Norco Sight with Pike - 150mm or 160mm?- Mtbr.com
Results 1 to 39 of 39
    I dig trails!
    Reputation: Mr.P's Avatar
    Feb 2005
    Any insight?
    2014 Carbon 7.2 - I have both air shafts for the Pike.
    I'm coming off a Specialized Enduro (slack and long) and chose the Sight for being a bit shorter, or a bit more nimble and less plow bike.
    Sight with original Revelation = 529mm A-C
    Pike 150 = 542mm A-C
    Pike 160 = 552mm A-C
    The old theory is 1 inch taller in fork = 1 degree slacker HA, so...
    Original Revelation = 67.5 HA
    Pike 150 = (+0.5") = 67 HA
    Pike 160 = (+0.9") = ~66.6 HA
    BB will also raise about 1/3 of the fork increase.
    ... I guess I am working this out while I write the post, lol. Thanks for bearing with me.
    Any ride experiences with the Pike at 160mm?
    Trails will be a mix of valley smooth and alpine chunk. All will be pretty fast.
    P
    Edit: As a side note, I run my forks pretty progressive and firm, and am speccing the Pike for stiffness and geometry and not for additional travel.
    May 2014
    Well, I'm running a Pike 150mm my Sight LE. I'm about 190lbs and hit intermediate sized jumps and drops. The Pike handled 4' plus drops to flat no problem and I have it set up on the firm side. No problem with the changes to the geo, the Sight still handled great- super balanced and fun. If you have an issue, I guess you could install an offset bushing to move the geo back towards stock.
    the pike is money on the sight, super plush. With a 150, I think you would bottom out the fox shock before the Pike.
    Also, you can always change the air damper for $40 and go from 150 to 160 or vice versa, 160 to 150.
    I like the 150 and am happy with my decision. Despite coming from a bike with a 160 fork and shock.
    I dig trails!
    Feb 2005
    Nice! Thanks Sounders!
    P
    May 2014
    Sure. here's my sight all built up. Pike 150, fox float kashima bv, xx1, next sl crank, xtr brakes, nox/I9 wheels. just waiting on my new pedals.
    Reputation: Dirt Gnome's Avatar
    Apr 2014
    I think it would really depend on how much sag you roll with. If you're running 25-30% sag then 160 wouldn't be over the top. that being said 150 is probably a safe bet too. Really a personal preference i think then a huge difference in the ride from the head angle.
    I have a weird and unreasonable dislike of the number 6, so I would most likely go to the 150 if I was buying a new fork (150mm, 5.9 in). But if you're not a total f'n weirdo like me I would go big or go home (160mm 6.3 in) all the way.
    I'm running a 150 pike it feels right. I don't think this bike would preform as well with a smaller stanchions. The taller fork gives a slightly slacker HT angle. I used a GEO calculator it's ~ 66.8* i don't think I would put a 160 on the front. You want the front and rear of the bike to perform similar to one another. Raising the BB more might have a small effect on handling. Plus you're kinda converting a trail bike into that longer travel category.
    Attached Thumbnails Attached Thumbnails Norco Sight with Pike - 150mm or 160mm?-imageuploadedbytapatalkhd1400124855.900793.jpg
    Reputation: SoCal-Rider's Avatar
    Are you guys upgrading to a Pike at purchase or buying them later on down the line? I'm steering away from the Sight because it doesn't look like they have a US frame only option and don't offer the Pike in a package. Am I missing something?
    Reputation: Serotta b1kr's Avatar
    Well, I started with upgrading to the Pike and Crank to next sl on a 7 1.5 my lbs had in stock, pretty much at the cost difference. Though, I really wanted LE w/ xx1 so the lbs called Norco and they did have a LE frame available so my lbs snagged it and built it up custom for me.
    If you just wanted to upgrade to the Pike, I think many/most dealers would do so at the cost difference or close to it. The hard part will be finding one. My lbs still has a M and L 7 1.5 in stock, and so you might want to contact them (PM me).
    OTOH, there are a number of outstanding bikes in this category, Troy, Mach 6, Tracer T275, 5010/Bronson. Another bike that is pretty similar to the Sight is the Process 134, though it's not carbon, the geo is really nice.
    Good Luck SoCal-Rider.
    fill what's empty, empty what's full, and scratch where it itches.
    I dig trails!
