2020 Sight- Mtbr.com
Page 1 of 4 1234 LastLast
Results 1 to 200 of 604
Thread: 2020 Sight
    Sep 2017
    2020 Sight
    These look pretty sweet! Closer to the Range territory now. Debating whether one of these should be my next bike.
    I have a 18' Range XL that I increased the travel in the fork to 170mm(same as the 19' models).It has a HA of 65, STA 73.2, Reach of 479mm, TT is 669mm, Wheelbase of 1253mm. The 20' Sight has a HA of 64, STA of 78, Reach of 515m, TT 649mm and Wheelbase is 1301mm.
    The biggest differences I see is the STA is 5į steeper and the wheelbase 48mm longer. I haven't ridden a bike with that steep of STA, does it make that big of a difference climbing?
    I ride the North Shore, many of the trails have tight turns, I already find the XL Range challenging in some of the techy, tight and steep corners, cutting it wide as possible to get through. What are these longer wheelbase bikes like in the tight corners?
    Personally excited for this bike to appear in local demo fleet, and at least on paper(all the online launch reviews) - it sounds like the bike im looking for. 2014 Sight was the real "game changer" bike for me. Went to a Spot Rollik 557 in 2017 which took the Sight to that next level. THIS bike sounds like the bike I'm looking for as Im ready to go back to 29er (i rode full suspension 29ers when frankly pre 2014 - they mostly sucked - but i still liked the big wheel).
    Reputation: In2falling's Avatar
    Jan 2005
    Quote Originally Posted by Graveltattoo View Post
    I have ridden a few of the "new geo" bikes with steep STAs, only place I found the steeper STA to be of benefit is when the climbing gets really steep.
    You will definitely feel an extra 50mm of wheelbase in slower tight twisty stuff, it's going to turn like a 747 taxiing down LAX.
    All this "new geo" stuff is all a trade off. Longer slacker will make it more capable/stable at speed in flowy rough stuff. Then make it tiring work in slow twisty stuff.
    Sep 2019
    Anyone know what a Stan's Flow D rim is? Nothing on Stan's website by that name. Mk3? EX3? Some kind of OEM?
    Jul 2014
    Have an A2 or order, should have it in a few days. I think it is supposed to have the Stans D whatever it is...
    Aug 2018
    Anyone know if the AL frames have a threaded bb? I can't find it in the specs.
    Sep 2014
    The Flow D rims are OEM, similar profile to the S1 rim but with some additional bracing within the rim (maybe to account for lower spec alloy???). 634g for the 29, 584g for 27.5 so not light (S1 29 is 584g)
    Threaded BB on the A1, also I weighed the large A1 with tubeless setup and it was 15.5kg
    Sep 2019
    Quote Originally Posted by Anth08 View Post
    Thank you muchly for the info! Threaded BB is good news at least!
    Jan 2016
    Odd but this bike seems not to be getting any attention on the forum---the Optic seems to not have big interest either.
    Sep 2019
    Quote Originally Posted by pctloper View Post
    Maybe because Norco released both a bit late relative to all the other big players? People's interest has moved on a bit?
    I know this is being critical, bit I'm trying to figure out why the sight carbon frame is so much more expensive than the Optic? Only difference is 25mm travel and carbon seatstays. Puts the sight carbon builds out of my price range.
    Day off tomorrow, going to head down to the local shop and fondle both (Optic and Sight).
    Aug 2018
    Threaded BB eh, damn, now I might just have to get one....
    Feb 2005
    Quote Originally Posted by percivilla View Post
    Having ridden the new Sight... it's phenomenal! I'm incredibly excited to buy one, coming off a very similar bike comparing dimensions and angles (the Transition Sentinel), but on the trail it just does everything better... climbs better, more traction, easier to move around, faster...
    The frame only option also has an X2, which is definitely has an added cost associated.
    Reputation: ocnLogan's Avatar
    Aug 2018
    Wait, I thought the new sight had a PF BB? Youíre saying the aluminum ones have a threaded BB? That was literally the only thing I had ďagainstĒ it (ie, my only preference it didnít have).
    And, Iím confused why this isnít getting more talk as well. The sight seems perfect to me. Slack hta, steep sta, and chain stay lengths adapting to the size of the bike/rider... all with a reduced offset fork, and standard 4 piston brakes on each build kit? Whatís not to like?
    I still need to find one to demo, but assuming that goes well, I may be trying to find my way into one sometime in the future.
    Sep 2014
    Press fit on the carbon frames, 99% sure the A1 had a threaded BB (external cups with tool interface both sides).
    Iím stuck on the sizing, I rode the large, Iím 174cm so on the limit of what the charts say for Medium. The large felt really long and I think the wheelbase and Reach on the M will more manageable on my local tracks however the short ett has me beaten, itís about 25mm shorter than my current M trance. I guess people just pedal in a more upright position with the steep seat angle.
    Feb 2005
    Quote Originally Posted by ocnLogan View Post
    I've never had an issue with a pressfit BB, last one was on a 2018 Range carbon with Raceface Next R cranks. I made sure to get a Wheels BB because the BB cup is also the bearing race, allowing them to use larger sided ball bearings... not a single squeak.
    As far as the Sight... there's a lot to like! There's a bit of a learning curve with the reduced offset fork and the handling (front end grip and staying centered), if you haven't ridden something similar, but I couldn't say much more than "it's a great bike" and "I want one" after riding it.
    I too rode a large and am 174cm tall, I felt like it would be a good size if I did enduro racing and all out speed. I too felt like it was just a bit long for the tighter trails I rode. I'll likely be getting a medium... but I'm wondering if running a narrower bar than my usual 800mm (same as the demo), as the setup guide's suggested a 760mm, and maybe a 35mm stem would help this out.
    Don't decide on a size based on ETT, your position when standing on the pedals will be more of a factor and likely feel feel right, you will pedal more upright and will likely feel more comfortable doing so.
    Jul 2014
    New Sight A2
    Aug 2018
    Quote Originally Posted by MikeyOrange View Post
    A PF BB isn't a deal breaker to me (my current bike, a Kona Process 153 29'er has them), its just that a I'd prefer a threaded BB. Carbon is out of my price range, so I'm happy to hear that the AL versions have it.
    I demo'd a Transition smuggler in the spring (and a number of other bikes), and the was blown away with how the bike cornered. I felt like the smuggler railed berms much easier, and overall was more confidence inspiring than even the longer travel bikes I demo'd. Compared to the other bikes I rode that day(and my own bike), the biggest difference was the reduced offset fork (3 out of the 4 bikes I rode had the same HTA, and chainstays within ~5-10mm of each other).
    Of course, that's the only bike I've ever ridden with a reduced offset, and it was only for like 45min-1hr. But I'm interested enough in the handling difference to try another.
    I'm also a bit between sizes. I'm 6'1", and I fit into the grey area between the L and XL. But looking at the XL Sight, compared to the L Kona I'm on right now, there is a massive ~90mm difference in wheelbase. That said, I do feel at times that I should have upsized to the XL Kona (again, I was right between sizes). Definitely want to demo both sizes before I commit.
    Sep 2019
    Yeah, I'm probably just being nitpicky because I can't justify the cost of carbon one 😆. Good point on the X2 as well. When you cross shop against other brands they are still a decent value, the Optic is just a bit better of a deal for the price it would seem.
    I am happy for sure that Norco is doing an Aluminum version of this bike! I'd rather spend the difference on better suspension than frame material. I'll probably end up with the A2, not sure I can stretch to the A1.
    At 6'4" I'm pumped about the geometry! I've always been annoyed trying to climb with my butt hanging out over the rear hub...
    Jul 2014
    I'm building my sons medium A2 later today. Go a sit on a large, it's just too big for him. Seated he can ride it but the reach and wheelbase are so long it will be too unwieldy in tighter corners. He is 172cm and still growing so I was hoping a large would have been ok, if he keeps growing I'll worry about it then.
    Seat post down the medium is like a large of many other bikes.
    Jul 2014
    Jul 2014
    Oh, and it is HEAVY... I can only imagine how heavy an XL bike would be. Didn't get it on accurate scales but hand held scales it was a bit over 16kg with pedals and bottlecage. Over 35 and a half pounds for seppos.
    Aug 2018
    Quote Originally Posted by Duane. View Post
    I read a review/first ride of the carbon version, and they said it was something like 33lbs (iirc anyway, and I think that was size large). So I'm not surprised that it is heavy.
    That said... I'm not a weight weeny. My Kona is ~35-36lbs (size Large, AL frame), so I'm expecting the weight to be similar-ish to be honest.
    I may care more... but I'm the lightest person in my riding group (which, unfortunately, is not saying much:P), and I'm always waiting for my buddies on the climbs anyway.
    And, IF I get one, I think I may build up a frame, as I'm not very smitten with the parts on the A3 version. I'd more likely transfer everything I could over from my current Kona. It looks like everything other than the dropper would fit (and of course, a threaded BB). Oh, and I'd need to change my fork to a short offset technically.
    I... just wish the frame only option came with a better color. The light metallic looking blue isn't exactly my style.
    I'm hoping one of these is in pinkbikes field test this year, or maybe the BikeMag big group test. I'm curious to see what reviewers think of it. Then come springtime, I should be able to grab a demo, and maybe make a better decision then.
