Results 1 to 71 of 71
    Reputation: BCTJ's Avatar
    How do I improve my rep power?
    I've been stuck at 1 for nearly 6 months and I think I've made some pretty awesome posts.
    gran jefe
    how much rep have you given out?
    Who fraking cares about rep power? You ask they answer, they ask you answer, game over.
    Formerly mtbnoobadam
    Reputation: Adam_B.'s Avatar
    Rep is a stupid system that should be done away with. There's no actual merit to it because of d bag trolls who hand out random neg rep just for the sake of being d bags. Then you have cliques of rep whores that give eachother verbal handjobs with pos rep.
    Don't pay any attention to it.
    Registered text offender
    Dec 2011
    Quote Originally Posted by BlackCanyonTrailJunkie View Post
    You don't improve your rep power, other members do it for you when they feel you make awesome posts.
    Concentrate on contributing helpful, informative, humorous, and supportive content and find fulfillment in doing so- these are reward enough and in time others with recognize it and you.
    Here's a good place to begin-
    http://forums.mtbr.com/general-discu...oo-783855.html
    I don't think you were being all that serious, but I hope you find this helpful.
    Suckin wind like a boss
    Reputation: big terry's Avatar
    you cant really rep whore too easily because you have to dish out 100 points before you can re-rep someone...i think. but yeah, you cant spam rep someone, it dont work like that.
    read this.
    http://forums.mtbr.com/site-feedback...at-719617.html
    If you arent bleeding, you arent riding hard enough.
    http://about.me/bigterry
    Quote Originally Posted by Hutch3637 View Post
    I don't need sex. My life fvcks me daily.
    since 4/10/2009
    Reputation: Harold's Avatar
    you don't create threads about rep
    Plays with tools
    Reputation: customfab's Avatar
    You need to give Chum a reach-a-round
    nah i think chum prefers the double dutch rudder, because thats technically not gay.
    Mar 2012
    Tips for getting positive reps.
    1-Don't start threads on getting positive reps.
    2-Don't seem needy.
    3-Don't brag about yourself.
    .....oh wait, you already did those things.
    Quote Originally Posted by Bill in Houston View Post
    I guess I haven't given alot of rep power out myself. Am I supposed to? Perhaps I haven't been as impressed by the posts I read. By the way, exchanging rep power for rep power seems to defeat the purpose of the idea behind rep power?
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Perhaps we haven't been that impressed by your posts that we have read.
    Bicycles dont have motors or batteries.
    Ebikes are not bicycles
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    You post almost entirely in your regional forum.
    Beer Me!
    Reputation: Guerdonian's Avatar
    1 green chicklett with 1 rep power is respectable.
    Just be happy your not red. You also don't want rep from those of us with light green chicklets, we all have CTD's and you will end up with an irritating rash on your E-weiner.
    "Any wheel size is better than sitting at a computer all day." -Myself
    DIY all the way
    Reputation: Mr.Magura's Avatar
    Aug 2010
    Clearly not the case
    Magura
    yeah this is what an awesome post looks like:
    Quote Originally Posted by Mr.Magura View Post
    Some pics.
    Magura
    Quote Originally Posted by David C View Post
    To know your chainline, you need to measure the distance between the inside of your rear right drop-out to the middle of the middle cog of your cassette. Then take your rear spacing divided by 2 and substrac the previous measure from it to know your rear chainline.
    Let's say you have a rear 150mm axle :
    150mm/2=75mm
    And the measure you got from drop-out to middle cog is 25mm
    75mm-25mm=50mm
    So your rear chainline is 50mm.
    Then using a flat ruler, measure the distance between the middle of your chainring to the middle of the seat tube/frame. This will give you your current front chainline. Let's say you get 52.5mm.
    Now you need to match either the rear to the front or front to the rear.
    If you want to match the front, then you'll need four 2.5mm chainring spacers to stick between your crank arm spider and chainring and maybe longer chainring bolts to accommodate the new setup.
