018
    I would assume that DeeGeeCee is just mentioning that what is important to you/I, may not be whats important to any other person. And maybe not just weather sealing, but I read that comment as mentioning other features as well.
    Weather sealing is something I'll look for in any ILC camera moving forward (personally), but if I still lived in CA/AZ... that may not be as much of a priority.
    I've been looking through my photos of that trip, trying to find some that do justice to how much rain/water there was... and its not working out. I wasn't taking as many photos in the truely wet bits (I carried it close to my chest, almost under where my baseball hat was, trying to minimize the water contact... as even though its weather sealed... it felt prudent to at least try to take care of it).
    Also, as I was the only person really taking photos... there aren't really any photos of me where you can see me holding the camera.
    Here is one photo from the trip I was fairly happy with though.
    It is a bit out of focus :/. But it turns out, if you round a corner, and then suddenly see a full grown bear 50ft in front of you, your hands aren't as steady as they typically are :/ (or, at least mine weren't). The next shot was technically better, but the bear looks much better in this one.
    Reputation: Klainmeister's Avatar
    I'll chime in here:
    I used to shoot Large Format and Medium Format film (still do sometimes) and bought a D750 when it first came out and used it for a while. I eventually bought a Panasonic GX8 for travel reasons and really fell in love with the M43 format despite coming from the larger formats.
    Currently I use a Panasonic G9 with 7-14mm F4, 12-35mm F2.8, and 35-100mm F2.8. Benefits of this setup are: insanely fast FPS (both the 6k hybrid mode as well as e-shutter and lastly mechanical shutter), weather sealing, roughly 6 stops of stabilization, and people tracking continous autofocus. The size difference between a M43 35-100 F2.8 and a Nikon 70-200mm F2.8 is comical. I can carry the body + 2 lenses for the weight of just one of the FF lenses.
    Downsides: less subject seperation and poor low-light performance. Realistically, these aren't issues I find when riding/shooting, but they are worth noting.
    There's always pixel-peepers that will crap on anything M43, but in real life situations with good glass its a non-issue. I carry a camera more, which yields more pictures and being able to shoot a meaningful 2.8 vs stopping down to 5.6 because the subject is too thin is very useful.
    Here's a gallery of shots, 95% G9 or GX8: Mountain Biking - Kyle Klain Photography
    Quote Originally Posted by Klainmeister View Post
    Here's a gallery of shots, 95% G9 [/url]
    Sensor Size 17.3 x 13 mm
    Good shots, worth a click.
    As far as ,
    Could be different from one mind to another.
    With delusions of grandeur, wanting to see a 5 foot tall photo of mine on a wall somewhere. I clicked medium format mirrorless.
    100 megapixels, 150 megapixels. man oh man.
    About the price of a Dodge pickup truck.,
    Then I dropped a nickel on the ground and bent over to pick it up.
    https://www.youtube.com/watch?v=bKxodgpyGec
    Change in my pocket wasn't enough
    Jan 2019
    Nikon is not for everyone, anymore than Sony, Canon, Panasonic, Olympus, Fuji and so on are. Sony works for me quite well, Olympus and Panasonic did not work out, Canon was ok, i rented and tried out both Fuji and Nikon before jumping to Sony. It is just a matter of ones needs. Everyone's needs are as different as the cameras themselves. Thats all i am saying. Do a decent amount of research before buying and you will end up with something good.
    Yep, horses for courses. If i'm riding something properly technical like TWE or our local Rio en Medio trail, I'm carrying something small and light. Big glass can be a big PIA.
    OTH, also considering a A7R III with a few primes -- FF and hi-res with fast glass. Now that could work! But the entry price is pretty ridiculous.
    Rent if you can, sometimes ergonimics play a bigger role than most like to admit as well.
    Aug 2003
    I'm mirrorless curious, but I'll never go back to crop.
    I may only shoot a ~dozen of these per year, but you simply don't get this kind of detail with crop, regardless of lens.