    Feb 2005
    Coming off a relatively light Sentinel (30.66lbs with pedals) and not knowing the weight of my demo large Sight; I would never have guessed it weighed much more... it certainly doesn't feel like it while pedaling and my climbing times were about my average. It definitely didn't feel slower.
    I would be shocked to not see this and/or the Optic in the bible of bikes 2020 as part of their bikes they can't talk about yet.
    Feb 2013
    I think I read that it will be in the new Bike Bible tests. I'm looking forward to that as their review of the 2017 Sight led me to buying one. I love it but would like to demo the new one. But frankly my current Sight feels perfect for my riding style.
    Sent from my LG-H872 using Tapatalk
    Sep 2019
    Might have to see if the shop can do a custom build. Pricepoint wise I'm comfortable around the A2 level but don't really care for the build. Basically the Range A1 build is perfect to me (except with air superdeluxe instead of coil), and should be a similar pricepoint looking at the $100 difference in frames.
    Weight doesn't really seem too far off other bikes in the category?
    Aug 2018
    Yeah itís a shame the frame only is that blue. It isnít bad, but I wouldnít loved the matte green or a nice black.
    Sep 2017
    Anyone ride a 18' or 19' Range that has demo'd the 20' Sight? How did is compare? Pro's? Con's? Sexy looking bikes!
    Feb 2005
    I rode a heavily upgraded 2018 C3 29er for a summer and demoed a 2020 Sight for a bit. The Sight was probably a little large, they only had a Large to demo and I usually ride a Medium, and I could tell that it was a longer bike on a tight trail. It did require a little more input but it never felt unwieldy and the rear end was easy to pick up and move around.
    The Sight just seemed to do everything better, but I didn't get to ride it in anything chunky. It definitely climbs and pedals better, has more front and rear traction, and was faster over the terrain I rode by a fairly large margin. It also felt a lot more playful, I always felt like the Range wanted to monster truck and go straight over everything...
    I feel like the new Sight is definitely a more complete bike for the entire mountain and is on my new bike wishlist... just have to decide colour, suspension and buildkit, I hear there's at least one more higher end buildkit and waiting to see it.
    Sep 2017
    Thanks for the feedback! But damn you MikeyOrange!😋I was hoping that you'd say there was a slight difference and not worth it......
    Reputation: islander's Avatar
    I was trying to get my head around the '20 Sights geometry, then I realized it is a reduced offset fork spec on the 27.5 ad 29 models. My understanding is that you can't do a direct comparison between head angle of 2 bikes with different fork offsets. SO, the 64 HA isn't actually as slack as it sounds....right? Surprised nobody has mentioned this geo much so far as it seems like Norco is trying to be pretty progressive here.
    Jul 2014
    My son has just gone for a short ride, easy xc terrain, but he is saying that the new one rolls so much faster (his old one was 650b so to be expected) but he is saying it climbs better despite the added weight and is more poppy, which surprised me. Nothing but praise so far.
    His old bike is a 2019 Sight A2.
    Aug 2018
    Quote Originally Posted by islander View Post
    A reduced offset fork reduces the wheelbase some, which reigns in the wheelbase a bit compared to a bike with a longer offset fork.
    However, a reduced offset fork increases the trail, which from what I understand, has a somewhat similar effect as slackening the head angle (and also making it so the bike likes to "stick" to the line its carving in a turn). It also brings the tire farther under the rider, weighting it more. Now, I have no idea how many mm of fork offset equals how many degrees of head tube angle, but from my reading, that's the basic idea behind it.
    My one time on a reduced offset fork, was great, I felt like I could finally corner as well as I usually describe my skills to my friends .
    Also, my current bike has a HTA of 66 degrees, and that doesn't ever feel like "too much" for me. At first glance, and on paper, the HTA of 64 degrees does sound a bit crazy, especially compared to a few years ago. However, I grew up riding dirt bikes. And dirt bike geo has had HTA's in the 62-63 degree range for what seems like forever, and those feel totally natural to me.
    I'm curious how far the "long and slack" trend continues. I'm doubting that the HTA's will go beyond what we see in DH or dirt bikes. But in terms of length? I'm not sure. At least now we're seeing chainstays lengthened on larger sizes. And the bulk of a the "reach" that has historically been in the 80-120mm stems that came on bikes, has now been moved to the frames. Now that steeper seat tube angles are pushing the reach out even longer to keep the effective top tube length the same. But now that that is more or less common, I don't think that the seat tubes can get much steeper, so I'm not sure how long the trend can continue.
    Reputation: F.N.G's Avatar
    Does anybody know if the 2020 sight can be run with 170mm for? 37mm offset?
    Aug 2018
    170mm is only 10mm overforked. And the 27.5in wheeled model has a 37mm offset fork on it from the factory, right?
    Usually you can overfork a bike by 10-20mm without anything weird happening, so I'd imagine it would be fine. If you wanted to go more, you may play around with an angleset, as that would bring the BB height closer to factory height.
    And, as for a 37mm offset on a 29'er? I mean, it would work fine, but would further increase the trail. That would make it tuck into turns really well, but not how it would ride on non-high speed trails.
    Thx, I mean the 27.5. I have a new Fox 36 grip 2 170 mm 37mm offset and like it. Would like to transfer it over to the Sight without lowering it.
    Aug 2018
    Quote Originally Posted by F.N.G View Post
    Oh, in that case, the change is only 10mm of travel then. A 170mm fork will further slacken your bike by ~0.5 degrees, which would give it a HTA of ~63.0 degrees.
    Also, you can change the travel on your fork fairly easily. The part itself is just a new air shaft, which usually seems to be in the ~$30-50 range, and it is easily done during a normal service of the lowers.
    Sep 2014
    Just read the Pinkbike field test for the Optic and they said the shimano rotors are resin only, turns out the Sight C2 also comes with resin only. Pretty poor for the price
    Rotors can only handle resin pads? Or brakes come with only resin pads from the factory?
    Sep 2014
    Quote Originally Posted by cachaulo View Post
    The info I have from Norco is RT54 rotors which are resin only but the bikes in reviews seem to have RT64 rotors which handle metal pads, also Shimano donít list the RT54 in 203mm so hopefully my info is wrong
    Sep 2019
    Got to check out an A2. Seems like a good spec for the money. Think I'd prefer rockshox but I'm sure the Rhythm 36 is decent. No riding impressions but the sales guy mentioned that he's getting one and so are several others at the store.
    It's not a lightweight that's for sure, the XL A2 is pushing 35lbs, but the guy I was talking to had ridden one quite a bit and said it feels awesome on the trail and climbs better than it had any right to.
    Are the frames heavy? Or are the builds making them heavy?
    Sep 2019
    Bit of both I'd say. The builds all favour toughness over weight with DH focused parts. The A2 has a beefy wheelset and suspension, and an OEM cockpit. Going tubeless will save some weight. Norco is marketing it as a bike for "sending" whatever you want so they're smart not to put any weedy parts on it.
    I'm aiming to be doing a fair bit of shuttling and bike park on it so it doesn't concern me at all. If I was doing mostly trail riding I'd be looking at the Optic.
    I should clarify that "pushing 35lbs" was an educated guess by me and the guy at the shop. We didn't hang it on the scale. Higher end carbon builds should shave a few pounds.
    The Large Carbon that Pinkbike tested was 32lbs so not unlikely that the A2 with lower spec parts and tubes would be a couple pounds heavier.
    Jul 2014
    My sons A2 with pedals and bottle cage is 36 pounds! It's no lightweight but I need to slow him down so I can keep up somehow.
    As parts need replacing I will upspec it. The wheelset is quite heavy.
    Jul 2014
    These days, a 35-36# Aluminum almost enduro bike with an NX cassette sounds pretty normal to me.
    Aug 2018
    Yeah, the weight seems normal to me. Usually an AL frame is somewhere around ~2lbs heavier for most bikes/brands. So I'd say ~35lbs is probably pretty accurate, depending on the rest of the spec. Smaller frame sizes may be a touch lighter.
    That said... I'm not worried about weight, especially for a bike like this. I'd rather it be more durable, which from the weight, it likely will be.
    anyone have some rides on this bad boy? Possibly even a Sight vs Optic comparo?
    Sep 2019
    Agreed. Every price point looks to be a bike you can charge anything on.
    I'm honestly a bit confused why Norco didn't put it in their Enduro category. Every aspect of the spec/build is Enduro. I guess they're suggesting that it climbs better than most Enduros by calling it all mountain?
    Reputation: eh steve's Avatar
    May 2012
    I'd bet it's because they actively list prior years on their site. So putting the new Sight in enduro would mean either putting the old one in there too (which it's not) or having it split between two categories.
    I have to wonder if a site update is coming. Listing all builds and 3 years of models is busy AF. Plenty confusing without splitting a model between categories.
    Most manf just list their current model for each bike. No clue why Norco decided to list their lineup the way they did.
    Sep 2019
    Quote Originally Posted by eh steve View Post
    It is a busy site for sure. It's kind of annoying how when you click on a model, you then have to scroll waaay down past all the other models to see the specs. I know, first world problems. I also wish companies would photograph their bikes outside, in natural light, not in a white room.