    Feb 2005
    Quote Originally Posted by Darkstar187 View Post
    I'm running a 150 pike it feels right....I used a GEO calculator it's ~ 66.8* ...you're kinda converting a trail bike into that longer travel category.
    Thanks! That was the info I was looking for. 66.8 should be perfect.
    I converted the Pike to 150mm the other night, so I just need to finish the build.
    (Is that Granite Bay trail?)
    P
    Quote Originally Posted by SoCal-Rider View Post
    local dealer said the 2015 model (august delivery) will have a 140mm pike, for the two highest models.
    May 2014
    Quote Originally Posted by bikebum View Post
    that's great news. Plus, it only costs like $40 to change the damper to make the fork a 150 or 160.
    I had mine built as frame only.
    Quote Originally Posted by Mr.P View Post
    P
    That sure is granite bay!! I ride there quite often!
    Reputation: jdcatnau's Avatar
    Feb 2007
    If you're looking for frame only give Matt a shot.
    [email protected]
    I know his shop is out of Pikes, but he may have a frame.
    Rolling a 2013 Sight, 35mm stem,Pike 160mm fork and Cane Creek double barrel air CS rear shock. Still handles great! CCDB CS flat out rocks on this bike. Climbing is taken to a new level!
    Mr.P where did you get your sight from??
    Curious about owners thoughts on the 2 degrees offset difference going to the pike?
    Nice bike darkstar
    I dig trails!
    Feb 2005
    Downieville Outfitters
    Downieville Outfitters - Shuttle Service to the Downieville Downhill
    P
    May 2014
    Quote Originally Posted by SMKNTRLS View Post
    Nice bike darkstar
    Well, Norco specs the carbon frames with the RS 140 rev which has a 42mm rake. The Pike 150 SA has the same 42mm rake. Fwiw, I love the way that bike handles, but then, I'm no rockstar rider.
    Soundersfc thane for sharing. Kick'n bike u got there too. I appreciate that last response and as my riding buddy told me last night during our night ride I just need to get a bike and ride it ;-). Nbd can't come soon enough :-)
    Quote Originally Posted by staz View Post
    So what size frame u snuggle that ccdb into and do u mind pming me who helped u out and what accessories u needed to make t happen. Pics would b sweet! Enjoy the ride!
    Feb 2007
    Cane creek's website has a fit finder. If you order it from them all the hardware comes with it. I have a ccdbair CS on my 2013 alloy and it's awesome one you get it set up properly. Most of the time I leave the CS switch half way, there's a little bob, but it smooths out the roots and square edge rocks during climbs.
    Thanks Jd. Looks like they've got a new toy up there for the sights too. Just to keep this thread on track wonder what offset a ccdb needs ;-).
    Feb 2007
    Just mounted the pike!
    Sweet lookin ride there JD. Enjoy and love some feedback on the difference in new fork to old: increased travel, feel, weight, offset ;-)
    Feb 2007
    SMKNTRLS, unfortunately there's a forest fire near me (slide fire just north of Sedona Arizona USA). My town is engulfed with all the smoke so until I can see more than a mile down the road I won't be on my bike anytime soon. When I do I will post. There should be a huge difference since I coming from the stock Sektor fork.
    Feb 2007
    SMKNTRLS, the fork at 150 is perfect for me. The bike feels super stable at speeds. Only gripe is I wished the LSC would be active during trail mode. It was a bit stiff, sag was at 30%, but it was my first ride.
    My guess is a non carbon bike.
    Attached Thumbnails Attached Thumbnails Norco Sight with Pike - 150mm or 160mm?-imageuploadedbytapatalkhd1401051752.635545.jpg
    With the 160mm Pike
    Always liked a bit more fork up front....still rolls great...not slow at all. Also seen the 650B shoot out video last year where they ran a 160mm up front and found it worked well. Anyone else rolling it 160 up front?
    <a href="https://s818.photobucket.com/user/gstaz/media/IMG_3301_zpse225fb1c.jpg.html" target="_blank"><img src="https://i818.photobucket.com/albums/zz105/gstaz/IMG_3301_zpse225fb1c.jpg" border="0" alt=" photo IMG_3301_zpse225fb1c.jpg"/></a>
    Cane Creek will make the hardware for the shock they have all the spec's.
    Went with their lounge tune and found it just about right...just back off the low speed compression a quarter turn in the climb mode. PSI set at 170...rider weight 205lbs.
