shock and fork pressure on sight 27.5 ?- Mtbr.com
Results 1 to 3 of 3
    What is everybody using for shock and fork preassure and what is your weight?
    if it helps - all sag - and trail feel for me... all I know is I am lower PSI in the fork than the chart on the left inside fork leg - by about 20psi
    with the sag marks on the RS - its super easy - but settled in aroudn 28-30% on a 150 Pike upgrade fork, prob 27-28% Monarch RT. it seems spot on for front range colorado variety -
    I had my sag set at about 25% front and back, 95psi front and 160psi back. When I rode I was using most of the travel to easily. I weigh 190-195 with gear.
  1. Replies: 14
    Last Post: 03-26-2014, 08:56 AM
  2. Fox Float (fork and shock) Air Pressure
    By alexk243 in forum Shocks and Suspension
    Last Post: 04-07-2012, 07:22 PM
  3. Low pressure shock/fork pump ...
    By TurtleGerl in forum Shocks and Suspension
    Last Post: 07-03-2011, 09:16 AM
  4. Low Pressure Shock/Fork Pump ...
    By TurtleGerl in forum Arizona
    Last Post: 06-29-2011, 04:31 PM
  5. Air Shock/Fork Pressure
    By sonypete in forum Clydesdales/Tall Riders
    Last Post: 04-22-2011, 04:46 PM
