Storing hydration bladder..tips?- Mtbr.com
Results 1 to 29 of 29
    Reputation: taprackbang's Avatar
    Jun 2014
    I just got a new hydration backpack (Raptor 14 - doesn't look like you can take the hose apart to clean..) and used it today, it has a little bit of water left. I plan on using it again next weekend (obviously)..what would you recommend in daily storage?
    I've heard to put it in the freezer..heard to fill it back with water and keep in the refrigerator..
    What do you guys do?
    nvphatty
    Guest
    Quote Originally Posted by taprackbang View Post
    either way will suffice for next weekends adventure but in general people tend to use the freezer routine over the fridge especially for longer storage times.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    On a weekly use basis....just leave the left over water in it and toss it in the fridge.
    Bicycles donít have motors or batteries.:nono:
    Ebikes are not bicycles :nono:
    Jun 2014
    Cool..thanks.
    RAKC
    Reputation: tigris99's Avatar
    Mine always goes in the freezer empty. I may plan to use it a few days later but weather or work can mess that up, freezer does a good job of ensuring 0 issues.
    Sent from my XT1565 using Tapatalk
    Jan 2009
    I drain mine out in the sink, remove the bite valve, and put the bladder in the freezer. I wash the bite valve with dish soap and put it in a drawer. I have never had a bladder go moldy this way. refrigerator sounds like it would work but I don't have room in the frige for that.
    Feb 2015
    In my experience, the bane of hydration bladders is air. You can store water only almost indefinitely. Add an air pocket and you get mold.
    Jun 2014
    Quote Originally Posted by boomslang64 View Post
    Would you refill with water before storing it in the refrigerator? or doesn't matter?
    SS Pusher Man
    Sep 2001
    If you are using it on a regular basis.....no need to refill before tossing it in the fridge.
    I use mine 1 or 2 times a year....I leave the water in it, toss it in the veggie drawer in the fridge, take it out and use it.
    Aug 2013
    After each ride, I drain out the water, refill, and put it in the 'fridge. then its ready to go for the next ride. Mine stores nicely in an otherwise unusable space under a drawer in the fridge. I have never had mold develop with this system.
    Reputation: flyfisher117's Avatar
    Interesting I will have to try this refrigerator method.
    I have always just inverted my bladder and put it over the top of a wood dowel/paper towel holder and let it air dry.
    Never had any mold issues but I was always worried
    Sent from my SCH-I545 using Tapatalk
    Dec 2014
    my experience shows I only have mold when I'm using something besides plain water
    I use it once a week, usually drain it and place it with the rest of my gear. Using one of the performance mixes changes that, I have to rinse well to keep mold from growing. My wife doesn't like it in the fridge but I'm gona investigate that under-a-drawer idea MKid.
    oops I wasn't clipped in
    Reputation: Zomby Woof (MCM700)'s Avatar
    Since I use mine every weekend I just keep it filled with water in the refrigerator. When I come back from the ride I just refill it and put it back in the fridge.
    If I'm using it often then I put it in the freezer.
    If I know I'm not going to use it for a while I bend a wire hanger so I can shove it in the wide mouth and hang it in the coat closet to dry out. The wire hanger keeps the walls of the bladder from sticking together and staying wet.
    Reputation: milliesand's Avatar
    Jun 2015
    This doesn't really address the OP questions, but the only water that gets in my bladder is already cold and filtered using this
    PUR 18-Cup Water Filter Dispenser : Target
    Our tap water isn't bad, but...nevertheless.
    I have a bladder used 4 or 5 days a week. Maybe once a month I'll drain and air dry. Other than that it stays in the backpack.
    Reputation: evdog's Avatar
    Quote Originally Posted by mtnbikej View Post
    Someone needs to get out and ride more
    I keep mine filled with water too, but it sits in my pack in the garage. I've never fretted about mold, and in the 5-6 years I've been using my current bladder I've not had any. In a prior bladder I did a couple times but a pipe cleaner took care of that. Nothing goes in my bladder it but water, ice and an occasional beer. And the water cycles through frequently which helps.