    Commencal has a nice site design. Easy to navigate. I like how they also show the whole bike from a few different angles.
    Anyway, topic drift...
    Out of curiosity, has anyone tried a Rhythm 36? Can't find much out there on them. Apparently it's an earlier version of the grip 2 damper with less adjustability and a slightly heavier lower?
    Aug 2018
    The term Enduro to me is really just a race version of all mountain riding. To me they are totally the same style of bikes. I think itís just them saying this isnít their ďraceĒ bike, but rather their long travel trail bike for the whole mountain.
    Which leads us to...
    Iím betting the range will be updated sometime in the next year or so, and will be something we may currently call a ďsuper enduroĒ style bike. Aka, 170-180mm of travel bike intended for people racing enduros. And I bet that bike will get the enduro moniker in their lineup.
    Sep 2019
    Yup. Different guy I was talking to a previous time at the shop was saying that the 2021 Range will be a 170ish bike to compete with the RM Slayer. Basically a park/pro line style bike. I'd bet it'll be HSP like the Aurum.
    Jul 2014
    Agree, I'm expecting a slightly reduced travel HSP with a single crown and eagle cassette.
    Since you brought the website up, I noticed today the black Carbon bike disappeared. And whatís the dealeo with the womenís lineup? Is it just considered a womanís color or are they specíd with womenís components like Specialized did?
    I stopped by a dealer today and they called the sales rep for Norco and said I should be able to get Black Frame only around December. I hope thatís the case....
    Aug 2018
    I read some press material, that said the women's bikes were the same frames, but with different finishing kits (ladies saddle, potentially narrower bars, etc). However, I just compared the builds of the A3, to the A3 women's on the website.... and I couldn't find any difference other than color.
    There is always the possibility that the website is wrong, and also the possibility things that are technically the same part, may be different (ie, fork/shock tunes meant for lighter weight riders).
    So, I think that technically it should work to buy a women's model... but I'd want to double check before I committed to doing that.
    Sep 2017
    From Norco.....only difference is saddle, grips and frame colour.
    May 2012
    Yep. If you plan on changing the saddle and grips, there is no downside to a "women's" norco model. At a local Norco dealer employees are considering the "women's" colours for their builds.
    Personally I hate yellow, so I'd take a women's C2 over the men's.
    I wonder how many take-off women's saddles norco dealers have...
    Sep 2019
    Yeah, if I had the means for a carbon build I'd be going for that metallic teal C2!
    Reputation: shlotch's Avatar
    Nov 2017
    I'll be in my bunk.
    I ride a '18 Range C2 29er and I love it. The new Sight looks like a bike that's similar, but slightly better in almost every way. Can't wait to try one out.
    If only a person could get his/her hands on one of those black and red frames as a frame-only option as opposed to that Ironman colour scheme. And, selfishly, I wish they'd built it around a 205/60 shock size so I could try it with the coil from my Range =]
    May 2012
    Quote Originally Posted by shlotch View Post
    Can't get the black/red as frame only, but also no build option with the red Lyric Ultimate.
    Want the bike in the promo video? Sorry, we don't offer that build.
    So, this color option will NOT be available? The rep that told my Norco dealer was incorrect? Are there any options to get frame only in another color other than offered on website?
    May 2012
    Depends what you mean and I don't have any inside info. The black and red frame is available in the builder (requires full build) but it shows a black Lyric as the only RS option. Maybe they'll offer more suspension kits in the future? A red Lyrik is available on the Torrent HT S1 build.
    The black/red frame doesn't appear to be offered as frame only on the site, but maybe the local rep can get you one instead of the ironman? Past years are the same, they offer 1 colour for the frameset option on the site. What your local dealer can actually get for you... I dunno.
    As for reps and info...
    I had a Norco rep (through their website) state there wasn't enough interest in custom alloy builds to have that as an option for the Sight.. low and behold the 2020 Sight alloy is available in custom alloy builds. Obviously that was a lie. Could have said, "Currently we do not offer sight alloy frames as custom builds or frame only." That would have been truthful and I wasn't asking about future models.
    Feb 2005
    To get the black/red frame you have to go through the "Build Your Ride" option which is available in Canada and the US. Just about to place an order at my local shop, sounds like if you want a Carbon Sight you should do it soon or it'll be April/May instead of January/February... just deciding on the build kit now...
    Feb 2005
    Depends on when the question was asked, what the exact question was, and if you asked before the 2020s were announced; they wouldn't have been allowed to say anything to you, unless you were employed by a Norco dealer.
    May 2012
    Yeah, obviously they couldn't disclose anything, but they can do that without lying (like my suggestion in my post you quoted). "Sorry, no custom alloys" would have been correct and truthful. "Not enough interest to warrant it" was a lie and unnecessary info.
    Maybe I was (unwittingly) hitting too close to home on the 2020 stuff, so they felt a need to mislead me? I was asking about 2019 models though (I also asked about colourway availability for the carbons, confirming they were done the 2019 run and what I saw for available colors was it). What I really wanted was an alloy frame with dvo suspension and gx drivetrain. This was before the ripmo AF was announced.
    Sep 2017
    You're also assuming that this "Norco Rep" actually had accurate information.
    Sounds like they didn't word it the way you liked, but you need to let this go! Hop on your bike and go for a wicked ride instead!
    May 2012
    Hard to get tone on the internet, I don't really care and yeah quite possibly bad info on their side. My point was that you can't necessarily trust what is said from someone "official" (I thought in context of others talking about what they were told that would be obvious).
    Wonder if I ask about an alloy Optic they'll tell me there's "no demand" . Even if the new Sight climbs like a dream, it's a lot of bike. So far the people around me buying them are replacing pretty big bikes (2018 Range Carbon, 2018 Spesh Enduro, Ripmo etc).
  67. #67
    Yeah I was thinking about a low spec Optic but no alloy version makes it a tough sell for a second (or third) bike for me.
  68. #68
    150 mm rear doesnít seem like a big bike to me...Perfect balance for all mountain riding.
  69. #69
    Aug 2018
    Iíd love to see an alloy optic as well.
    It seems like manufacturers that have serious geometry short travel 29íers have for some gone away from having aluminum frame options.
    Transitions smuggler is pretty similar, and used to have an AL version... but itís all carbon now. Same with the Whyte s-120.
    So perhaps they felt no one wanted an AL frame optic?
  70. #70
    They do make a budget friendly aluminum Optic, they just call it the Fluid FS. It doesn't get all the goodies like the piggyback shock and different chainstay lengths for every single size, but overall they are remarkably similar. It's not quite as long, low, and slack but the seat tube angle is the same and the rest isn't off by much.
  71. #71
    Reputation: kragu's Avatar
    Travel isn't the only thing that makes a bike "big". The wheelbase has at least as much to do with a bike feeling big, as does reach. A Norco sales rep even described the bike as a "big bike".
    That said, I'm planning on rockin' this thing everywhere.
  72. #72
    Yep - the only reason Norco isn't calling this an enduro bike is because they'll be updating the Range next year and nobody's using the term "freeride" anymore. The SB165, RM Slayer, and new Range will basically be in that category, which is frankly too much bike for racing all but the gnarliest enduros.
  73. #73
    Sep 2017
    Anyone else taken one for a ride? I'm trying to justify getting one, but I have a 19' Range and a big part of me is being silly!! Are the Geo's that much better to warrant spending more money?
  74. #74
    Apr 2014
    I suspect that this is partially because of the weight of these burlier short travel bikes. The Optic isn't that light as a carbon bike (31 pounds in the C2 version according to Pinkbike's fieldtest). A 33-34 lb 125mm bike starts to seem pretty heavy.
    Just to add to the thread: I'm really excited to demo the Sight and Optic. I suspect that given the geometry, the Optic will be closer to what I need even if the Sight is closer in travel to my current bike. I'm excited for both though.
    One reason I suspect that there isn't much chatter is that just not many people have been on them given the timing of their announcement and stocking. They're on the top of my "to test" list for next year.
  75. #75
    Aug 2018
    Yeah, there arenít any available to demo in my area.
    Iím really interested in riding the new sight, and new ripmo af. The travel for the bikes is very similar, but the ibis doesnít change the chain stay length. The different suspension platforms may feel very different though.
    For short travel bikes I want to ride the new tallboy, the optic, and the rift zone.
    Iím really glad we are seeing more nice geo short travel bikes though. The fact that the Marin rift zone comes in an alloy frame is great news for the segment. I just wish they offered a frame only option.
  76. #76
    Sep 2017
    I think I'm going to get the Sight. Trying to decide on the Rockshox of Fox suspension?
  77. #77
    May 2012
    Quote Originally Posted by aerius View Post
    I dunno man, it's a pretty different bike aside from specs even. The Fluid FS has a higher bb, so if you overforked it (to match an Optic) it'd be even worse. I guess you could use an angleset headset to slack it out and drop the bb (and steepen the seat angle after overforking), then the wheelbase would be similar.. it's definitely a different geometry. Whether it rides differently? I dunno.
    Ignoring the geometry difference, I don't like the top end build on the Fluid FS (a1). It's around the same build level as the 2019 Sight A3 (similar original msrp and similar level components). For me to be interested in a Fluid FS they'd have to make an A0 model. Better hubs, better brakes, add a DHR II to match the DHF etc.
