Seatpost holder on carbon Sight- Mtbr.com
Results 1 to 8 of 8
    Dec 2008
    I have a '14 Sight carbon that has some play between the seat tube clamp and the frame. It's still in there fairly tight but I can rotate it by hand if I push hard enough. I don't know how tight this thing is supposed to be, or how it is attached to the frame, but I don't think it should be moving as easily as it is. I can't see any damage on the frame itself, and I'm wondering if this is something I should have looked at. Any advice would be appreciated.
    Jan 2014
    Tighten the seat clamp.
    Dec 2008
    Quote Originally Posted by dreys View Post
    Maybe I'm missing something, but I don't see how that's going to help. The seat post isn't moving, the clamp itself is moving. The red arrow is where the movement is occurring, between the clamp and the frame.
    Attached Thumbnails Attached Thumbnails Seatpost holder on carbon Sight-5-18-2015-3-32-02-pm.jpg
    Looks like the sleeve in the carbon frame is loose
    Dec 2008
    Quote Originally Posted by the-one1 View Post
    Correct... Sorry I am probably not using the correct terms to describe what is going on. Any idea if I can fix this, or do I need to have the LBS / Norco dealer look at it?
    CAMBr Trail Crew
    Reputation: DDDonny's Avatar
    Quote Originally Posted by AKAndy View Post
    Correct... Any idea if I can fix this, or do I need to have the LBS / Norco dealer look at it?
    If it's a frame issue, which it sounds like it is, you'll probably have to get in contact with NORCO to have the situation remedied. Please let us know the outcome...
    Dec 2008
    I'm taking it in to the dealer today so we'll set how is goes. They said based on my description they should be able to adjust the clamp to fix the problem. Thanks for the input.
    CAMBr Trail Crew
    Any update on the outcome of your seat post situation???
  1. Replies: 9
    Last Post: 07-25-2014, 10:26 PM
  2. Replies: 1
    Last Post: 03-23-2014, 12:00 PM
  3. Replies: 16
    Last Post: 01-10-2014, 07:05 PM
  4. Seatpost mount bottle holder
    By racer1 in forum Endurance XC Racing
    Last Post: 07-30-2012, 04:22 PM
  5. profile design seatpost 2-bottle holder?
    By BBW in forum Endurance XC Racing
    Last Post: 08-01-2011, 07:20 AM