    But if you want to match the rear, you will have to either shim your cassette with a 2.5mm cassette spacer or re-shim your hub to take 2.5mm worth of spacers/washers off the drive side and put them on the non-drive side. This will likely cause to set your rear rotor out of alignment and require to also shim either the rotor or caliper adaptor mount.
    A last option is also available. Depending on your current BB/crank setup, you could just get a shorter BB spindle length (cartridge BB) or shim the BB spindle to get the right chainline (outboard BB), refer to the crank techs documents to see how to.
    Regarding chainring spacers, there is two kind, the "regular" ones and the granny ones. The regular ones will have a ID of 10.5mm to fit standard chainring bolts while the granny ones will have a ID of 8.5mm to fit on a granny ring bolt.
    Widely available standard one goes from 0.1mm to 4.5mm. Granny goes up to 5mm.
    I had a very hard time finding some 5mm standard ones locally. I pretty much had to order online, but only bags of 20 were available. So I finally found some 4.5mm ones at my local bike co-op.
    They cost about $1~$2 each at the lbs.
    Pick your poison !
    Thing is, if you make cool posts, you don't have to tell people about it
    Reputation: monzie's Avatar
    I'm cool, I like posting. Sweet handy, thanks bro. CHUMp is king dingle-ling. woot woot! IBTB.
    gran jefe
    Quote Originally Posted by mtnbikej View Post
    All this right here.
    Keep pedaling
    Reputation: Furball the Mystery Cat's Avatar
    It's better to give than to receive.
    I see a lot of intelligent, interesting, or funny posts on MTBR, so I give a lot of rep.
    Those little green squares won't improve your riding ability. Go for a ride and don't worry about it.
    Not to highjack this thread, but does Tapatalk not see rep or deal with it? I don't even have a clue how to give it out and I do see some rather funny/insightful posts every now and again.
    since 4/10/2009
    Quote Originally Posted by SS Hack View Post
    no.
    i dont think tapatalk is *that* detailed. ive noticed it too.
    Quote Originally Posted by big terry View Post
    I guess we're lucky!
    Tapatalk: CTD resistant application. Might be worth the elevendybillion dollars just for that.
    Beer Me!
    there we go kids, Tapatalk = rep condom
    Can we have cute college girls pass out tapatalk on campus now saying "practice safe repping" please.
    My point proven...
    Attached Thumbnails Attached Thumbnails How do I improve my rep power?-neg-rep.jpg
    It's funny that you think I give a **** about your neg rep. What kills me is the fact that you b!tches don't have the testicular fortitude to sign your username. U scared or something?
    Attached Thumbnails Attached Thumbnails How do I improve my rep power?-rep.jpg
    better than I deserve
    Reputation: roblee's Avatar
    Mar 2012
    I always hear guys complain about the whole rep thing, but I have to disagree. Without it, would we have the amusing threads like this and others?
    I can use the rep function on tapatalk when tapatalk is working on my phone. I just tap on the post itself and there's usually a function there.
    since 4/10/2009
    Quote Originally Posted by ehigh View Post
    Not on the iOS version I use and not here. On other forums I can "thank" someone using tapatalk but rep on any forum I use just doesn't exist in this app.
    ~Reformed Mechanic~
    Reputation: Ace5high's Avatar
    Jan 2011
    #1 IBTB
    #2 Dont worry about rep man, its a completely pointless system. The guys that only care about rep and are just keyboard commando's who put up 5,000 posts a year unemployed, still living in their moms house, that don't own a bike... They are the ones that leave neg rep and actually think anyone cares about it.. Don't get sucked in to the childish antics of children.
    Instead you should be here to learn, teach, chat, chill and enjoy the company of other real riders
    I do all my own stunts, but never intentionally...
    Quote Originally Posted by mtbnoobadam View Post
    My point proven...
    I signed my negative rep once and this guy wrote me a long letter of "**** you" and I told him he should thank me instead because at least I signed it-so I don't know what to think. The system is broke either way, so why are you worked up about it?