    The new Optic is the replacement for the old Sight carbon. The Fluid FS is downspec and marketed as entry level (plus no frame only option so you can build your own spec). The Optic is carbon only (though the C2 does look like an amazing bang for the buck for carbon build) and the new Sight is the replacement for the old Range.
    There is no replacement for the old Sight alloy. The obvious replacement would be an Optic alloy. Mike Levy commented, "Hopefully a less expensive alloy Optic soon..." on the PB Field Test Editors' Choice.. so maybe that's a hint?
  78. #78
    May 2012
    Personally I'd go with one of their off-the-shelf builds. The A2 is all good enough components (nothing I'd want to replace immediately.. nx shifter eventually, maybe). The 370 hubs are basic but solid. Code R brakes are great.
    The A1 build is awesome. Dt 350 hubs, lyric ultimate, code rsc brakes, full GX drivetrain (including cassette, which is costly to upgrade from NX after the fact). I think it's Norco's highest end OTS alloy build yet.
    I don't like the two drivetrain options on the custom builds right now. The SLX/XT drivetrain itself is fine, but I don't like the shimano hubs and I'd prefer code r brakes to the SLX. X01 above my pay grade.
    Thing is, with the cheapest custom alloy build you can configure, it's as much as an A1 (at least in Canada, no clue if the US builder shows the same). IMHO the A1 is better (better brakes and hubs for sure).
  79. #79
    Sep 2017
    I'm definitely leaning towards the A1, but also considering the C2. Thus the question about the suspension.
  80. #80
    May 2012
    Sorry, I don't have anything useful on one suspension setup vs the other. I know the X2 is good (plenty of friends run that and have upgraded to it) and I have 0 knowledge or experience with the "RockShox Super Deluxe Select + DebonAir". I don't think you could go wrong with either fork, but it's not like I've ridden both (Lyrik has new RC2.1 with improved rebound circuit, Fox 36 has new GRIP2 damper with 4 way adjustment).
    By looking at the rest of the build on the C2 it appears they put the money into the suspension over the drivetrain (making smart choices on the drivetrain). For me I'd go with the A1 for the brakes and hubs. I have no legit info on the Shimano hubs (could be fine) but I know the dt350 hubs are solid. I also prefer SRAM brakes (some prefer shimano, to each their own). Suspension wouldn't play into it for me, but mainly because I'm ignorant and assume they are going to be similar.
  81. #81
    Aug 2019
    I'm def liking the C2 build, although I wish it had XT brakes! I did notice it looks like the shock doesn't have a climb switch on it... I'm a little nervous about that.. I would want to ride it..
  82. #82
    May 2012
    Quote Originally Posted by Windband View Post
    Good catch. I forgot the 2-way switch is optional on the X2. Yeah, definitely would want to try it to decide if it's right for what you ride.
    I have a friend with an X2 on his '18 spesh enduro. I have yet to see him touch it. That being said, when we ride it's pretty much all singletrack and punchy climbs.
    I have a DPX2 on my prev gen sight and I rarely use the 3-way switch. There's a smooth gravel climb to the parking lot at the local trails I will sometime lockout for at the end of a ride. I'll also go full lockout when riding on pavement with the Mac Ride (and a 40lb kid on my top tube). I used to use the trail setting for a technical switchback climb, but with my sag set to around 27% I don't need it. I was using it to stay higher in the travel, not to fight pedal bob.
    If the new sight pedals and climbs as well as people are claiming I don't think a climb switch is needed, but yeah, I'd want to try it before dropping 5K on it. The optic not having a climb switch was a shock, but apparently it doesn't need it.
  83. #83
    Aug 2019
    It makes a lot more sense on the Optic, since it's only 125mm. The Sight being an aggressive AM bike at 150mm, makes me prefer to at least have it there... I have a brand new DPX2 on a '15 Intense Tracer. I love it, but do use the switch for forest service roads and such. On the actual trail I don't use it at all. I think those X2's ride a bit softer though... I guess you can always set it up on the firm side. I would like to demo first though. And of course you can always replace it with something else later!
  84. #84
    May 2012
    Hopefully you can actually demo one. Looks like parking lot demos around here until a friend takes delivery on one (and lets me try it) or a local shop gets demo/rental units. Looks like both of those are a long ways off (like 6 months away).
    The enduro-mtb review on the C2 said:
    "The rear suspension generates a lot of traction on the climbs without excessive pedal bob, which is a good thing, since thereís no climb switch on the shock. Overall, the Norco is a brilliant climber and the front wheel always remained calm and in control on technical climbs."
    But then they put no climbing switch as a con (with zero context). Į\_(ツ)_/Į
  85. #85
    Aug 2019
    Well we'll see how it goes. I live in the PNW, US, so we won't be doing a ton of riding, as winter is coming. I'm not planning on buying a new rig until maybe late summer/early fall. Hopefully I can demo some things before then. I'm also looking at the Nukeproof Mega 275...
  86. #86
    May 2012
    I'm in the PNW as well (but Canada). Yeah it's wet, but that's not what's stopping me. Friends are going riding today and I can't due to a broken toe .
  87. #87
    Aug 2019
    Sorry to hear that. We've been dry for a few days, so we prob could go tomorrow. Normally when it's real wet I don't like to jack up the trails with too much riding.
  88. #88
    Apr 2017
    My Norco dealer just told me that they have decided not to sell the 2020 Norco sight AL as a frame only option. Anyone hear the same?
  89. #89
    Aug 2019
    Quote Originally Posted by Shredur View Post
    You should be able to order from Norco direct. Their site says "add to cart"... IDK.
  90. #90
    Apr 2017
    Yeah it still shows on the website. Just sold out. I donít see any reason why they would decide not to offer it.
  91. #91
    Aug 2019
    Not sold out, the 2020s haven't really started shipping yet! They just launched. Give them time to get inventory!
  92. #92
    Aug 2018
    I havenít checked with my local dealer yet.
    But Iíd assume you can order online from norcos website, and it would be delivered to you through your dealer... right?
  93. #93
    Apr 2017
    Should be able to. I was just trying to buy one at my local dealer and they told me that they were discontinued.
  94. #94
    Apr 2017
    I just confirmed with Norco that there will not be an AL frame only option for the 2020 model year. Ripmo AF it is then!
  95. #95
    Aug 2018
    Norco itself, not a local dealer?
    I had emailed Norco support a week or two ago about fitment, and post mount dimensions and got a reply pretty quickly. So I just replied to that same thread, and asked if they will have a 2020 AL sight frame only.
    Guess we'll see if I get the same information back?
    And yeah, if this is true (having no frame only option) would leave me in a bit of a lurch, as that was totally what I was planning on buying (if I bought).
  96. #96
    Apr 2017
    I emailed Norco directly after speaking with the dealer. I was dead set on the Sight as well. I already have good components that I would like to move over.
  97. #97
    Feb 2005
    Last time is checked at my LBS, the distributor still had a frameset listed for sale but there was no stock yet, this is in Canada and was a few weeks ago... It's also still listed online at the Canadian Norco site. I doubt it would be if there was no plan to offer it.
    If you're in the US and can't get one, send North Shore Bike Shop an email (north shore bike shop at gmail com, no spaces at symbol and add a .) and they'll get you sorted out. Also, if you're from the PNW, they're in North Vancouver BC and they're going to have a full size run of A1 demo bikes to ride.
  98. #98
    Jun 2014
    I hope this isnt true, was planning on ordering as soon as stock was available and building up over the winter.....already cancelled a ripmo frame order to facilitate this one instead
    Sent from my SM-G975U1 using Tapatalk
  99. #99
    Apr 2017
    Quote Originally Posted by rajcoont View Post
  100. #100
    Aug 2018
    Boooo. I was wondering if that was the case (too many orders).
    On the one hand, thats great news. It means the new bikes are selling well, and people like them, and we may get more build kits/frame only options in the future.
    On the other hand... I may not own one next year. I may have to wait another year... which is probably for the better, honestly, as I've not been on my Kona all that long.
    Guess that gives me time to see what else comes out, and to make sure I demo everything I can find.
  101. #101
    Apr 2017
    Yeah Iím trying to decide wether to keep my Slash or go for the Ripmo.
  102. #102
    Aug 2018
    Just got my response to my email about the "rumor" that I sent in a few days ago.
    Jeremy Axon (Norco Bicycles)
    Nov 27, 12:27 MST
    Hi <ocnLogan.
    It seems that the rumors are unfortunately true. Apparently there was little interest expressed by our dealers, and the frame-only option has been cancelled. An aluminum version will be available for full custom builds in our Build Your Ride program, though.
    Best regards,
    Jeremy A
    So, same result... but, kind of sounds like they're saying that the problem isn't too many orders of complete builds, but instead lack of interest?
    Not sure it matters much, to be honest. Although maybe if there is no interest, then maybe there won't be AL frame only options in the future? Hard to tell.
    Still excited to test ride the bike though. I was just hoping to save some cash, by bringing in most of the components, and not having to deal with SX eagle/etc.
  103. #103
    Jun 2014
    Thanks for heads up....total bummer!
