Size for Norco Sight- Mtbr.com
Results 1 to 5 of 5
    Jul 2017
    I found very cheap little used Norco Sight 650b 2015 in Large.
    I am 5' 9" with 31.5" inseam and very very light 60kg can I fit?
    Other question about quality of alu Norco frame are they cracking?
    Sem
    Nov 2018
    Quote Originally Posted by ileste View Post
    It depends on the size of large, if it had dimensions it can help. Then you can use a chart to find out if you would be comfortable using that frame (obviously if it isn't perfect it won't be too bad). Here is a size chart:
    https://www.evanscycles.com/help/bike-sizing-TT
    As for the frames, I have never had norco so I can't say, but they have been around and popular for a while so I'm guessing they are good.
    Sent from my Moto G (5) using Mtbr.com Forums
    Jul 2014
    The pre 2017 models are a bit shorter in the geometry so a large should be fine I would think.
    There were some issues with chainstays.
    Apr 2014
    Large is pushing it tbh.....you’re bang in the middle of a medium. See if you can try it
    Reputation: clintj's Avatar
    Nov 2018
    I'm your height with a shorter inseam and ride a medium. I found that my limiting factor on a large is I can't get the stock dropper post low enough in the frame for comfortable pedaling.
    Sent from my Pixel 2 using Tapatalk
  1. FS: 2014 Norco Sight Carbon LE 27.5 size M
    By martinPL in forum Classifieds
    Last Post: 10-22-2017, 05:38 PM
  2. Replies: 6
    Last Post: 05-05-2016, 08:49 AM
  3. Norco Sight as a PLUS size
    By kamper11 in forum Norco
    Last Post: 06-25-2015, 07:38 AM
  4. Sight/Sight KillerB BB height
    By skidad in forum Norco
    Last Post: 11-02-2012, 03:38 PM
  5. 2012 Norco Sight Review.
    By Biggles604 in forum All Mountain
    Last Post: 06-16-2012, 08:52 AM
