Range Derailleur Hanger Alignment Issue- Mtbr.com
    Apr 2014
    Hello!
    I have a 2014 Range C 7.1 and I am having problems with the derailleur hanger not staying straight. I have a hanger alignment tool and I can straighten is until its absolutely perfect but I still can not get my XX1 drive train to shift correctly out of the 10 tooth cog to the 12 tooth. After a few rides I will check the hanger alignment again and it is always a little off. Does anybody have any suggestions or anything?
    high pivot witchcraft
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    Quote Originally Posted by smjergie View Post
    Hello!
    If I were you, I would throw this up on the drivetrain forum as I don't think it is a bike specific problem. This forum is dead. Lucky to get a post a week.
    Apr 2014
    I truly don't believe this is a drive train issue but rather an issue with the Syntace X-12 interface. I will post over there as well but Ill leave this here just in case someone else has the same problem.
    Reputation: JHwick's Avatar
    Yes, I've noticed something similar.
    I wound up using a bit of loctite on the flat surface between the hanger and the frame. From there I aligned the hanger as well as I could and made the 5mm Allen bolt pretty tight.
    Seems to be better now and less prone to going out of alignment.
  1. My DIY Derailleur Hanger Alignment Gauge (that also cost nothing)
    By sasquatch rides a SS in forum Tooltime
    Last Post: 07-12-2015, 12:39 PM
  2. Derailleur - or Hanger - Alignment
    By Sablotny in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 07:18 PM
  3. Will this work - Derailleur Hanger Alignment tool
    By dietz31684 in forum Tooltime
    Last Post: 10-03-2014, 05:47 AM
  4. Replies: 2
    Last Post: 02-05-2014, 10:23 AM
  5. Derailleur hanger alignment gauge
    By golden boy in forum Frame Building
    Last Post: 05-08-2012, 07:17 PM