  104. #104
    Just placed an order for a L 29 frame. Super stoked. Moving parts over from a Smuggler, so drivetrain and wheels will be upgraded at some point, but my starting build will be...
    Lyrik Ultimate
    X2
    XT 1x11
    Saint brakes
    RF SixC cranks
    Anvl 40/35 stem
    Chromag BZA bars
    Ergon SM Pro saddle
    TransX 170 post
    Hope/Flow wheels
  105. #105
    Aug 2019
    Quote Originally Posted by kragu View Post
    Lyrik Ultimate
    X2
    XT 1x11
    Saint brakes
    RF SixC cranks
    Anvl 40/35 stem
    Chromag BZA bars
    Ergon SM Pro saddle
    TransX 170 post
    Hope/Flow wheels
    Sweet, congrats! That's a really solid build! Where/how did you order it? What is the process? Thanks,
  106. #106
    Sep 2017
    I've ordered the Sight A1, won't be in until the end of Dec., but I'm guessing it'll be the New year. Sounds like they're selling quickly! The A1 has nothing that I'd want to change out, maybe the dropper post when it/if dies. I briefly considered the C2, but I think the components are way better on the A1. Plus I don't like yellow bikes, so that made it an easy decision.
    The A1 is a beautiful blue, looks great in person. Now I just have to play the waiting game.
  107. #107
    I think so too. Best part is paying for it all with parts lying around my garage. Worst part, again, is waiting.
    Just went to my local Norco dealer and told him what I wanted.
  108. #108
    Aug 2019
    Awesome! Post a review after you ride it!!
  109. #109
    Aug 2018
    Super bummed about them axing the AL frame only. I can't justify the price of the carbon, and the used part market where I am is super lame, so I won't even be able to recoup much of the cost if I get a complete build and strip it.
    I guess people who wanted AL frame only options were in the minority. Hopefully after the first wave of orders they bring it back?
    Oh well :/
  110. #110
    Aug 2019
    Quote Originally Posted by Notbn View Post
    Oh well :/
    What about the A1? I understand if it's out of your budget...
  111. #111
    Aug 2019
    Oh well :/
    What size frame do you need? Chainreaction cycles has a Nukeproof Mega 275 Frame in XL for only $1399! Also an alloy XL for $1100.
  112. #112
    Apr 2017
    275 only?
  113. #113
    Aug 2019
    275 only?
    Yes. But they have brand new 2020 alloy 29er frames for $1800!
  114. #114
    Aug 2018
    It isn't necessarily, but I already have a nice lyrik and perfectly serviceable parts from my current build, was hoping I could just grab a frame only and call it a day.
    Easier for me than selling my complete bike and having to wade through a sea of low ballers on PB. Plus like I said the used scene around me is very biased towards buyers, not sellers. Can get some great deals buying, but if you're selling, it's hard to find a buyer that is willing to pay market price.
  115. #115
    Aug 2019
    Yeah that totally makes sense.
  116. #116
    Sep 2017
    The A1 comes with e*thirteen LG1 EN rims. Can't find info on their website. I'm guessing it's an aluminum rim 30mm internal width? Anyone have any further info?
  117. #117
    Aug 2019
    The EN just means Enduro. It is an alloy, 30mm internal, enduro rim, 6 bolt, 28 spoke. Intense uses them on their bikes too. https://www.ethirteen.com/collection...lg1-enduro-rim
  118. #118
    Sep 2017
    Thanks for the link.
    "Entry level" rims, doesn't sound very inspiring! I guess we'll see how they do.
  119. #119
    32 hole
  120. #120
    anyone have any ride reports and impressions?
  121. #121
    Nov 2017
    Don't sweat it. If the rim strength is anything like the e*13 TRS rims that came on my Range, you'll be replacing them soon anyways ;-)
  122. #122
    Sep 2014
    Quote Originally Posted by kamper11 View Post
    Yep, Iíve ridden both the A1 in large and A2 in medium. With my XT pedals they were 15.95kg(A1-L) and 16.49kg(A2-M) on some luggage scales. Iím 174cm so Norco say M or L on ride aligned, the L is a big bike though, itís got the same wheelbase as an XL Megatower which seems crazy for someone of my height. My reservation is the short effective top tube on the Medium.
    On the trail both bikes felt surprisingly poppy, Iím not great at jumping but they both left the ground easier than my M trance. Out of the box the A1 ride aligned setup felt a bit better, I slowed the rebound on the A2ís X2 a touch. They climb really well, you wonít set any KOMs but the pedalling feels really efficient with little bob. Descending took some getting used to but once I worked out you need to really lean the bike to get it to turn it was a lot of fun, they really came alive on the steeper tracks I rode and felt really confidence inspiring. For me itíll be my main bike so Iím thinking Iíll buck the size up trend and go with the Medium C2, it just felt more manageable on tighter trails.
  123. #123
    Aug 2019
    Thanks mate, that is very helpful. They're very interesting bikes, but honestly, I'm a little nervous to ride something with a 1259 wheel base!! I'm 6', so I would take a large... What are you then, 5' 8"? I would def NOT go up to a large, if I was 5' 8". I'll see if I can demo one sometime in the next 6 months. I'm really looking at a Nukeproof Mega 275, to be honest.
    Thanks for the review!
  124. #124
    Sep 2017
    Fantastic!!
  125. #125
    Dec 2019
    I picked up an A2 and have set up under the ride aligned measurements for 68kg. I've noticed though looking at Fox recommendations their rebound settings are very different.
    For example, ride aligned is saying 21 out on float X2 shock rebound vs about 12 from Fox (note max is about 23). Does ride aligned sound a bit too fast?
    For the 36 rhythm ride aligned suggests 8 whereas Fox suggests about 12 again for rebound. This time around ride aligned is suggesting a slower setting than fox's recommendations. Confusing!
    Does anyone have experience on what you used as they are drastically different and I'm feeling like the shock especially is probably too fast.
  126. #126
    Sep 2014
    Ride Aligned told me 20 for the A2 demo bike, think I ended up at about 18, could even go a bit slower. I noticed the fox recommendations are quite different as well, coincidentally the 18 out setting is what fox recommend with air pressure set to my body weight (160lbs) so maybe the shock has a custom tune, or it could be to do with the linkage ratio, you have to run a much higher air pressure than the fox recommendation. Guessing this is the fox doc?
    https://www.ridefox.com/dl/bike/605-...Guide-revA.pdf
  127. #127
    Sep 2017
    Quote Originally Posted by BekzD View Post
    It's a baseline setup, everyone is a bit different. I talked to one guy and he said that the recommended settings were bang on, another had to alter his settings (he has a longer torso and short legs).
    I would go with Norco's recommendations, and make micro adjustments to dial it in for you. Fox is very generic and can't factor in the different bike designs.
  128. #128
    Aug 2019
    It's very likely the Norco version has a bit of a custom tune. Usually FOX aftermarket suspension is set up in a general "medium" tune. Get the four digit code from your fork and shock and plug them in on the FOX web site. It will tell you everything that is inside your kit (how it's tuned).
    https://www.ridefox.com/fox17/help.p...ke&ref=bc_help
  129. #129
    OP's nailed it. I have this fork in the 36 performance Grip sweep damper. Also a Marz Bomber Z2.
    I have the 36 on my ripper hardtail and find 8-10 from closed is the proper range. 12 was too fast. On the Marz, recommendations are same - but I ride it at 11 from closed.
    Just start at the recommended and 1 click at a time from there. Once I hit that pogo/deflect feel - I back off 1 to 2 clicks and good to go.
  130. #130
    Dec 2019
    I have been following this thread because the sight popped onto my radar because I am a fan of Norco and it seems like the bike I am looking for. I demoed a Megatower XL and really liked the way it made feeling riding it but I canít justify the price. I am a point and shoot and hope for the best rider. Can anyone give some insight between the Range C1 and the Sight A1. I have talked with Chris at Norco and he said that the Sight will take up most of the Range purchases and that it was ďnext levelĒ.
  131. #131
    Aug 2019
    Quote Originally Posted by barch1982 View Post
    As you can see, the Range is a big susp bike (in the 275 size)! As such I would only go for something like that if I absolutely needed that kind of suspension. I personally do not! So it really comes down to what you really need from a bike. It's also important to note that the Range is outdated, from a geo point of view! Judging by that alone, I would bet it climbs like a pig. Seat angle is way too slack! The Sight is much more modern and progressive in its geo and is very intriguing. It's on my short list for my new bike next year for sure... Even if you needed big susp, I don't think I'd consider the Range because of the geo. It's too old! Looking at the Optic and Sight, both very modern geo, I'm sure Norco will do a big redesign on the Range for 2021! Cheers.
  132. #132
    Dec 2019
    Thanks for the responses everyone. I was looking at the generic fox charts and it makes sense different tunes for OEM parts. Unfortunately the code I have for the shock doesn't come up with a doc but I'm going to run with Norcos settings and experiment dialling back 1 or 2 clicks for the shock.
  133. #133
    Sep 2017
    I have the XL Range 29er, it climb well for what it is, but on the steeper stuff you have to lean forward a fair bit to keep the front end down. I've talked to alot of people that have ridden the Range and the new Sights. They all state that it climbs significantly better, and is slightly better descending than the Range. Some state the Range may feel more secure in some very rough terrain. I like the Range for descending, but I want a bike that climbs better. If I was just climbing fire roads I don't think I'd sell my Range to get the Sight.
