Norco Fluid Tire Question- Mtbr.com
Results 1 to 3 of 3
    Nov 2016
    I have the Norco Fluid 7.1+ and am looking to upgrade tires. Frankly, the stock WTB Rangers just aren't doing it for me. My question is what is the widest and skinniest size tires I could run? I am also running the stock Alex MD 35 650B+ 32H, 35mm TRS rims if that helps.
    Link to bike specs: https://www.norco.com/bikes/mountain...id-fs-71-plus/
    Sep 2015
    What about the Rangers isn't "doing it" for you?
    35mm would be a good fit for 2.6 tyres like a Nobby Nic or Rocket Ron. Going even narrower, you could easily run Maxxis DHF 2.5 WT and DHR2 2.4 WT on those for an aggressive option. Going wider, personally I'd stick to 2.8 however some manufacturers have released plus bikes running 3.0 tyres on 35mm rims.
    Nov 2016
    The Rangers just don't seem grippy enough for the way I ride. Maybe it's me but I want something a bit more sticky if that makes sense. I'll take a peak at your
  1. Norco Fluid HT+
    By Bikin' Bric in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 05-14-2018, 12:29 PM
  2. Norco Fluid 9
    By jrahm in forum 29er Bikes
    Last Post: 09-11-2014, 10:05 AM
  3. Norco fluid 7.1 ?
    By Nicool333 in forum 27.5
    Last Post: 12-27-2013, 01:02 PM
  4. Norco Fluid
    By Motocrosser86 in forum All Mountain
    Last Post: 09-20-2011, 07:54 PM
  5. Norco Fluid shock question
    By etacata in forum Norco
    Last Post: 04-04-2011, 08:35 PM
