• 04-17-2016
    taprackbang
    Storing hydration bladder..tips?
    I just got a new hydration backpack (Raptor 14 - doesn't look like you can take the hose apart to clean..) and used it today, it has a little bit of water left. I plan on using it again next weekend (obviously)..what would you recommend in daily storage?
    I've heard to put it in the freezer..heard to fill it back with water and keep in the refrigerator..
    What do you guys do?
  • 04-17-2016
    nvphatty
    either way will suffice for next weekends adventure but in general people tend to use the freezer routine over the fridge especially for longer storage times.
  • 04-17-2016
    mtnbikej
    On a weekly use basis....just leave the left over water in it and toss it in the fridge.
  • 04-17-2016
    taprackbang
    Cool..thanks.
  • 04-17-2016
    tigris99
    Mine always goes in the freezer empty. I may plan to use it a few days later but weather or work can mess that up, freezer does a good job of ensuring 0 issues.
    Sent from my XT1565 using Tapatalk
  • 04-17-2016
    mack_turtle
    I drain mine out in the sink, remove the bite valve, and put the bladder in the freezer. I wash the bite valve with dish soap and put it in a drawer. I have never had a bladder go moldy this way. refrigerator sounds like it would work but I don't have room in the frige for that.
  • 04-17-2016
    boomslang64
    In my experience, the bane of hydration bladders is air. You can store water only almost indefinitely. Add an air pocket and you get mold.
  • 04-17-2016
    taprackbang
    Would you refill with water before storing it in the refrigerator? or doesn't matter?
  • 04-17-2016
    mtnbikej
    If you are using it on a regular basis.....no need to refill before tossing it in the fridge.
    I use mine 1 or 2 times a year....I leave the water in it, toss it in the veggie drawer in the fridge, take it out and use it.
  • 04-18-2016
    Malemute Kid
    After each ride, I drain out the water, refill, and put it in the 'fridge. then its ready to go for the next ride. Mine stores nicely in an otherwise unusable space under a drawer in the fridge. I have never had mold develop with this system.
  • 04-18-2016
    flyfisher117
    Interesting I will have to try this refrigerator method.
    I have always just inverted my bladder and put it over the top of a wood dowel/paper towel holder and let it air dry.
    Never had any mold issues but I was always worried
    Sent from my SCH-I545 using Tapatalk
  • 04-18-2016
    jim c
    my experience shows I only have mold when I'm using something besides plain water
    I use it once a week, usually drain it and place it with the rest of my gear. Using one of the performance mixes changes that, I have to rinse well to keep mold from growing. My wife doesn't like it in the fridge but I'm gona investigate that under-a-drawer idea MKid.
  • 04-18-2016
    Zomby Woof (MCM700)
    Since I use mine every weekend I just keep it filled with water in the refrigerator. When I come back from the ride I just refill it and put it back in the fridge.
  • 04-18-2016
    peter.thedrake
    If I'm using it often then I put it in the freezer.
    If I know I'm not going to use it for a while I bend a wire hanger so I can shove it in the wide mouth and hang it in the coat closet to dry out. The wire hanger keeps the walls of the bladder from sticking together and staying wet.
  • 04-18-2016
    milliesand
    This doesn't really address the OP questions, but the only water that gets in my bladder is already cold and filtered using this
    PUR 18-Cup Water Filter Dispenser : Target
    Our tap water isn't bad, but...nevertheless.
    I have a bladder used 4 or 5 days a week. Maybe once a month I'll drain and air dry. Other than that it stays in the backpack.
  • 04-18-2016
    evdog
    Someone needs to get out and ride more :lol:
    I keep mine filled with water too, but it sits in my pack in the garage. I've never fretted about mold, and in the 5-6 years I've been using my current bladder I've not had any. In a prior bladder I did a couple times but a pipe cleaner took care of that. Nothing goes in my bladder it but water, ice and an occasional beer. And the water cycles through frequently which helps.
  • 04-18-2016
    Justin MD
    I have a second fridge in my garage. My whole pack goes in after rides. No air in the bladder, cold temps, and no light really helps the mold. I wash mine about every 2 months and nothing looks, feels, or smells funny.
    You can also get quick disconnect valves from camelbak to make the hose come off without disconnecting from the bladder. But the new Raptor is so easy to remove the bladder I'm don't think it's a big deal.
  • 04-21-2016
    baja07
    Get a large zip lock bag. Throw it in freezer after every ride.
  • 04-21-2016
    Scott In MD
    Number 1 tip >> nothing but H2O in bladder.
  • 05-04-2016
    sbvx67
    About once a month I empty mine out completely of water and put about a cup of lemon juice in it. Suck all the air out and let it soak for a while. Rinse well and go.
  • 05-11-2016
    velo99
    I have to agree with Boom. I clean mine out occasionally and get all of the air out. Usually leave it in my pack for the weeks riding. When I empty or near empty it on a ride I'll rinse it out and refill getting all of the air out. I too use water only. There's too many nooks and crannies to clean if I get mold growing.
  • 05-29-2016
    chazpat
    I take it out after riding and throw it in my beer fridge in the basement. But I only fill it with water. Never had a mold issue in years of doing this.
  • 05-30-2016
    acer66
    :thumbsup: Never had an issue doing it that way.
  • 05-30-2016
    dietz31684
    Ditto
    Sent from my VS980 4G using Tapatalk
  • 05-30-2016
    Barman1
    Fridge guy here as well.
    Camelback gets filled in the AM and I chuck the whole thing in the fridge when I get back from the ride.
    I don't like cold water on a ride ergo the AM fill (enough for the ride) up.
    I'm on the third season with the original bladder in my Mule.
  • 05-30-2016
    755872
    For long term storage (more than a week) I use the bladder hangers that Camelbak makes (you can cut to fit almost anything). I also installed a quick disconnect valve.
  • 06-14-2016
    SDMTB'er
    After rinsing put them in the freezer.
  • 11-01-2016
    ka81ua
    I
    have you found out how to disconnect hose from bladder-connector without damaging ?
    In my new Raptor 14 same situation - i cant take it apart.
  • 11-09-2016
    eri
    After 6 months of cleaning and care, nights in freezer I now have occasional mold problem because of very occasional use of carb drink. Using the new osprey with zip top I can clean pretty easily, but not too thoroughly I suppose. Hose and mouthpiece are a problem. I try to fully air dry but it takes days.
    Last week I bought a large bottle of the cheapest gin I could find, $17 for 1.5 liters. Filled the bladder including hose, left overnight, then drained back into bottle. Bladder was dry by afternoon. Refilled with water and now theres a slight pleasant gin taste. Definitely better than Clorox. Anyone know if the gin will kill mold?