    I was told the Sight C2 XL 29ers are sold out already and they have 3 A1 XL 29ers left. I'm glad I got my order in! Should be arriving in Jan sometime.
  134. #134
    Aug 2019
    That's fine. Always set up and ride "for feel". All those suggested settings are just to get you in the ball park. Then you can set it the way you like!
  135. #135
    Aug 2019
    I'm assuming shipments will come in waves. That's common in manufacturing. They can't be literally sold out. It's a brand new bike and it's not even 2020.
  136. #136
    Sep 2017
    I'm not sure, a bike store that primarily sells Norco, stated they don't know if they'll have any Sights to sell in the spring.
    They're selling quick!!
  137. #137
    As I understand it - next frame shipment expected in March. But likely will not offer alloy frame only as was originally optioned - complete builds or the build your Sight options only.
  138. #138
    Aug 2019
    Well hopefully Norco didn't plan that poorly, and will have a decent number of models well into 2020... I did hear that info regarding the change of mind, on that alloy frame set.
  139. #139
    Dec 2019
    I appreciate the feedback. Being that you ride an XL Range do you feel you would ride the same on a Sight?. I have heard that the A1 is the best bang for your buck. Is it that much better than the A2? The local shop is trying to scare me away from a NX build.
  140. #140
    Aug 2019
    Yeah mate, if you can swing it, the A1 is just a better bike all around. Better susp, better brakes, better drive train, better hubs on the wheel set, nicer handlebars. You can upgrade that rear hub to a 54t ratchet for a really nice engagement. And I don't hear very good things about the NX drive train. The shop isn't lying to you... I'd try to do the A1, if you can!
  141. #141
    Sep 2017
    I haven't had the chance to ride the Sight to compare to my Range. The information that I gathered from those that rode both, stated the Sight climbs significantly better and equally or better on the descents. If I was doing HUGE drops and air, then the Range would be a better option.
    I think the A1 is way better, but if I didn't quite have the money, I'm sure I'd be happy with the A2.
  142. #142
    Sep 2019
    Cool-blue Rhythm
    Well ladies and gentlemen, I pulled the trigger on an A1 today!
    It's being shipped to my local shop and is supposedly going to be ready for pickup in seven days or less.
  143. #143
    Aug 2019
    Congrats! Please post a review on a new thread, after you have a chance to ride it. Cheers.
  144. #144
    Sep 2019
    I will for sure, unfortunately it won't be worth much. I was a hardcore (I don't mean hardcore to try to sound cool, just meant that it was basically all I did) rider back in the glory days of "freeride" 98 to 2006, until a pretty serious crash with a couple years of recovery. Sold my DH rig at the time. Did the roadie thing for a number of years until a near death experience with a car put me off of that. Haven't ridden more than bike paths with the kids the last couple years. Decided that I needed to get on top of my health again and want to get my kids into it as well.
    I guess what I'm getting at is that I'll post what I think of the bike, but I won't have much to compare to. My last time on a mountain bike was a Specialized Big Hit DH with Shivvers, Hayes Mags, Sunn doubletracks etc. Prob north of 45lbs and a 24" back wheel . Well, and a dirt jump hardtail ...
  145. #145
    Aug 2019
    It's all good. Post up a review anyway. You don't need to be pro to share a review!
  146. #146
    Sep 2019
    For sure! Can't wait, although it's snowing and minus eight celsius right now...
    I was originally going to go for the A2 but that A1 spec was just too good. No compromises anywhere and I wouldn't change a single part. Also going to get the shop to do the tubeless conversion before I pick it up.
    Both 29's and a bike this long are going to be totally new to me. Should be very interesting!
  147. #147
    Congrats on the A1 - im in same boat that while the a2 spec is good the A1 really doesn't need anything out of the gate. That said - I plan to swap out the drive for new Shimano 12spd at dealer.
    BTW Perciv - thanks for the sharing the story - sounds like you may have been lucky to not have been worse off after your accidents and kudos for jumping back in. If not for the mtb the past 10 yrs I don't know what my health both mental and physical - would look like! Look fwd to hearing about your first rides!
  148. #148
    Aug 2019
    LOL, wow that's cold! Sounds great though. Yeah I've never ridden a bike that long either. I really hope to demo one in the spring/early summer. Look forward to hearing your thoughts on it.
  149. #149
    Sep 2019
    Thanks! Yep, cold for sure. May have to head out to Vancouver to scratch the itch...
    I'm so curious what 29" wheels are going to be like. Most of the riding around here is super rooty and rocky so I totally get the advantage. Back when I rode, 29ers were a pretty new thing and were only on super short travel XC bikes. DH and freeride bikes were short WB with mega tall front ends and steep angles. What were we thinking!?
    It's so cool to catch up and see where the industry has gone the past 13 years! Tubeless, air suspension on Enduro and DH bikes, dropper posts, 1x drivetrains on non DH bikes, big wheels, radically different geometry and the fact that you can do anything short of WC DH with a single crown fork is all new to me. I've got my 8 year old on a bike with 2.6 tires with like 4psi and it's awesome!
    My biggest unknown right now is if I retained any of my riding skills...
    Anyway, thread drift, I think Norco is going to do really well with these bikes this year. I haven't had a Norco since I was a kid so that's kind of neat. I wonder how availability is going to be after some of the comments in this thread? There's still pretty limited sizes on their website but it's still early. I wasn't planning on getting one till closer to spring, but suddenly A1's were in stock in XL 29". Figured that A1 will be a popular build especially since they took away alloy from the custom builder.
  150. #150
    Aug 2019
    Good call on the drive train swap! I def prefer Shimano all the way around. That's why I have my eye on the C2. I know it's a bunch more money, but it's a great build kit, and I do like carbon too.
    Enjoy!
  151. #151
    Aug 2019
    Oh wow, you got a 29er AND an XL?! LOL, that's going to be another planet for you! It's massive and with those big wheels...it won't be like anything you remember. You're going to freak out in a good way. Not sure how your fitness level is, but you'll need good legs for all that bike.
  152. #152
    Sep 2019
    Hehe, yeah, it'll be different. I've sat on an A2 at the shop and it's a whole different animal. Very long and low. You sit down between the wheels instead of up on top of the bike.
    I'm 6'4" 180lbs and fairly fit so it shouldn't be too bad. These bikes are probably way more proportional for guys like me anyway.
  153. #153
    Sep 2017
    I stopped Mtbing in 2006 as well and got back into it 2 years ago. It was quite overwhelming with all the choices out there(geo, wheel size, etc).
    As for skills, they come back relatively quickly, the biggest adjustment was keeping my weight more centered, I was hanging my ass over my rear tire way too much because that what you did with the bikes back in the 90's.
    I have the Range XL 29er, you're going to love the 29er for the roots and rocks and 29 will be better for the climbs. Once you ride any bike, you just get use to it after awhile.
    I'm waiting for my A1 XL as well and talking directly to Norco they're supposed to arrive around Dec 26th, but with the holidays I'm preparing myself for mid January.
    I live on the North Shore, so if you're in Vancouver and your itching to take your new bike on a ride, send me a message and we'll hit it up on our new bikes!
  154. #154
    Sep 2019
    Ha! That's wild that you took a long break too! I paid absolutely no attention to the state of mountain biking during those years so it was like waking up from a coma and having to catch up with all the changes!
    Man, I really appreciate the offer for the ride! That's very cool! I'll see how the winter goes here and I'll hit you up for sure if I'm able to get out there. I'm in Calgary so riding in the winter is pretty much left to the fat bikes. I've never ridden the North Shore and have always wanted to. I used to visit my Cousin in Nanaimo and rode some pretty wild stuff out that way back in the day.
  155. #155
    Aug 2019
    Yeah that's exactly right, a good bike will have sitting more "in" the bike, instead of "on" the bike. You're going to love it!
  156. #156
    Sep 2017
    Let me know if you're thinking about coming out and I'll let you know what a trail conditions are like. Last year we biked until Groundhog Day, ironically it snowed the next day and the snow stayed until the beginning of April. In fact in Jan/Feb the trail were getting loose because of dry conditions. That doesn't happen very often in Vancouver!!!
  157. #157
    Sep 2019
    Aaaaaalllllright, picked up the new A1 tonight! Really nice in person, beautiful paintjob and what a parts spec! Had an assembly at my kids school so I've only ridden it up and down the sidewalk in front of my house without enough pressure in the shock. Feels immense! It's a big bike in XL.
    I'll get some pictures tomorrow night hopefully, buy won't get much of a riding impression anytime soon as there's half a foot of snow on the ground.
    For anyone curious, it weighed 34.7lbs on the digital shop scale with the crappy pedals they put on for pickup. Oh, and converted to tubeless.
    I'm a happy boy!
  158. #158
    Aug 2019
    I'm a happy boy!
    That weight isn't half bad considering how huge that bike is, and that it's alloy! Congrats!!
  159. #159
    Aug 2018
    The A1 XL 29er would be a bike Iíd be very happy to own (less so to buy, as its out of my price range). Hopefully you get some days of weather that will let you get out and try it a bit sometime soon 👍.
