Do 29er wheels fit on a Fluid 7 HT+ or Torrent 7 HT+?- Mtbr.com
Results 1 to 5 of 5
    I'm thinking about getting a Fluid, but would be nice to have the option to put 29er wheels with 2.4" on them. Anyone know if that would work?
    The shop where I bought my frame for the torrent told me that they can definitely run 29er wheels. He said it's only slightly higher. I was thinking about dropping my fork to 120 and running 29er wheels for xc races but then I remember the head tube will still be 67.5. I'll stick to my rigid ss for the fast rac es.
    Sent from my SM-G900T using Tapatalk
    Reputation: LyNx's Avatar
    If you go into the PLUS forum you'll find loads of info on the whole PLUS thing, including a lot of bikes listed that will do conversion, which ones etc. Basics though are that a 650B 2.8" is roughly 28.25" tall and between 63-70mm wide and most any frames that will fit one will most likely also easily fit a 29x2.4" setup as well, if your frame will take a 650B 3.0", then most definitely no issues with a 29er.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    But you're also right in posting a question about a NORCO bike in the NORCO forum. Still got your answer... I think you totally fine running a 29er in your fluid.
    Never said he wasn't, just offered someplace with a load more info on the whole PLUS thing and doing conversion either way
    Quote Originally Posted by kikoraa View Post
  1. Torrent w 29 wheels?
    By kamper11 in forum Norco
    Last Post: 05-13-2016, 01:34 PM
  2. Replies: 1
    Last Post: 03-28-2016, 08:57 PM
  3. Replies: 0
    Last Post: 06-19-2015, 12:53 AM
  4. Cyclops fluid trainer fluid replacement
    By trailbrain in forum Tooltime
    Last Post: 02-11-2014, 10:30 AM
  5. Reynolds Carbon AM 29er Wheels-Crosspost in Wheels and Tires
    By bicyclemark in forum 29er Components
    Last Post: 06-14-2013, 05:32 PM