    Attached Thumbnails Attached Thumbnails Does it make sense to go from a DSLR setup to Mirrorless?-8a3a5167.jpg
    Does it make sense to go from a DSLR setup to Mirrorless?-screen-shot-2019-12-19-7.23.49-pm.jpg
    saddlemeat
    Aug 2003
    Awesome comments above, I too am looking to dip a toe into FX waters. I'll start with a used A7xx that can clunk around the mountain with me, nothing too nice, which adapts to my crop lenses, then start acquiring some primes. I like 'em wide and it's all about the lenses. I'm a print maker too, no such thing as too big of a file in my world.
    Reputation: Mudguard's Avatar
    I bought the Sony A6600 yesterday, a step up from my RX100IV, which has been brilliant once you navigate Sony's horrible menus.
    Jul 2016
    The Sony A73 is an amazing camera. I have carried it at some very important events ,for me, with a 50 F1.8 and have not regretted it. You figure out how to work around the menu's. The Nikon sits, unless the lights come on and they start passing a football.
    The thing about using adaptors:
    They change the number of mm the glass is from the sensor.
    If a lens was made to be 7 millimeters from the sensor or mirror and you use an adaptor it might now be 11 or 13 mm from the sensor. people argue about the pros and cons for hours on end. Cons do exist with a non native lens.
    I recently learned that a crop lens only uses 44% of a full frame sensor. Few threads down this page is where I learned that.
    In for a penny in for a pound. Must be an old saying from waaaay back when a penny could buy something.
    ďthe best camera is the one you have with you,Ē and we truly believe that.
    https://www.creativelive.com/blog/us...aphy-settings/
    If I google best night camera, Nikon pops up most everywhere.
    Click here for a while
    https://www.dxomark.com/Lenses/
    Aug 2018
    Thatís true about adapters, to a point.
    One of the reasons that the new Nikon Z mount is interesting, to native flange distance is very short. This means you can adapt almost anything hung to it, as there is enough space for the adapter, and make sure the adapted lens stays at its native ďlens to sensorĒ distance. Sonyís full frame mount is somewhat similar (just not as much space for adapters).
    And full frame sensors are designed around a known standard size (same as a 35mm piece of film). But crop sensors arenít the same way, so each brand is going to be a slightly different percentage of full frames sensor size. Offhand I recall that cannons crop sensors are smaller than nikons (1.6 crop factor vs 1.5). I canít recall any others at the moment, but they were all in the same basic area of 40-50% of the size.
    And again, itís primarily sensor size that determines lens sizes (at a given aperture/focal length). So mirrorless or DSLR, if youíre carrying a bunch of lenses, the overall difference in kit weight isnít huge usually. The actual camera itself comes down to what is most important to you, as both mirrorless and dslrs have their pros and cons (just like bikes ).
    Jan 2019
    A73 and A7R3
    A73 Balloon shot at 5000 ISO, A7R Sunrise at 50 ISO. Both shot with the same lens, Sony GM 16-35 f 2.8.
    Just backs up what you said Mikesee.
    Attached Thumbnails Attached Thumbnails Does it make sense to go from a DSLR setup to Mirrorless?-a7r00687-copy.jpg
    Pale in comparison to the above star photos.
    rx100v
    A 1 inch sensor (13 x 12 mm), does not do well at a high iso or capture a lot of details at night.
    I seldom turn it up past iso 250.
    Some things just work better than others.
    This is what tips the scale in favor of Nikon.
    I mean other than the weather proofing.
    While other brands come out with a new lens to camera interface all to often.
    Nikon has a corporate policy.
    True to the lens.
    If you paid way to much for a Nikor lens every few years, You can still use them on your new Nikon 850 Camera, or whatever the latest and greatest is when the time comes.
    Most if not all other major camera makers switch things around,
    the same way a 12 speed cassette does not fit your old bicycle. You need a whole new setup to switch to modern. ... .
    If you buy the z6, and a lens once a year for the next five or eight years, when it comes time to buy a z17 or whatever the latest and greatest is in 2029, Nikon is the only safe bet to still be using the same lens to camera interface. Other brands change the interface and you need all new lenses because the adaptor, well, is less than perfect.
    Nikon did not switch the interface until they removed the mirror from the camera.