    Super interested to demo one. Looks like I may have to wait until the duthie bike fair though (June ). Until then, Iíll just Live vicariously through you guys here and any reviews I can find.
  160. #160
    Sep 2017
    I'm envious that you have your A1! I still have to wait a couple more weeks for mine.
    I'm guessing the DT Swiss 350 hub comes with a 18 tooth ratchet?
  161. #161
    Sep 2019
    Don't be too envious, its -14 celsius here right now...
    As far as the hub, I didn't check but it sounds like it.
  162. #162
    Aug 2019
    That's an easy upgrade, and not too expensive!
  163. #163
    Dec 2019
    For the guys getting an XL. What is your height? I am 6'1" short torso, long limbed. I ride a L Fluid FS now but have tried out and liked an XL in a Santa Cruz. The local shop says they probably won't get any Sights or Optics in until February next year.
  164. #164
    Sep 2017
    I'm 6'1" with a longer torso. I only rode the Sight 29 in L and XL in the store. The L was definitely to cramped for me, XL felt the same as my XL Range. I know one guy that's 6' with short torso and he went with a Large.
    You're probably going to have to try both.
  165. #165
    Dec 2019
    I figured I would. Just hoping the shop will stock both sizes.
  166. #166
    Sep 2019
    With the seat angle being so steep and the head angle so slack it makes for a relatively short cockpit. It doesn't feel stretched out to ride. I'm 6'4" so XL was the obvious choice, but the bike fits smaller than it is if that makes sense?
  167. #167
    Sep 2017
    Hahahaha......I'm wearing my t-shirt outside right now!
  168. #168
    Sep 2019
    Quote Originally Posted by Graveltattoo View Post
    And I'm wearing a sweater and toque inside...
    Careful, I may just be taking you up on that offer in January if I can make it work...
  169. #169
    Aug 2018
    I haven't sat on any model of Sight (new, or otherwise).
    I'm also 6'1", with relatively normal proportions.
    Looking at the geo chart, the Reach itself on the L looks fine, but the ETT is 11mm shorter than my current bike (2018 Kona Process 153 29'er), which already feels slightly small to me.
    However, the XL is another 17mm longer than my Kona, so Id want to make sure I get to demo bikes on both L and XL before I make any final decisions.
    Since they nix'd the AL frame only option for this year, I'm about to throw a 15mm longer stem onto my kona to fix the sizing a bit (and get me to weight the front wheel more), and try to get my to be ok with my bike for another year . So maybe that will give me a better idea of if the XL will be the right fit for me.
  170. #170
    Sep 2017
    With the new Geo's, you really can't compare with other bikes. My XL Range has a top tube length 20mm longer than the XL Sight. The Sight's HA, STA, etc is different from the Kona 153. So I think it's impossible to make a comparison looking at numbers.
  171. #171
    Aug 2019
    For bike fit, I only look at Reach and Stack, and a bit at the STA. STA will determine if a long Reach number will actually feel long. Length of the various tube measurements aren't nearly as important. Just my opinion...
  172. #172
    Aug 2018
    Since reach is only the distance from bottom bracket to the head tube. This means that bikes with the same reach, can have wildly different distances from saddle to handlebar/head tube, just because their seat tube angles are very different.
    The effective top tube measurement is supposed to be the geo chart measurement that gives you an idea how a bike will fit while seated and pedaling. Itís the horizontal distance from the top of the seat tube to the head tube.
    The reach measurement is supposed to be more for the fit while standing and descending. Just saying, Iím pretty sure thatís what the effective top tube is attempting to communicate. That said, head tube angle, stem length and rise, saddle position on the seat post, and even the number of spacers under the stem can change the fit. Not trying to say a geo chart will tell me everything, as I still want to demo both L and XL sizes. Just using the only bike I have to get me as much of an idea what the Fit of the sizes of sight will be like as I can .
  173. #173
    Sep 2017
    Reach feels the same, XL Range vs XL Sight, even though the Sights reach is 35mm longer. But the Range's Top tube is 20mm longer.
    I thought I could analyze geo numbers and compare different bikes. The only way now is to ride them!!!!
  174. #174
    Aug 2019
    Yes, that's because the STA on the Sight is so steep. The Reach is longer, but the STA brings you closer to the bars, so it ends up feeling the same. When I'm analyzing geo, STA takes more priority versus top tube length. Like I mentioned, that's why I focus on Reach and STA mostly. ocnLogan also made good points about seated fit, and pedaling fit, out of the saddle. Fun stuff.
  175. #175
    Sep 2017
    I'm starting to think of storage of tube, tools, CO2 cartridge on the new Sight. The underside of the top tube has some bosses to mount items.
    Looking at Wolftooth B-Rad mini roll top bag.
    https://www.wolftoothcomponents.com/...13730327691299
    Oneup EDC tool system.
    Anyone have any feedback on above options?
    Any other potential storage systems?
  176. #176
    Sep 2019
    That wolftooth bag looks cool. I was pretty gung ho on the one up system until I really looked closely at it. The multitool is pretty minimalist and is missing several fairly vital patterns. I'd rather have a bigger multitool with all the bits I need rather than two separate tools. Plus I already have a C02 setup...
  177. #177
    Sep 2019
    Alright, I did a HUGE test ride tonight that consisted of a few kilometers of neighborhood sidewalks so take this with more than a grain of salt...
    Keeping in mind that it's -6 and there's six inches of snow on everything other than the shovelled sidewalks.
    Bike felt great! You definitely sit much farther forward than any other bike I've ever ridden. Climbed one good hill and man, sitting forward like that feels fantastic climbing! You don't even have to lean forward, just sit and spin. Did notice more weight on the hands riding on flats, but not bad.
    The geo feels really stable. Anyone who has ridden on packed snow knows how sketchy the front wheel feels. It's a lot like sand in that the front wheel just wants to wash out. Not so on this bike, that slack front end feels really solid and just goes where you point.
    So there you go, a basically pointless review of how the 2020 sight shreds on frozen pavement and packed snow for 20 minutes in the dark
  178. #178
    Sep 2017
    Quote Originally Posted by percivilla View Post
    Do you think that Wolftooth bag would fit under the top tube? Would it look too crowded with a water bottle in the usual spot? I don't have my bike yet to see if it would work.
  179. #179
    Aug 2019
    LOL. We appreciate the review anyway! Sounds very interesting. I'm really hoping to demo one this season. I've never ridden anything that long. (that's what she said). As far as hand pressure on flat ground, that makes sense. You'll have to see how that goes. You can always try bars with a higher rise on them. That may help. Thanks!
  180. #180
    Sep 2019
    Think it'd probably be fine. The top tube bosses are pretty far back so it wouldn't foul the water bottle. If you stuffed it really full it might rub the top of the shock I guess. There's about 2 3/4 inches of clearance above the shock on the XL.
  181. #181
    Sep 2019
    Yeah, it wasn't bad at all. I guess it's not that you have that much weight on them, it's more that when you are spinning, the downward push on the pedals doesn't push your torso away from the bars as much as say a road bike, because the pedals are farther back relative to your centre of gravity.
    I played around with the spacers as well to go with the "ride aligned" recommendation of 15mm below the stem.
  182. #182
    Quote Originally Posted by MikeyOrange View Post
    Having ridden the new Sight... it's phenomenal! I'm incredibly excited to buy one, coming off a very similar bike comparing dimensions and angles (the Transition Sentinel), but on the trail it just does everything better... climbs better, more traction, easier to move around, faster...
    The frame only option also has an X2, which is definitely has an added cost associated.
    Super interested in anything else you can say in comparison to the Sentinel. Iím coming from a Patrol/Smuggler stable and love the way those bikes handle. 2020 Sight is on order...
  183. #183
    Nov 2014
    Is it just me or did the aluminum frames get all the best paint jobs?
  184. #184
    Aug 2019
    Quote Originally Posted by dlxah View Post
    The alloy bikes do have really good colors, for sure, but I also really like the Woman's C2. The dark blue/green is sweet!
  185. #185
    Reputation: ocnLogan's Avatar
    Aug 2018
    The colors for the sight are a bit all over the place for me. I like the Yellow of the C2, The red of the womens C3, the A3, and A1 are the only other ones that I kind of like. The rest don't really do anything for me.
    Different strokes for different folks though .
  186. #186
    Here is a slightly edited review (removed some local trail references) I did after demoing a brand new A1 in November. I'm not the target audience for this kind of ride, but I've been around the block a couple times on alot of different types of bikes. First time I was ever motivated to write a review. That's how impressed I was....
    If you want to know about parts spec or geometry details, none will be found here. No value to be added from me paraphrasing what can be found elsewhere on the internet or at your local Norco dealer. This is just a write up by a barely literate spandex aficionado who after one ride is questioning what I want from our amazing sport.
    Fair to say climbing is my forte. Itís the part of cycling Iíve naturally gravitated too. I like punishing my body and Iím kind of scared of downhill riding. My bike collection reflects this, two 100mm XC bikes and a rigid SS. Itís not that I havenít owned and ridden bigger bikes, even have a full-face helmet and armour tucked away somewhere... but itís been a while. So, when I found myself demoing the new 2020 Norco Sight, it came with a lot of preconceived notions of how a bike should perform!
