2016 Occam bearing replacement?- Mtbr.com
Results 1 to 3 of 3
    Jul 2014
    My bike (2016 Occam TR H30, 29er, aluminum) is 1 year old with 2500 miles. This aluminum frame has pivot bearings concentric with the rear axle (whereas the carbon models have no pivot, just flex). There seems to be a fair bit of lateral play, so I'm considering replacing those bearings. I don't feel any obvious issues with the other bearings but should I replace those also?
    I'm considering the bearing kit from RWC:
    ORBEA Bearing Kits from RWC
    ($55)
    Or is it likely that bushings or other specific parts also need to be replaced, in which case I might need the entire kit?
    https://www.orbea.com/us-en/gear/kit...-modelos-occam
    (but this kit seems to be only the main pivots??)
    Does anybody have advice on which tools to buy to do the bearing removal/replacement? If I'm investing in tools, I'd like these to work for the bottom bracket also.
    Thanks-
    LMN
    LMN is online now
    The drive side bearing in the main pivot does seem to wear a little quick. The rest of them hold up quite well. You should be able to buy the bearing from a local bearing shop.
    I use a punch and hammer to remove the bearing and I have a press to put them in. You should be able to easily make your own press.
    "The best pace is suicide pace, and today is a good day to die." Steve Prefontaine
    Apr 2014
    Quote Originally Posted by paramount3 View Post
    ($55)
    Thanks-
    Having the same slight lateral play on mine.
    LBS suggest the Main Pivot as well.
    Did this above work for you?
  1. 2016 Occam AM
    By bikeCOLORADO in forum Orbea
    Last Post: 08-01-2017, 09:39 PM
  2. Replies: 3
    Last Post: 07-04-2017, 09:44 PM
  3. Dreaming with Orbea occam s10 - funny video -
    By gualas in forum Videos and POV Cameras
    Last Post: 05-28-2012, 01:05 AM
  4. 2012 Orbea Occam?
    By DaGoat in forum Orbea
    Last Post: 10-08-2011, 01:43 PM
  5. New Guy need advise on 2009 Orbea Occam Setup
    By camiliosalomanda in forum All Mountain
    Last Post: 03-15-2011, 09:08 AM