    Looking to the future,
    Mirrorless will leave the single-lens reflex camera sitting next to the 26er.
    Don't get me wrong, I still ride my 26er, but my 29er is better for a number of reasons and most of the time.
    Does it make sense to go from a DSLR setup to Mirrorless?!
    Depends how much you like photography? Not a cheap hobby.
    All modern cameras take better pictures than the older models.
    Switching to full frame requires a strategy and plans for the future.
    Itīs your money.
    Most any late model camera can print out a 8 x 10 good enough.
    On a quiet street where old ghosts meet
    I see her walking now
    Away from me so hurriedly
    My reason must allow
    That I had loved not as I should
    https://www.youtube.com/watch?v=Dobt...8P_HoP&index=7
    There are other ways to spend all your money besides cameras.
    If you want to walk with Venezolana on a quiet street you need an airplane ticket to South America.
    The modern world has changed. Do all the electronic gadgets make us happy or keep us from happiness?
    Same Mayan girl 5 years ago.
    Five years ago she and her grandmother made belts and sold them in the park. She smiled at you until you bought one. No phone.
    Today she sells bags made in China. Maya chino. Few people know she ordered them on her phone. She doesn't smile anymore. Beep beep beep all day every day.
    Jun 2017
    lmfao @ "mirrorless is smaller and lighter"
    i mean, if i switch to the 10-18 lens, maybe =)
    granted, i went from a crop body (80d) to full frame (eos r), so not truly apples to apples
    rambling aside, size is the absolute last reason i went mirrorless. hell, the body now rocks the bg-e22 battery grip full tine as well, so if anything, i despise smaller camera bodies.
    Attached Thumbnails Attached Thumbnails Does it make sense to go from a DSLR setup to Mirrorless?-20191023_160435-01.jpg
    Jan 2019
    I bought a Leica SL last year, so my answer is "Yes mirrorless is worth it."
    And the comments about full frame sensors costing more but giving better results is also true.
    The comments about lens being more heavy for a mirrorless body aren't necessarily accurate, it depends on which lenses you buy.
    The bottom line is and the correct answer depends upon the person behind the camera. Only you can say if the upgrade is worth the cost.
    My advice, don't shop based upon pixel count. More pixels do not equal better pictures. Large pixels offer advantages over small pixels. Many pros feel the large pixels render the image as more natural while more pixels may offer more digital data, but also, more digital noise as well. Similar to the cd vs vinyl debates.
    Go to the Leica forum and read the comparisons there. Every possible comparison has been made along with experiments using non native lenses so you can see what really works and what doesn't. Even though it is a Leica based and funded forum, the comparisons are genuine and many guys have other brands for traveling on Safari and other places that you may not want to carry $20,000 or $30,000 worth of gear due to security issues.
    There are great options out there, you just need to be open minded and educate yourself and avoid the marketing biases that exist.
    Quote Originally Posted by A/C in Az View Post
    Got a link to the Leica forum?
    Seems there exists more than one forum talking about Leica cameras.
    I just looked up what that camera costs here in New Zealand. Not sure I'd be putting that in my Camelbak!!
    Aug 2018
    Anything Leica is going to be pretty pricey, itís just kind of how it works.
    For me, mirrorless vs dslr is mostly down to which pros and cons you want to live with. Price, bulk, battery life, image fine tune, etc. Pick whatever works for you and your budget.
    And then sensor size I choose to take on a specific outing is dependent on what Iím doing. If Iím going on the trip explicitly to take photos, then the big sensor, and nice glass are coming out, weight and bulk is a secondary concern. If Iím going out and just going to be taking Incidental photos, then a more compact camera is coming.
    My Panasonic ZS100 is easy to carry along, and is good enough quality to share online, or print in reasonable sizes (in good light). Iíd also seriously consider a micro 4:3 like the Panasonic GX85 for the same use case if I wanted to change lenses. Doesnít hurt that it is available with a lens for under $400 iirc.
    Lenses are the biggest difference, it's hugely important, especially considering 2.8 is 2.8 no matter. Here's a direct comparison of the difference between the G9 and D750 with the same lens (as in focal length, f stop). Hence taking the G9 is much easier.
