Widest tire for 2018 29er Norco Sight Carbon?- Mtbr.com
Results 1 to 11 of 11
    high pivot witchcraft
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    Anyone know if it will fit a 2.4 DHR2 on the rear? How about a 2.5 DHF?
    Feb 2013
    The tech specs sheet from Norco says 2.5. But I'm not sure in real life.
    https://www.norco.com/downloads/bike...mall-parts.pdf
    Mar 2015
    Quote Originally Posted by Darth Pinche View Post
    Interesting. Thanks.
    Man - this subform is dead. I should probably post this on PinkBike. Much more Norco activity there. Like you say, it would be good to hear from guys actually running 2.5s, rather than relying on the manufacturer's claims. Case in point:
    https://forums.mtbr.com/yeti/sb130-s...s-1089983.html
    Reputation: clintj's Avatar
    Nov 2018
    I've got the 2017 version of that bike. The stock 2.35 DHR fits just fine, and there's plenty of clearance around it. Looks like if you go bigger, the first place you're going to lose mud clearance is the seatstay bridge.
    Sent from my Pixel 2 using Tapatalk
    Mar 2015
    Thanks. Is yours a 27.5?
    I have 2.3 DHR2s on mine (I replaced the 2.3 E*13 tires and wheel set after 1 ride). There is a shit ton of clearance at my seat stay bridge/yoke. The iffy part on my bike is the chainstay clearance. I have shockingly little clearance there.
    Nov 2018
    29er. I can fit my thumb between tire and frame on mine. Did you go to a wider rim? I'm running 2.35 Minions on WTB rims, 28mm inside width.
    Mar 2015
    Quote Originally Posted by clintj View Post
    The opposite. I went from the stock E*13 30 mm id rims to 27 mm id We Are One Insiders. Replaced the beefy 2.3 E*13 TSR tire with the 2.3 DHR2.
    Nov 2018
    Huh. When I get some free time later today I'll take a pic of my tire clearance in back to compare.
    Another thought is maybe the way Norco tailors chainstay length to size is having an effect? I'm on a medium.
    Mar 2015
    Iím on a large. If anything, you would think any tailoring on mine would provide for greater clearance. I will take a few pics of mine too and post them. Hopefully they will accurately illustrate the actual clearance. Thanks for your help.
    Nov 2018
    I stuck my bike wash mitt in the background for contrast here. I also didn't realize how much wear and tear the vinyl tape I use on the frame had until I used the flash. Wow!
    Mar 2015
    Shit. I got stuck at work. I promise I will take some pics super soon. Thanks for posting those. They are very helpful. I really appreciate the effort.
  1. 2018 Norco Sight with Fox DPS EVOL rear shock
    By Nissan80 in forum 29er Bikes
    Last Post: 03-31-2018, 08:15 PM
  2. 2018 Intense Primer and Norco Sight Reviews???
    By sctrix1 in forum 29er Bikes
    Last Post: 01-29-2018, 12:12 AM
  3. Norco Sight Alloy 2018
    By Nissan80 in forum All Mountain
    Last Post: 11-17-2017, 02:04 AM
  4. Replies: 9
    Last Post: 07-25-2014, 10:26 PM
  5. Sight/Sight KillerB BB height
    By skidad in forum Norco
    Last Post: 11-02-2012, 03:38 PM
