• 06-21-2014
    field_c
    Sight Carbon 7.1 - replacement headset?
    Can anyone recommend an upgrade to the FSA Orbit C-40-ACB integrated headset that comes stock on the Sight 7.1.
    After a couple of muddy rides, mine is rusted out and creaking badly, even after cleaning and regreasing a couple of times. There doesn't appear to be any decent seal at all at the bottom bearing area.
    Chris
  • 06-23-2014
    dreys
    Have you tried the warranty replacement? I believe issues like that are covered for 1 year from the date of purchase.
    For replacement, in case you don't want to warranty it out, I'd suggest going with Cane Creek 40 or 110-series. Both have seals on the bottom area to protect against moisture and dirt.
  • 06-23-2014
    field_c
    Not sure I'll bother with the warranty replacement, as it is highly likely to occur again.
    Looks like the FSA headset uses the Campag angular bearing standard, so will an equivalent integrated Cane Creek 40 or 110 be OK to fit?
    Thanks for your help.
    Chris
  • 06-23-2014
    dreys
    Either 40 or 110 will fit, you will need IS 42 (top) / IS 52 (bottom)
    110 is slightly nicer set (and includes "110 year warranty"), however it comes a premium price. 110 has two sealing lips on the crown race, where as the 40 has "only" one.
    Both 40 and 110 are really nice though and either one will provide a seal from dirt. I've used primarly 40-series here in SoCal and never had any issues.
  • 06-23-2014
    field_c
  • 08-09-2014
    hanger
    Which one of IS52-30 or IS52-40 will fit? Running RS Pike fork..
  • 08-09-2014
    dreys
    You need IS52 bottom and IS42 top
  • 08-10-2014
    hanger
    Yeah but I found two different ones.. IS52-30 and IS52-40.. I think the last number is outer diameter of the crown or something..
  • 08-10-2014
    dreys
    IS52-40 for the bottom
    52-40 is for 1-1/2 down steer
    52-30 is for 1-1/8 down steer
    Rockshox Pike has 1-1/2 down steer, so you need IS52-40
    Check your PM, I have one extra Cane Creek 40-series headset if you need it.