    Aug 2018
    Just wanting to make sure something is clear here with the comparison photo.
    The image is comparing lenses of similar equivalent focal length and F stop, for different sensor sizes. Meaning, the difference you see in the lens sizes is due to how large the lens must make the image circle, not due to the fact that one is mirrorless and the other is a DSLR.
    As I said before, lenses for DSLRs and mirrorless cameras are mostly equivalent in size, as long as youíre comparing the same sensor size, focal length and aperture. Meaning, you donít see a huge difference in the size of lenses between the two types. There are some exceptions to this (mostly wide angle lenses where mirrorless cameras I allow a different design to be used for the lens), but itís a pretty good rule of thumb, and its really just down to the physics of getting enough light in for the sensor.
    Some links showing what I'm talking about. For the record... this is a pain in the butt. MTBR destroys the links that camerasize generates, no matter how I link it.
    Like this.
    *************/2VMkpNp
    So I had to manually screenshot/save/upload .
    Sony A7 RIV (full frame mirrorless) vs Nikon D750 (full frame DSLR), both with their 12-24mm F4 native lenses.
    Same cameras, with their native 85mm F1.8 lenses.
    Now both with their native 70-200 F2.8 lenses.
    As you can see, the lenses themselves are pretty equivalent in size, because the light required to cover the sensor is the same, as its the same size sensor for both cameras. There are differences from lens to lens, so its not 100% equivalent for any comparison you care to make, but overall, they are very similar in size IMO. Which is why I say that if you're carrying multiple lenses, the size advantage of mirrorless camera bodies really isn't a big deal in most circumstances.
    However, once you start changing sensor size, you do start seeing dramatic differences in the size of lenses, like the comparison between the Panasonic G9, and the Nikon D750 shown in the post above. Because a 2.8 lens is a 2.8 lens, as mentioned. Itís just that a full frame lens needs to collect 4x more light, to create an image circle big enough to cover its 2x larger sensor with the same F2.8. So naturally itís lens is dramatically larger.
    Which is why many of us keep saying If the purpose is to drop the size/weight of the kit youíre carrying around, then the easiest way to do that, is to drop sensor size.
    A micro 4:3 camera like the G9/GX85 is a great compromise. You still get a wide array of lenses to choose from, and good image quality, with a much smaller and lighter load to carry with you. It just comes with some loss of image quality (mostly in low, to extremely low light conditions), and most (all?) happen to be mirrorless cameras, which may be a pro, or con, depending on your preferences/viewpoints.
    Attached Thumbnails Attached Thumbnails Does it make sense to go from a DSLR setup to Mirrorless?-12-24.png
    That's my only problem with the Z series, the flange distance kinda negates the smaller possible lens size, so you end up with pretty darn large primes, even though it's mirrorless. They're twice the size of comparable Sony FE.
    Loud tyres save lives
    Jul 2013
    I find like for like mirrorless setups don't tend to be a significant weight or size saving and some of the lenses that look smaller are because they're a dimmer aperture like a 24-70/4 rather than a 24-70/2.8. There are some compact setups but it's usually from a non like for like build but definitely possible depending on what's needed.
    The main reason I feel for going mirrorless is for the capabilities as they have great video which is more convenient than a DSLR, better liveview and increasingly impressive burst speeds and AF performance with Sony's A9 series offering ridiculous speeds.
    I did like the 1in based Sony RX100 series cameras for my carry around camera but a couple of years ago picked up the Sony RX1r. It is old these days, lacks IS and decent video but it's fairly small overall and one of the smallest FF cameras, the 35mm F2 is sharp and the sensor is still good for dynamic range and high iso as well as usable shallow DoF.
    2014 Trek Fuel Ex 8
    2015 Trek Farley 6
    2016 Trek Stache 7
    saddlemeat
    Aug 2003
    Just because you can go big doesn't mean you have to, be like Galen Rowel. If you need more detail there's always medium format, which stunts FX. It's about the picture... who makes big prints anymore anyhow?
    edit:
    I carry Sony a 16/2.8 and 55-210/4.5-6.3 OSS with my apsc a5000. Lots of bang for the package size.
