Best way to load up on calories after a ride?- Mtbr.com
Results 1 to 8 of 8
    Professional Noob
    Reputation: eicca's Avatar
    May 2014
    I'm 23, 6'1" and 145lbs and my metabolism is probably charted somewhere around "nuclear." If I ride and don't refuel afterward I get tired, crank, and nasty headaches. Like today, I did 11 miles, most of it climbing, and managed to get a tuna fish sandwich and a protein shake before heading off to work but still ended up with a gnarly headache an hour or so later. Once I got off I was able to get a huge Costa Vida burrito and put it down in minutes and now I feel way better.
    What do you recommend? Tons and tons of granola bars? Eating light snacks during the ride to try and keep energy up? (I usually just roll with a water bottle full of CarboRocket and I feel great...) A nice restaurant meal after every ride would be quite nice but a little unfriendly on the wallet.
    => CannondaleExperts.com <=
    All the parts and accessories your Cannondale ever needs
    Rent this space for $
    Reputation: Oh My Sack!'s Avatar
    Taking in good protein about 20 to 30 minutes after your ride is a good thing. That's always my priority and like you, I usually do this with a Whey Protein shake with fruit and spinach mixed in to top off the glycemic needs. Are you sure you're getting enough water before, during, and after your ride? Not familiar with CarboRocket but is offering sufficient calories without refined sugars. Does it have a good supply of Sodium and Potassium?
    Edit: Just looked up CarboRocket. Maybe the Fructose is having an effect. It's also loaded with lot of calcium. For grins and giggles, try another mix like Tailwind or Skratch and see if that has an effect on your headache issue.
    Professional Noob
    May 2014
    I've been toying with the idea of just blending my own electrolyte drink. Some table sugar with salt and potassium. Probably won't taste great but then again neither has any other drink I've tried. Wonder if that'd be sufficient to keep me energized properly without all the extra additives.
    Log off and go ride!
    Jul 2003
    Research shows the optimum glucose concentration is around 6-8%. Above that the solution is slower to leave the stomach, thus takes longer to absorb. Read the labels on the product, and do some math. Some sports drink are much higher than the preferred 6-8%. The higher ones are OK to pre-hydrate in the hour or so before your ride, just not during the ride. Glucose based are better than fructose, as fructose must be processed by the liver first, thus taking longer to get into the muscles. Glucose & fructose mixes are OK also, as then you have fast absorption for immediate effect, and a slower sustained glucose source.
    Post workout snack should be around a 3:1 to 5:1 carb-protein ratio. If the ride was more endurance then use the 5:1 ratio, if a more physical workout then 3:1. The exact ratio is not as important as just getting carbs (high glycemic preferred, or a mix) into you to replenish muscle glycogen. About an hour later push protein. Carbs first. That stops the catabolism and starts anabolism.
    You can get all the protein your body needs and can use from real food. Protein powders are unnecessary. Don't hurt, but are not any better than a good diet of real food.
    Reputation: Calhoun's Avatar
    Nov 2008
    "Real Food" is ideal but not always convenient.
    If you are looking for an easy way to get calories you might try some Carbo Gain. I have a hard time getting enough calories in (just not hungry that often) but I have been adding Carbo Gain to my protein shakes to get some extra calories.
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    Professional Noob
    May 2014
    I might give that a shot. My biggest issue is that my metabolism is so fast I can't get enough calories in me during a longer ride without eating so much I get sick when climbing. Plus carrying all that food is a pain.
    Jul 2003
    Quote Originally Posted by eicca View Post
    Are you sipping on a carb sports drink before and during the ride?
    Do not take anything I post seriously. I don't.
    Professional Noob
    May 2014
    Quote Originally Posted by dave54 View Post
    Sure am.
  1. Calories Burned=Calories Needed After A Ride For Recovery?
    By Bethany1 in forum Beginner's Corner
    Last Post: 04-02-2015, 01:38 PM
  2. Creaking under load, 45 mins into ride
    By SDMTB'er in forum Pivot Cycles
    Last Post: 10-09-2014, 07:15 PM
  3. Calories in, Calories Out - STCP Newbie Ride
    By Dion in forum California - Norcal
    Last Post: 12-01-2012, 07:44 PM
  4. Do I need to replace calories burned from a ride to maintain weight?
    By bikeisgood in forum XC Racing and Training
    Last Post: 05-18-2012, 01:40 PM
  5. How many calories do you eat/day?
    By joshman108 in forum General Discussion
    Last Post: 01-24-2011, 01:33 AM