    <a href="https://s818.photobucket.com/user/gstaz/media/IMG_3298_zps4eb08d26.jpg.html" target="_blank"><img src="https://i818.photobucket.com/albums/zz105/gstaz/IMG_3298_zps4eb08d26.jpg" border="0" alt=" photo IMG_3298_zps4eb08d26.jpg"/></a>
    It will fit!! I have mine on order already!
    Attached Thumbnails Attached Thumbnails Norco Sight with Pike - 150mm or 160mm?-imageuploadedbytapatalkhd1401123471.156201.jpg
    Aug 2010
    Sorry but I just had to comment on this particular ride.
    It's freaking perfect! This is the bike I would have if I were wealthy.Every component...its like you read my mind building it. A perfect trail machine.
    What does this weigh?
    Quote Originally Posted by Sounders FC View Post
    jdcatnau Thanks for the feedback. I hope your out enjoying that ride. Now hoping they'll be something around when I'm ready to buy.
    Curious guys if I end up getting an aluminum frame because all that's avail or afford to start with and knowing this will probably be your frame for 3 to 5 years at least would you go with the piggyback CCDB or prepare for the future C upgrade with the CCDB inline? I'm a big boy who enjoys his CA Singletrack but still thinking more oil the better. I'm not doing crazy long downs but do like to hit whatever small jumps/drops I can create/are around. A couple miles of down at the most is my regular.
    NBD just can't come soon enough :-)
    Enjoy your rides!
    Smkntrls
    Feb 2007
    Enjoy your rides!
    Smkntrls
    SMKNTRLS, I am going for a 2015 carbon frame whenever they are available. My alum frame will be available. Talking to my shop, you can only order new carbon frames. Norco doesn't sell alum frames separately. I was also thinking about going with the alum frame.
    May 2014
    Quote Originally Posted by xmessenger View Post
    Thanks XMessenger! The bike is fantastic, totally love it. I weighed it using my bathroom scale and it came in at 25.8 lbs with pedals.
    I dig trails!
    Feb 2005
    Follow up on my original thread starting question.
    I set the Pike to 150mm. I did not try the Sight with the 140 Revelation, nor the Pike set at 160.
    The Sight with the 150mm Pike seems balanced, I can climb crazy steep stuff without a wandering front end, cornering is fine, the stiffness is great. Basically, a zero negative issue addition, IMHO.
    On a side note, I decreased the volume of the Monarch rear shock to make it more progressive, which was worthwhile for my riding. I lost a touch of compliance going through rock gardens, but gained a firmer midstroke to pump through terrain and in corners. And gained a more bottomless feel for hucks. I have not bottomed since the mod, and that includes some moderate jumping and drops.
    P
    Mar 2011
    What did you use to lower the volume? I'm debating doing that as well. Linkage is pretty progressive so bottom out is not an issue but am looking for more mid stroke support for pumping as well.
    Sent from my XT1080 using Tapatalk
    Jul 2015
    Sorry to revive old thread .. just mounted a 160 pike on my norco sight LE carbon .. CCDBI on rear . Trying about 25% sag . Pressure is low compared to recommended . I'm 175 kitted up and running 50 psi . No tokens .
    Seems strange but will ride tomorrow and see how it goes
    Sep 2015
    Is that 25% seated, or standing/attack position?.
    160mm on the Sight is fine. I'm running 160mm on a fork with a longer A/C lengths than a Pike. The Sight rear end is so soft at the top of travel and then firms up that I feel the 160mm fork pairs well with it.
    Jul 2015
    Little over 25% standing in attack position
  1. Fox 34 float 29 CTD 150mm or Rockshox Pike 29 150mm
    By mo6500 in forum 29er Components
    Last Post: 05-12-2014, 05:06 AM
  2. 2014 Pike 160mm Air Spring compatible with a 160mm Lyrik?
    By hafnz in forum Shocks and Suspension
    Last Post: 05-05-2014, 10:55 AM
  3. Replies: 0
    Last Post: 10-09-2013, 11:21 AM
  4. RockShox Pike 29er 150mm to 160mm?
    By nuckingfuts2 in forum 29er Components
    Last Post: 07-30-2013, 03:13 PM
  5. Pike 150mm vs 160mm
    By dutchct in forum Shocks and Suspension
    Last Post: 06-14-2013, 12:36 PM