    Most of my prints are 13x19 or less, anything larger doesn't sell. Few have much wall space it seems.
    Photoshop skills can be a significant part of the gear package.
    Reputation: Hulka's Avatar
    Dec 2013
    I have recently ditched my faithful 7D after 10 years and purchased and EOS R. Camera is lighter, smaller by a smidge. Once you attach the 28-70 RF lens it is a beast. The 70-200 is a little lighter but my not be the focal length you want. It takes great pictures and the detail the RF lensís captures is amazing but the RF lens are pricey.
    No one mentioned it but why not rent a 28-300 lens and try it? Covers a bunch of the focal lengths of a few lenses. Downfall is f stop changes at longer focal lengths and pricey.
    Sent from my iPad using Tapatalk Pro
    Jul 2013
    Quote Originally Posted by bsieb View Post
    It's curious I see this assumption all the time that the only reason to go for a larger format sensor is to print large, while this can be an advantage of larger format sensors there are many other advantages which are what people do buy FF sensors for particularly dynamic range and high iso. Medium format does offer better detail and dynamic range but still relatively niche and sensor development and general practicality lag behind FF, you won't find anything in medium format (or currently APS-C) which can match the likes of the stacked sensor in the A9 or the insane iso 102,400 in the S series.
    2014 Trek Fuel Ex 8
    2015 Trek Farley 6
    2016 Trek Stache 7
    Aug 2003
    Very few.
    But they're so much more preferable to smaller!
    Attached Thumbnails Attached Thumbnails Does it make sense to go from a DSLR setup to Mirrorless?-img_0578.jpg
    Aug 2018
    Quote Originally Posted by JohnMcL7 View Post
    The IQ advantages of a FF sensor are more apparent under close observation, and often (not always), FF has more megapixels, making it more ideal for larger display anyway. Usually close observation is "pixel peeping", but also happens when printing large, and usually most apparent when you were shooting in poor light (high ISO noise usually shows up the most in deep shadows).
    My purpose for going to FF was for low light, and depth of field. I tend to shoot mostly candid portraits (going to family reunions and just walking around getting photos of kids/siblings/etc), and the family reunions official photos. Both of which benefit from those traits.
    Beautiful photos Mike .
    I've just barely started printing stuff as I finally have a house, and we can use the stockpile of old photos we took to start decorating. I usually just wait and print when I see that mpix has a good 25-50% off sale.
    This is my biggest print at the moment. I have a 20x30" of this waiting on me to make a frame. Shot with a 16MP, 10 year old D7000. Viewed up close, its not quite as crisp as I'd like, but no one other than me (or maybe a DPReview pixel peeper) will ever really notice/care.
    This is a good thing!
    The larger opening lets in more light!
    Nikon says
    ®wider than any full-frame mount available (as of 8/23/18).
    NIKKOR Z lenses are able to deliver improved low-light performance and edge-to-edge detail in both stills and video®
    https://www.nikonusa.com/en/learn-an...nt-system.html
    This is a good thing.
    If I order a 240 hub from componets de it costs a lot less than it does at the lbs. $426 vs 200.84Ä. A Tubus Airy rack is $260 vs 116.81Ä direct from Germany.
    Are Leica cameras the same_? Anybody know a German camera vendor to find out? If a $7,000 camera cost 3,500Ä in Gremany, you have enough money left over to Visit Berlin.
    Ask your self a question. When was the last time I made a print? How big are the prints I make? If you made a couple of 4 x 6 prints last year. You do not need a full frame camera. A 1 inch sensor prints nice clear photos at 6 x 8 inches, but at 12 x 16 inches a person might notice a slight decline in quality. For large prints you need a large sensor.
    Someone might care about the quality of a print?
    I recently sold my m4/3 (Olympus OM-D E-M1) setup to buy a used D750. The E-M1 was probably good for biking, but I wasn't about to go carrying around a pricey camera and lens like that while i'm out biking. It was a pretty light setup for the pictures it could produce, but in the end it wasn't that small and the pictures weren't that much better than what I can get out of my cell phone (Pixel 3), and I sure didn't need the extra weight in my backpack. And nevermind what would happen to it in a crash...
