• 11-22-2007
    [email protected]
    Frame polisher in Philly area?
    Anyone know of a place that will polish a raw frame in the Philly, King of Prussia area?
  • 11-22-2007
    NEPMTBA
    You might try your local auto supply. Custom vehicles tend to use that application more than bicycle riders. They might know of someone. I don't know of any bicycle shop that advertises they do it! Personally I have done them. Lot's of work, but worth the finished product! Are you having it clear coated after because it will oxidize very fast and need constant polishing if not top coated. Clear coating does level the shine a bit!
    Here's one in Ohio if you decide to send it out!
    http://www.superfineshine.com
    Good Luck!:thumbsup:
    LC
  • 11-22-2007
    tturbotom
    A Brillo pad will shine raw aluminum. I use it one any aluminum car part that I want to shine. Here is a picture what to look for.
    https://upload.wikimedia.org/wikiped..._soap_pads.JPG
  • 11-26-2007
    Tunedin302
    Start w/ a 180 grit and go all the way upto to 1100. Work in intervals of about 80 grits. After the 1100, then get yourself some polishing compund and a buffing wheel.
