Dropper on a 2017 Revolver FS 9.3 ... Has anyone done it yet?- Mtbr.com
Results 1 to 6 of 6
    Hi All, I have the Revolver FS 9.3 and really would like to put a Dropper post on it.
    Has anyone done this and what size dropper did you get? Overall length and amount of drop....
    In short...What will fit on a Large frame.
    Cheers...
    No one can answer this question without knowing a few pieces of information:
    -what is the full height to your desired pedaling position.
    -What is the maximum insertion depth of a seatpost for your frame. This depends on the frame and linkages. Basically you can take your existing post and see if it goes all they way down before hitting something.
    -what is the minimum insertion length of the post you are interested in
    -what is the overall length of the seatposts you are looking at
    -what is the length of the drop you are interested in, 80mm, 125mm, 150mm. The longer the drop the more seatpost length needs to be inserted into the frame.
    look at these drawings: https://www.pnwcomponents.com/pages/measurements-page
    Basically, there will be a range available to you between the minimum insertion height and the maximum insertion height that the overall length of the seatpost needs to fit within to achieve your desired seated pedaling position.
    Apr 2014
    Hi there, I got the KS Lev 31.6mm / 400mm / 125mm drop and seems perfect.....this is on a 2016 7.1 FS however.
    Just measure how much seat you have sticking up from the frame currently and make sure there is enough for that + the minimum insert and you'll be fine
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by jmaynard11 View Post
    Cheers...
    Bump. What did uou end up getting?
    Thanks for the responses. Got busy with daughters softball and sons racing and put this on the back burner. I was looking at the crank bros with a 125 mm drop but couldn't pull the trigger. Also started thinking that I'd like a new fork before the dropper.
    Cheers,
    NedwannaB
    Longer travel or different fork? I think the Recon can be moded to 120.
  1. Replies: 23
    Last Post: 06-21-2019, 12:06 PM
  2. Replies: 15
    Last Post: 12-23-2016, 08:43 PM
  3. Replies: 12
    Last Post: 11-21-2016, 08:14 PM
  4. Replies: 4
    Last Post: 11-03-2016, 06:56 AM
  5. Electronic Dropper post - Anyone has one yet?
    By Loll in forum California - Norcal
    Last Post: 03-17-2016, 08:11 AM