    I really hated the low light performance of the m4/3 as well, which isn't going to be as much of a problem with a mirrorless. Watching my camera hunt for focus repeatedly while trying to get a picture of my daughter on Santa's lap made me unreasonably angry.
    The D750 is a bigger camera with many of my lenses, but actually still respectably small with some others. For example my Nikon 50mm 1.8g (~$150) makes the entire camera hardly any bigger than my E-M1, and I can always crop to make up for some of the zoom it's missing.
    Anyways, you guys keep buying mirroless and I'll just keep snapping up these cheap used FF lenses. I'm having fun.
    saddlemeat
    Aug 2003
    Very few.
    You have an enviable amount of wall space, nicely done.
    Is this your gear room?
    saddlemeat
    Aug 2003
    Nikon says
    Lol... so only FX shooters care about the quality of a print? That's the realm of gear geeks who can't make it on their images, usually. Lots more to quality prints than pixel or dot count.
    Aug 2003
    It's the front half of my shop. Ostensibly the "sales floor" or retail area, but because most of my business is online I've never had a use for that ~400 sq feet. Sat empty and unfinished for years before I had the 'aha!' moment to finish it out as such.
    Actually, I was thinking Magdalena's grandmother might care about the quality of the print. When she finally gets it 49 weeks after I took it. And no, there is no print shop with a machine made this century within a 100 miles of her house.
    I was told that the white straw caused the camera to over compensate and make her face to dark.
    Yep, since I did not know that, I have to buy a better camera with a bigger sensor to hide my mistakes.
    Aug 2003
    I wonder how long ago the OP checked out of this gear-sturbation.
    Nov 2019
    Iím just here for the gear-sturbation party.
    Iím just excited for mirrorless 300mm/400mm F2.8 lenses to come out so I can buy F2.8 lenses for cheap.
    I had to find an old card with a photo of stars.
    Because I gave up on the idea of star photos with a 1 inch sensor.
    iso 1600 and 30 seconds. hard to tell the difference between stars and noise.
    If you want better night photos you might have to pay for a better camera.
    Did he say to dream on
    or
    dream until your dreams come true?
    https://www.youtube.com/watch?v=sHCt...rt_radio=1&t=0
    The fiddle player don't stop playing after dark. You might stop taking his picture after dark depending on which camera you have though.
    OP asked is it worth it?
    The answer is,
    how much do like photography?
    To answer your question Chris, my typical commissioned prints are between 18-42" longest edge. Last year the largest print I produced was 90" long edge. I print probably 30-60 a year depending.
    I've never once had someone question the camera that created the image, which I think underscores the difference between pixel-peepers and real, on the wall prints. That, and learning various photo software is probably worth 10x any gear acquisition!
    Either way, hard to go wrong with any camera these days. IBIS and video quality, if you're a hybrid shooter, really narrows the list. If you need low-light, get fast glass, if you need zoom, get a better higher-iso camera to compliment the lower f-stop. It's all compromises.
    He is not the only one saying that.
    Aug 2018
    At the extremes of low light, sensor size, ISO perf (almost the same as sensor generation, as newer sensors are usually much better), and lens aperture really do make a huge difference.
    If the OP is wanting to do Astrophotography, take candid portraits of musicians playing in jazz clubs, photos of actors in plays, or athletes playing night/interior sports, then a full frame sensor (or larger), and some nice fast primes are in order.
    A full frame sensor camera with the same aperture lens, will have at stop advantage over a crop sensor, and a 2 stop advantage over a Micro 4/3 camera. That can make the difference between getting/not getting a shot in those conditions, and it is why most pros use them in those situations.
    As light gets better (more available), and the speed of movement goes down the amount of gear it takes to get a good quality (non-noisy or motion blurred) photo goes down.
    Most cameras (including phones) these days take pretty good photos in good light of non moving subjects.
    Its the "in between" where its not amazing full sunlight, and "its almost black in here" where you get to decide how much you want to spend, and/or carry to get the quality of photos you're comfortable with.