    There is no hiding the 35 pounds of weight on the climbs. Itís a big bike with solid components. You wonít be rising out of the saddle and sprinting up over rises on the Sight. But it turns out you donít need to. The bikes geometry allowed me to stay perched in the same spot on the saddle and motor truck my way up the climb. I used the suspension lockout once, but left it off for the remainder of the ride. Donít need it. Better off just removing the lever and saving the 3 grams in weight.
    It was approaching sunset as I summited to the start of Jabbarocky (chunky steepish DH trail). Light was fading fast, but not as fast as I found myself bombing down the trail. Once I figured out not to fight the handlebars, and remember to drop the saddle, the bike did all the work. No bike setup beyond quick tire and suspension pressure. Despite this, within minutes from dropping in, I felt comfortable and confident. The Sight encouraged me to hit lines and jumps that I never had before. Exiting the end of the trail, I let out an audible yelp of joy.
    Iíd already decided the Norco Sight was my new best friend, but what did Strava have to say? Iíve hit Jabba some 130 times, but on that first shake down test, I knocked 45 seconds from my PR on a ~ 7 min segment. Still a long way off the KOM, but fourth was a nice surprise. Brand new bike, the brakes werenít even bed in yet. Crazy.
    Of course, a faster time on an Enduro bike could be expected, compared to my previous best on an old school 150mm 26Ē wheeled bike. Thatís a given. But to go that fast on the first conservative run on the Sight, ahem.. eye opening! The misses summed it up well later that evening while looking the bike over, ďThis goes against everything you have taught me about bikes!Ē Well sweetie, as it turns out, for the first time ever since being married, I was wrong.
    Me being me, Iíd change a couple things about the bike if it was mine. Fit and setup preferences, along with an oval 30 tooth chainring. Save all my energy for the DH. Maybe wait an extra pay day or two and upgrade to the carbon model. I am an ex-XC rider after all...
    Yeah, Iím gushing with glee from the demo ride. But Iím also trying to figure out how to buy a new bike. Anyone in the market for a well-used XC bike? Only ridden all day on Saturdays and Sundays. I donít want it anymore.
    Disclosure: I have zero industry affiliation. Self-funded weekend warrior. I get no industry deals and am possibly too blunt when giving an opinion.
    Addendum: I've since bought my first Norco, a 120mm Revolver. In part due to being so impressed with the quality of construction and handling of the Sight.
  187. #187
    Sep 2019
    I'm planning on taking mine for a longer ride tomorrow. Everything is still pretty snow covered but they're calling for six degrees tomorrow (that's 43 in American money).
    Agree that the colors are a bit polarizing. I only really dug the womens C2 and the A1. My A1 looks stunning in person. The blue is really deep and the lettering is darker grey than it looks in pictures.
    One odd thing I noticed is that "ride aligned" recommended 101psi in the fork for my stats. That's mega stiff and my sag was way too little. Rockshox recommends 85psi which gets the sag where it should be. Ride aligned got my shock to the proper sag, but the fork pressure seems way too high. Anyone else try ride aligned yet?
  188. #188
    Sep 2017
    Just to confirm, you're in the attack position when set the o-ring against the duster seal to check your sag? When you hammer down on your fork how much travel do you go through?
  189. #189
    Aug 2018
    For what its worth, I found what might be the first official (ie, not "first ride") review of the Sight.
    Enduro-mtb released the article reviewing 17 enduro bikes in their app (strangely, they make articles exclusive to their app for like a month, then it goes to their website). For those that can't, or don't want to do that, here is the main takeaways.
    The Sight was well received saying that it was super fun and capable. And perhaps surprisingly, the climbing was great as well. As the cons, they pointed out the noise from the internal cable routing, and the chain slap guard being way to short (and the chain damaging the paint).
    They did mention that the bike isn't billed as an "enduro" bike, and so it was slightly under-gunned (less travel) compared to most of the others in the test. As part of that they said that the rear end was less plush, and more poppy than most in the test.
    Here is the conclusion in full:
    "The Sight C1 is one of the best bikes on the market for those who are out to have fun. It will win you over with its lively, agile handling, excellent climbing characteristics, and huge freedom of movement. Its only when the trail becomes very rough that the firm tune of the rear suspension can't keep up with the better bikes in the field test. There is also room for improvement in terms of the quality of the workmanship."
    The Optic has been getting a lot of good press about how fun it is over on pinkbike/etc. But I'm happy to see that Enduro-mtb is saying the same thing about the Sight. I was moderately worried that because the Sight is longer, slacker, and more travel, that the bike doesn't sound like its to dulled down/boring/etc.
    Because, like most of you, I'm not racing. I'm just out there to have fun .
    I still want to demo both the Optic and the Sight. I'm just still fairly certain that the Sight is the one that I think I'll prefer.
    And excited to see some real user reviews coming in. It all sounds great so far.
  190. #190
    Aug 2019
    What do you weigh, if you don't mind...? 101 PSI is quite a lot for a fork! The pros aren't even using that much. Sam Hill only uses about 85...
  191. #191
    Aug 2019
    Quote Originally Posted by ocnLogan View Post
    Thanks for passing that along mate. I also want to demo a Sight, for sure! The Optic is too small for me travel wise...
  192. #192
    Sep 2019
    6'4" 180lbs so not exactly a beast. I'll double check the sag tonight, but yeah, 101psi was really stiff! The Rockshox trailhead app said 85psi for my weight. Seems much more reasonable.
  193. #193
    Sep 2019
    Yep, standing in the pedals, balanced in a doorway, all damping backed off. Bounced a few times then got my wife to roll the o ring down. Ended up just less than 30% with around 87psi averaged over a few tries. 101psi was way to stiff. Odd for ride aligned to recommend a psi so much higher than the manufacturer.
    I haven't yet ridden the bike on more than paved sidewalks so I don't know how much travel I'm going through yet. Stock otherwise so two tokens presumably.
    I'll hopefully get out tomorrow to try to find some dirt amongst all the snow.
  194. #194
    Aug 2019
    85 is a pretty decent amount, but not crazy. Def give that a try. The Debonair air spring uses a larger negative chamber, and those designs do take a little more air, so hopefully that will feel much better than the 101 lbs. LOL.
  195. #195
    Sep 2017
    I've been riding a Fox 36 fork, they recommend 20% sag for plush and 15% for firm. Does Rockshox recommend 30% for their fork?
  196. #196
    Aug 2019
    Not sure if they have a suggested sag. I would imagine they do, but I'm not sure. I generally like to shoot for around 20% for my forks, as a starting point, keeping in mind that's just a starting point. Always set your bike up by how you like it to feel. Interesting story; do you know who PUSH suspension is? Anyway, the founder of PUSH says to set your sag and then cut your travel indicator ring off! Just ride by feel. He doesn't agree with the idea of setting up to use "full travel". In fact he says, if you're using full travel your susp is probably NOT set up correctly...
  197. #197
    Aug 2018
    I've always been under the impression that the rough baseline for almost all forks was ~25% sag, and then to go from there.
    I tend to prefer a bit less sag in the front of the bike (compared to the rear). This way the bike dives a bit less when under hard braking/cornering, which IMO keeps it a bit more composed (and the HTA slacker).
  198. #198
    Anyone else here read the Enduro MTB group test of new 2020 Enduro rigs? They included the new Sight in the test. Frankly a little surprised what they set about the more "firm" ride in the rear with the Rockshox. (compared w fox x2) but that's likely the beauty - you can have firm and poppy or more plush and plow-y depending on the shock. Overall a good review of a bike in a class of even longer, longer travel, slacker etc... they do seem to reward it as a good climbing, fun and agile ripper that will keep up with most of the true enduro sleds they tested
  199. #199
    Sep 2019
    Went and downloaded the app. Very cool app actually! Interesting review for sure. Funny they mention the loose cables in the down tube rattling. I was already thinking that would be an issue. Figured I'd stuff some closed cell foam chunks up in there.
    Good to hear they think it's playful and fun! That's what I was looking for. Used to ride big travel DH bikes and they were often too squishy for just screwing around on trails. Already seen a couple reviews for the Specialized Enduro that mention how fast it is but at the expense of playfulness.
  200. #200
    Aug 2019
    Yeah they mention not the plushest rear end. I wondered if it was the shock itself, the tune, or the susp kinematics... The FOX shock on C2 has no climb switch. I thought it may be good to swap it out with a Factory X2 or DPX2, so you could run it more plush and then just use the climb switch, if needed... Seems like a very interesting and hopefully great bike though...
Page 1 of 4 1234 LastLast
  1. 2020 Hightower 2 vs 2020 Tallboy 4
    By Doug in forum Santa Cruz
    Last Post: 07-07-2020, 10:47 AM
  2. Replies: 7
    Last Post: 11-10-2019, 09:31 AM
  3. 2020 Orbea Rallon vs 2020 Santa Cruz Hightower
    By kzlucas in forum 29er Bikes
    Last Post: 10-11-2019, 07:31 AM
  4. Replies: 6
    Last Post: 05-05-2016, 08:49 AM
  5. Sight/Sight KillerB BB height
    By skidad in forum Norco
    Last Post: 11-02-2012, 03:38 PM
Members who have read this thread: 290