    Dec 2010
    whenever I see someone with red rep I usually shoot them some green to help them out a bit. I hate how the new guys are negative from the red chicklet scammers.
    Quote Originally Posted by roadie scum View Post
    Some of them deserve it, I take it on a case by case basis.
    So like, basket and brief?
    Reputation: roadie scum's Avatar
    Jan 2011
    Quote Originally Posted by sasquatch rides a SS View Post
    Dec 2010
    Certain people do deserve it, however I'm talking about the guys who have very few posts. I've seen members with 1 post, and a red chicklet, and it was just a post of their first ride or something. I shoot those guys a big green blast of rep. Unfortunately, some of the *******s on here have a lot of green rep, which I don't know why.
    DIY all the way
    Aug 2010
    Still it must be case to case based.
    I sure agree that the guy with one post and a red, couldn't possibly deserve that, but for instance the OP of this thread, just managed to get my first neg, simply for being so immensely self absorbed, that he thinks getting positive rep for just being around is mandatory.
    I truly hate that sort of attitude.
    Magura
    since 4/10/2009
    sure, case by case. I will drop red on new posters who show up with a pretentious attitude, spam the board so they can get to 10 posts so they can post links, stuff like that. I will drop green on a new poster posting up about their first ride, new bike, or whatever.
    meow meow
    Reputation: b-kul's Avatar
    i rep occasionally, i dont play it fast and lose like a lot of people but if someone reps me i try to rep them back.
    DIY all the way
    Aug 2010
    Quote Originally Posted by NateHawk View Post
    case by case.
    Now that this thread is down the drain anyway, could somebody please educate me.
    Is it "case to case" or "case by case" ?
    Cheers
    Magura
    STEEL IS REAL
    Nov 2008
    What comes around, goes around. Share the wealth and it will come back to you. It doesn't have to be an "Impressive" post. It just needs to make sense, or tickle you, or seem positive.
    Don't forget that you can also get neg rep for saying dumb, or offensive things. That can take your green blocks away, too.
    life is... "All About Bikes"...
    STEEL IS REAL
    Nov 2008
    Yeah, there's a big hairy dude on here that is waaaay overdue for a full body waxing, He's got an aweful lot of green blocks.
    ***I think a middle grounds color block should be added to the system: Yellow
    This would be a warning, without hurting the member's reputation.
    meow meow
    Cheers
    Magura
    depends. you can jump from case to case or deliberate case by case.
    DIY all the way
    Aug 2010
    Quote Originally Posted by b-kul View Post
    Please explain. I am not a native English speaker.
    Magura
    Dec 2011
    Quote Originally Posted by ambassadorhawg View Post
    I've not read anything to the effect that one is "supposed to", but reciprocating appreciation intuitively seems proper etiquette and the polite thing to do.
    Mr. Magura- case by case would be proper sentence structure, although case to case will convey the same idea.
    STEEL IS REAL
    Nov 2008
    Removed
    Removed....
    meow meow
    Magura
    to implies movement of some sort. by implies some sort of decision.
    Magura
    Magura - I don't think that hate is a value which the mountain bike forum would like to emulate.
    DIY all the way
    Aug 2010
    Thanks. Much appreciated.
    Magura
    No Stranger to danger....
    Reputation: Tone's's Avatar
    Brother, i like your style mate, you are one on this forum that has the balls n spine to always speak you mind, mate i like that alot....
    i havnt been on here for long but this rep stuff is for guys that like to flog each other off in lil circles, pure bred gutless tools give neg rep without puttin their name next to it, where i come from these same dudes get bashed for being grubs in real life, its a system that is totally floored in every regard, yep ill prob get 100 lil red dots for this, but ill wear em with pride, gettin lil green dots next to your name from your own lil mutual admiration floggers group, is for dudes with a pea heart, who like to feel like they are somebody, mate dont worry about them, n learn from mtbnoobadam, your only worth your salt if you speak you mind, dont run with the crowd, be your own man, i dont view you for how many lil green dots you got, n nore should you worry bro, cheers from oz
    adam, mate the spinless gutless coward that gave you that rep, is the kind of coward im talkin about, i dont even know how he looks in the mirror, let alone walk out into the world, hes the sort of guy who in the war would run n hide when hes mates went over the top of the trench to die, n later paint himself as a hero n collect a medal, yer strong words, but not strong enough for a spinless lil grub........
    lower than a snakes guts.........