    In my experience so far, sharp photos worth printing have more to do with technique and setup than sensor size. Its just that larger sensors can help you capture shots you may not be able to get at acceptable quality levels with other gear.
    To each their own of course though .
    Maybe I am trying to convince myself to buy something I really can not afford but want. Am I the only one who waits for a storm so I can set my camera on old phone box and stand in the rain holding an umbrella not over me, just over the camera?
    Or the only one who walks up the creek instead of the trail?
    Be careful what you wish for. When I said I wanted to take pictures of waterfalls, it rained, everyday for 10 days.
    https://www.youtube.com/watch?v=N4ltLp30KVs
    S hit; while I was typing this,
    "13 mins ago - President Trump said he would be suspending all travel from Europe for the next 30 days "
    We might be getting more time in the forest with our cameras than we bargained for! If this keeps up.
    Aug 2018
    Beautiful photos .
    I understand gear lust, and as I mentioned before, I did recently upgrade to a D750 (cheap full frame), so clearly Iím one to talk.
    But, both of those shots are easily done with a tripod, and a sensor of pretty much any size. Itís when youíre taking photos of similarly dark areas but with trying to capture the moving bits without blurring that the light advantage of big sensors start to help out.
    Beautiful photos .
    I understand gear lust,... .. ... D750 (cheap full frame), .
    My rx100 v1 slowly faded away, as is my rx100 v5 doing now. V1 lasted 3 years. The manual focus went, the auto focus slowly declined. Then one morning the screen was just fuzz like a 1938 tv screen.
    V5 has a much better autofocus than the v1. I hear that v7 is even better still. After 2 years, the pop up viewfinder has stopped working. The internal battery charger is fading. The non weather sealed Sony takes good pictures. But , may not be the best for a person that walks up creeks in the rainy season, or spends weeks cycling on gravel roads.
    I am reading the mirrorless thread because, well, soon the want will fade to need. Those little pocket cameras are not robust.
    My tunnel vision can only see the Nikon sales pitch of a robust weather sealed camera. They have a $1,000, $2,000, and $3,000 model to choose from. Naturally: I lust after the most expensive one.
    Gear lust. I walked into Best Buy with enough money in my pocket to buy the A7--- 42 pixel $3,000 camera, non weather sealed. I chickened out and bought the rx100v instead. With the $2,000 I still had in my pocket I bought some tickets for Peru, Colombia, etc. Could have been a better choice.
    As I read this I am also looking at some Vittoria Mezcal III G2.0 tires. And looking at Bikepacking Roots routes page.
    Wo, oh, what I want to know, how does the song go.
    What about the Nikon z8 with 61 mega pixels? should we be saving up for that one?
    How does the song go?
    https://www.youtube.com/watch?v=3SiURXMrVrc
    I typed that right Sixty one pixels just around the corner. Sounds better than a new bike.
    Nov 2013
    It comes down to priorities. My go to (almost)everyday carry has been m4/3. Of course its image quality does not match even the APS-C of my Canon, although the Olympus OMD M5 I just got is impressive. It also is proving the mirrorless development has matured enough where it gives up little to DSLR now. My previous m4/3 was a Panasonic GFX and it definitely suffered in comparison on many fronts. Mainly it was compact and light while maintaining pretty good IQ and control functions.
    The Olympus has closed up many of the gaps, the hybrid AF is excellent and fast now, although in tracking mode my Canon still beats the Oly. The electronic viewfinder resolution and rate is fast enough I hardly notice and is now good enough for me to use for action and my occasional whale watching. FPS on electronic mode is ludicrous, I do not run it at max rate, that buries my Canon. Even on mechanical I think it beats it.
    The in body IS on the Oly is also impressive, it seems to approach almost gimbal like levels.
    It also does some cleverness to get 50 mega pixel images for static shots using the sensor shift.
    Oh, and one of the reasons I went Oly was the weather sealing, I'm pretty sure dirt and moisture intrusion is what did my Panny in, it still works but control dials are all wonky and barely work.