    Reputation: Justin MD's Avatar
    Sep 2013
    I have a second fridge in my garage. My whole pack goes in after rides. No air in the bladder, cold temps, and no light really helps the mold. I wash mine about every 2 months and nothing looks, feels, or smells funny.
    You can also get quick disconnect valves from camelbak to make the hose come off without disconnecting from the bladder. But the new Raptor is so easy to remove the bladder I'm don't think it's a big deal.
    Get a large zip lock bag. Throw it in freezer after every ride.
    Happy Trails
    Reputation: Scott In MD's Avatar
    Number 1 tip >> nothing but H2O in bladder.
    Mar 2014
    About once a month I empty mine out completely of water and put about a cup of lemon juice in it. Suck all the air out and let it soak for a while. Rinse well and go.
    Reputation: velo99's Avatar
    Apr 2014
    I have to agree with Boom. I clean mine out occasionally and get all of the air out. Usually leave it in my pack for the weeks riding. When I empty or near empty it on a ride I'll rinse it out and refill getting all of the air out. I too use water only. There's too many nooks and crannies to clean if I get mold growing.
    The bike doesn't make you go fast.
    You make the bike go fast.
    Cycologist
    Reputation: chazpat's Avatar
    I take it out after riding and throw it in my beer fridge in the basement. But I only fill it with water. Never had a mold issue in years of doing this.
    This post is a natural product. Variances in spelling & grammar should be appreciated as part of its character & beauty.
    Evolutionsverlierer
    Reputation: acer66's Avatar
    Oct 2010
    Quote Originally Posted by tigris99 View Post
    Never had an issue doing it that way.
    Quote Originally Posted by Mr Pig View Post
    Avid is spelled wrong, there should be an 'O' in there.
    Reputation: dietz31684's Avatar
    Quote Originally Posted by acer66 View Post
    Ditto
    Sent from my VS980 4G using Tapatalk
    Broken Hipster
    Reputation: Barman1's Avatar
    Jan 2014
    Fridge guy here as well.
    Camelback gets filled in the AM and I chuck the whole thing in the fridge when I get back from the ride.
    I don't like cold water on a ride ergo the AM fill (enough for the ride) up.
    I'm on the third season with the original bladder in my Mule.
    Guest
    For long term storage (more than a week) I use the bladder hangers that Camelbak makes (you can cut to fit almost anything). I also installed a quick disconnect valve.
    Reputation: SDMTB'er's Avatar
    Feb 2014
    After rinsing put them in the freezer.
    Giant Reign Advanced 1
    Reputation: ka81ua's Avatar
    Oct 2014
    I
    have you found out how to disconnect hose from bladder-connector without damaging ?
    In my new Raptor 14 same situation - i cant take it apart.
    OK
    eri
    eri is offline
    Reputation: eri's Avatar
    Sep 2012
    After 6 months of cleaning and care, nights in freezer I now have occasional mold problem because of very occasional use of carb drink. Using the new osprey with zip top I can clean pretty easily, but not too thoroughly I suppose. Hose and mouthpiece are a problem. I try to fully air dry but it takes days.
    Last week I bought a large bottle of the cheapest gin I could find, $17 for 1.5 liters. Filled the bladder including hose, left overnight, then drained back into bottle. Bladder was dry by afternoon. Refilled with water and now theres a slight pleasant gin taste. Definitely better than Clorox. Anyone know if the gin will kill mold?
  1. Hydration Bladder in a frame bag?
    By podrunner in forum Nutrition and Hydration
    Last Post: 08-12-2017, 08:02 AM
  2. storing my SLR in a hydration pack? what to buy
    By wizzer16 in forum General Discussion
    Last Post: 04-16-2014, 01:13 AM
  3. How often do you clean your hydration bladder?
    By Rockrover in forum Nutrition and Hydration
    Last Post: 01-04-2014, 08:25 PM
  4. Help me pick a hydration bladder.
    By John K. in forum Nutrition and Hydration
    Last Post: 09-01-2012, 06:19 PM
  5. Custom Hydration Bladder
    By AvalonTrails in forum General Discussion
    Last Post: 01-13-2011, 05:14 PM
