Dupont Pump Track- Mtbr.com
    ohhman
    Reputation: salmansp's Avatar
    Dupont Pump Track
    The Dupont Pump Track Fund has almost reached its goal! Please drop some change into pot next time you are at The Hub. We will begin construction shortly after we reached the necessary funds to do so.
    The PT will be full of wooden rollers, berms, tables, and other obstacles branching off the sides.
    We will send notice to PAS when the build date comes about.
    Thank you all for your support.
    Next fund raiser will be the Kids Noggin initiative. Will will be collecting donations to help provide helmets to all the little helmetless rippers at local Dirt Jumps, trails, and other local hot spots. So chip in and help a little shredder out. SixSixOne has already joined the effort, and will be throwing in a handful of helmets for the cause.
    Drinker w/ Riding Problem
    Reputation: brado1's Avatar
    Quote Originally Posted by salmansp
    where in DuPont is the Pump Track going to be located?
    Reputation: 4000psi's Avatar
    At giuion Farms next to the skills course. Also, send notice to UpstateSORBA when you get it since this is a SC trail system.
    Dec 2008
    Will Do.
