2017+ Norco Sight Shock info- Mtbr.com
Results 1 to 5 of 5
    Reputation: Calhoun's Avatar
    Nov 2008
    Looking to see if any one has the specs for the 2017+ Norco Sights. Looking to pick up a coil shock that is meant for a Norco but the seller doesn't know the shock tune. Any help appreciated. Cheers!
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    Assuming it's a RS shock, the Sight will have the ML tune for rebound & compression, respectively.
    Unfortunately I don't know what this corresponds to in a Fox or other shock.
    Reputation: JoshM's Avatar
    Quote Originally Posted by aerius View Post
    Would the RS deluxe be the same tune across all the sizes? XL has the same tune as a small?
    I'm interested in giving the Deluxe RT a try vs the Performance DPS that came stock on my 2018 Sight C3.
    Nov 2008
    Good info, thanks!
    Quote Originally Posted by JoshM View Post
    Do you have the tune code off your DPS? Should be a four digit sequence. Like this:
    2017+ Norco Sight Shock info-fox_20shox_202017_20float_20dps_20972-01-316-2-e1493206307435.jpg
    -cabra cadabra
    Nov 2008
    Just a follow up here for any one else looking into this.
    The shock came in and is a MM tune.
    -cabra cadabra
  1. 2017 Norco Sight vs 2017 Giant trance
    By paddy73 in forum All Mountain
    Last Post: 04-09-2020, 08:01 PM
  2. Replies: 0
    Last Post: 12-16-2017, 10:38 AM
  3. Replies: 6
    Last Post: 05-05-2016, 08:49 AM
  4. Replies: 14
    Last Post: 03-26-2014, 08:56 AM
  5. Sight/Sight KillerB BB height
    By skidad in forum Norco
    Last Post: 11-02-2012, 03:38 PM