    Beer Me!
    Getting rep is just like getting college girls.
    1. If you act like you want it too much, or wine about how you don't get enough, you will scare off those who will give it to you.
    2. If you hang out in the right area it will come to you (off camber / co-ed sports or sorority's)
    3. Be funny
    4. Be attractive
    5. Don't be ugly
    6. Intelligent posts/conversation will get you some with the right group, but not as reliably as being attractive and/or funny
    7. When moved to whore status your weener or e-weener will turn light green and become irritating.
    8. Getting some from the popular group will have extra pay off, but they either don't give it out as much, or give it and take it as often as possible
    Stiff yet compliant
    Reputation: Moustache rider's Avatar
    It's no secret how to get pos rep. Just give out lots of pos rep to other people and sign it. Some of them will return it.
    It's known as the "rep circle jerk".
    nodejitsu
    Reputation: phxKokopelli's Avatar
    Aug 2010
    You need a system.
    Mar 2012
    As sad as this thread is, the amazing thing is that the guy came back and replied to a post. I don't know how to explain this phenomenom. They usually never return, we have our fun and the thread is left to rot. I may pos rep this guy after all.
    gran jefe
    Quote Originally Posted by aikane View Post
    now who's getting soft?
    Thanks to all those who pos repped me. I was briefly at Rep Power 2, but then the haters (did someone say Magura?) knocked me back down to 1. Are we going to let the haters win, Forum?
    Mar 2012
    Well I was thinking of rewarding the perceiverance, but he has reverted to begging again, so I think not.
    dont leave me out, i think i hit ya too.
    Is not amused
    Reputation: Hutch3637's Avatar
    A long time ago in a galaxy far, far away...
    It is a period of civil war. Rebel spaceships, striking from a hidden base, have won their first victory against the evil Galactic Empire. During the battle, Rebel spies managed to steal secret plans to the Empire's ultimate weapon, the Death Star, an armored space station with enough power to destroy an entire planet. Pursued by the Empire's sinister agents, Princess Leia races home aboard her starship, custodian of the stolen plans that can save her people and restore freedom to the galaxy...
    http://forums.mtbr.com/off-camber-of...ad-775714.html
    I've evenly handed out love and dookies. Nothing gets rep points like the passion section and taking great pics of your local ride. Not you, but bike and surroundings, capturing the feel of the ride... That'll get you lots of positive rep. AZ has lots of great riding areas, outside of Phoenix. Go, shoot them, ride them, and share the stoke in the passion section, and your sword will grow.
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    Mmmm.. rep thread..
    Wēk Ss
    Reputation: IAmHolland's Avatar
    Quote Originally Posted by RandyBoy View Post
    And all without the use of a swedish penis enlarger.
    Axe
    Axe is offline
    Custom User Title
    Quote Originally Posted by IAmHolland View Post
    I wanted to enlarge your green penis, but man says I have given out too much for the day.
    They do not let me share too much.
  67. #67
    ahhh that only works when you ride west of the divide. us flatlanders dont have great photo ops, so we must rely on our wit and humor to enlarge the e-peen.
  68. #68
    hells bells! i need to wield the green peen a little more!
  69. #69
    gran jefe
    best post on the topic of rep in the history of MTBR.
  70. #70
    Ah yes, my green peen got thoroughly drained last night before going to sleep. Maybe I can spread some more love later tonight?
  71. #71
    Should I rephrase that as green cookies and red dookies?
