What gears for Asheville area?- Mtbr.com
Results 1 to 6 of 6
    Quiet Professional
    Reputation: chef7734's Avatar
    SO I am planning on building a giant reign so I can get back into mountain biking. I live in the Asheville area and wondering what gears everyone is using? Should I go 1x12 with a 36 up front and 10-51t in back?
    Reputation: Sugar_Brad's Avatar
    Quote Originally Posted by chef7734 View Post
    If you are getting back into biking that gear ratio is pretty tall. It really depends on what trails you plan on riding but I would go with a 30 or 32 (I am decently fit and run a 32) tooth front ring.
    since 4/10/2009
    Reputation: Harold's Avatar
    One of my two mtb's is geared at a 28t chainring and 11-46. That's about where I like to be. My other is geared at 30t and 10-45 and it's just a touch taller than I'd prefer. I can ride up anything locally with that gearing when I'm fresh, but I need a little lower for when I'm tired. I'll be moving it to a 28t chainring eventually, but there aren't any HG+ compatible 28t rings available for Race Face CINCH direct mount cranks yet.
    FWIW, I'm a fairly slow climber by local standards and probably a midpack descender.
    If you're planning to put a 36t ring on a Reign and climb with that bike (not just ride park stuff and shuttle), you'd better be strong. And if you're planning to ride park stuff and shuttle primarily, the range of a 10-51 is a bit of a waste.
    Reputation: Timothy G. Parrish's Avatar
    Apr 2014
    Quote Originally Posted by Sugar_Brad View Post
    What Brad said. Most people around here run a 32t. You'd probably be better off with something smaller to start.
    Quiet Professional
    OK thanks. I look at 30 and 32t
    30 front 51 rear to start. I was suffering getting back into shape with a 32.
    Sent from my SM-G975U using Tapatalk
  1. Gears on No Gears?
    By bing! in forum Downhill - Freeride
    Last Post: 11-13-2014, 01:44 AM
  2. Asheville Area CPR Saturday...
    By TrailZen in forum North & South Carolina
    Last Post: 02-10-2011, 03:29 PM
  3. Fixed gears ... gears
    By Aldone in forum Singlespeed
    Last Post: 08-29-2007, 11:34 PM
  4. Gears or no gears?
    By no_lix in forum Beginner's Corner
    Last Post: 03-18-2007, 03:50 PM
  5. Gears, Gears, and More Gears
    By OneEyeMan in forum Singlespeed
    Last Post: 09-05-2006, 06:38 PM