    My go to for riding pics is Nikon AW1 with 1" sensor, IQ is decidedly medicore, manual control PIA and not really used. But the thing is built like a tank and works despite pouring rain, mud, snow, being tossed around, dropped, slammed in van door, crashed on.
    Jan 2019
    61 mp
    Depends on your needs vs wants. As far as 61 MP goes, I have shot with the 61 MP Sony A7R4, and chose the 42 MP A7R3. IMO, 61 MP is far overkill for most shooters except for the concerning professional photographers going for ultimate detail for clients needs, gallery sized prints, or massive cropping ability. If that is you, then go for it. But wait in 3 years and we will have 50+mp cameras everywhere.....maybe.
    Attached Thumbnails Attached Thumbnails Does it make sense to go from a DSLR setup to Mirrorless?-a7r01349-dci.jpg
    saddlemeat
    Aug 2003
    I think resolution is reaching the point where more is not necessarily better if it is not needed. From my perspective as a fine art printer, more detail is not always beneficial to an image from a visual perspective, and there are some practical real world size limits beyond which it's gets awkward and pricey, especially if it's not a permanent installation.
    On the other hand, I've never wished for less detail when editing an image, so at what point does more data, and the overhead that inevitably goes with it, get to be awkward for you, is the answer. I have a dear friend who is a published fine artist and career photography professor, who can use whatever gear he chooses, and he is using a Leica D-Lux as daily carry. Says it gives him everything he needs for his 24" Epson. https://www.amazon.com/Milan-Sklenar.../dp/0968236219
    Attached Thumbnails Attached Thumbnails Does it make sense to go from a DSLR setup to Mirrorless?-dscn3907.jpg
    Jan 2019
    exactly
    Exactly. I prefer the detail of the 42 MP A7riii, over my other cam the A7iii. But the lesser gets it done quite well at 24 mp. A decent apples to apples comparison.
    Reputation: UpTheAnte's Avatar
    Mar 2018
    Does it make sense to go from a DSLR setup to Mirrorless?-14f8b685-9c54-403d-8d2d-4cb7547259fe.jpgDoes it make sense to go from a DSLR setup to Mirrorless?-72ffad66-f9aa-4702-9648-f236c79e0eae.jpgDoes it make sense to go from a DSLR setup to Mirrorless?-6b4b4676-7e0f-4510-95ff-5ed410134c53.jpgI use both;
    Nikon D500
    Fuji X100T
    Here is my Krampus Kit.
    the half breed devil
    Reputation: shekky's Avatar
    Oct 2011
    the main focus of my photography is trains in scenic locations. thus, when it comes time to purchase a new camera mirrorless will be a consideration, based on what i've read in this thread.
    however, i see the cost of an F to Z mount adaptor is well north of two grand. if i end up selling my D-7100, i'd like to use my 18-200 on whatever new camera i buy.
    as for carrying a brand new mirrorless with me on rides, i'd probably stick with toting around my trusty d-80 with an 18-105 kit lens. that's enough camera to get me shots like these:
    https://www.flickr.com/photos/770831...posted-public/
  67. #67
    Wow that was a nice photo
  68. #68
    Nov 2019
    I will take as much resolution as possible, until it negatively affects something that I consider more important (FPS, processing speed, etc). For printing on my Pixma Pro100 I find anything above 10mpx to be fine.
  1. Canon M5 Mirrorless - Short Term Review
    By smmokan in forum Photography for mountain bikers
    Last Post: 01-25-2019, 08:38 AM
  2. any of you all into Mirrorless cameras?
    By Boomchakabowwow in forum California - Norcal
    Last Post: 04-16-2018, 11:34 AM
  3. Sony A9 mirrorless camera introduced...
    By bsieb in forum Photography for mountain bikers
    Last Post: 04-20-2017, 05:35 PM
  4. Mirrorless or DLSR Camera For My Wife?
    By Legbacon in forum Photography for mountain bikers
    Last Post: 04-09-2017, 11:59 PM
  5. Four thirds/mirrorless sytem cameras anybody?
    By hardtailkid in forum Photography for mountain bikers
    Last Post: 01-25-2012, 12:22 PM
Members who have read this thread: 74
