Norco Range 2014 Rear Axle O-Ring torn- Mtbr.com
Results 1 to 3 of 3
    SKL
    SKL is offline
    Oct 2014
    Hi,
    The rear axle of my 2014 Norco Range has an O-Ring on the left side ( where the Allen key goes in).
    The last time I had the rear wheel tyre replaced this O-Ring was torn so I screwed the axle back in with no ring.
    Now I don't know what the purpose of this ring, but on the next ride the Axle got loose and almost out its place.
    Does anybody knows what's the size of this O-Ring and what does it do ?
    Thanks,
    SK.
    I do not know the size of the O-ring or what it does, but I did have the same O-ring almost break on me when I was taking the axle apart to clean it. I went to Home Depot, bought a couple packs of assorted size O-rings from the plumbing department and went through them till I found a good match. That was last summer and since then the new O-ring has been working great.
    I dig trails!
    Reputation: Mr.P's Avatar
    Feb 2005
    The same happened with mine. Torn, used axle without it, axle came loose. It did take quite a few rides though.
    I'm guessing the O-ring helps keep the axle from unscrewing itself.
    P
  1. 2014 Norco Range Carbon
    By beaterdit in forum 27.5
    Last Post: 03-24-2017, 11:29 AM
  2. Rear Shock for 2014 Norco Fluid 7.2
    By jtfromla in forum 27.5
    Last Post: 04-22-2015, 10:06 AM
  3. Norco Range 2014 or 2013
    By Mystic_17 in forum 27.5
    Last Post: 11-26-2014, 12:57 PM
  4. NORCO Range 3 rear suspension pressure
    By moriel in forum Shocks and Suspension
    Last Post: 11-17-2013, 09:40 AM
  5. CK Griplock o-ring torn
    By Warp in forum General Discussion
    Last Post: 09-06-2012, 10:42 AM
