2015 Norco Sight C7.4 XL weight- Mtbr.com
Results 1 to 10 of 10
    Captain One Lung Administrator
    Reputation: JCWages's Avatar
    Jan 2015
    In case anyone wanted to know the weight of the entry level carbon Sight model here it is: 31.08lbs
    It's an XL frame with stock components except the following:
    WTB TrailBoss 2.25" tire (fast rolling) (778g)
    Wellgo B252-MG pedals (250g)
    Water bottle cage (42g)
    Kore Cubix 50mm stem (115g)
    2015 Norco Sight C7.4 carbon (stock build)
    * Frame Size & Color: XL / Matte Black
    * Fork: Rockshox Revelation RL solo air 140x15mm
    * Shock: Rockshox Monarch RL
    * Brakes: Shimano Deore BLM506 w/180mm rotor
    * Cranks: Sram S-1000 38/24T PF BB92
    * Front Derailleur: Sram X-7 high direct mt
    * Rear Derailleur: Sram X9 type 2 long cage
    * Pedals: Wellgo B219
    * Stem: Race Face Ride 70mm (replaced)
    * Handlebar: Norco double butted 760mmx25mm rise
    * Seatpost: X-Fusion Hi lo w/remote 30.9mm
    * Saddle: WTB Volt Sport
    * Bottom Bracket: Sram Pressfit BB 92
    * Cassette: Sram PG1020 11-36T 10sp
    * Headset: FSA Orbit C-40-ACB
    * Grips: Norco single side lock
    * Front Tire: Maxxis Ardent 650Bx2.25 wire bead (replaced)
    * Front Rim: Sun Inferno 25 double wall
    * Front Hub/Skewer:
    * Rear Tire: Maxxis Ardent 650Bx2.25 wire bead
    * Rear Rim: Sun Inferno 25 double wall
    * Rear Hub/Skewer: Formula sealedbearing 142x12mm
    * Weight: 31.08lbs.
    CAMBr Trail Crew
    Reputation: DDDonny's Avatar
    Nice! When did you get it?
    Jan 2015
    Quote Originally Posted by DDDonny View Post
    Early March.
    It feels a lot bigger than I expected but I had been riding small bikes with I had this on order. I love it!
    Jun 2012
    How tall are you? What about inseam and reach? I'm 6'2" with a 35" inseam and 6'6" reach and I'm pretty sure I want an XL and have been looking at Norcos since my local shop just started carrying them, but they don't have an XL bike in stock yet.
    Jan 2015
    Quote Originally Posted by CBus660R View Post
    I'm 6' 2.75" officially. I have never measured my inseam or reach for this purpose so I'm not sure of the numbers but I I wear a 34" length regular pant and 36" pant for work wear (Wrangler, Ariat, Carharrt).
    With your measurements I'd think the XL would be the way to go. I feel like the XL is borderline large for me but I'm glad I go it. It fits very well. It's just not as nimble as the medium-framed 25-27lb bikes I had been borrowing.
    Jan 2015
    Forgot to mention, my friend is a sale manager for Norco and he is 6'2" and rides the XL frames and said that the XL was perfect for me. With your potentially longer reach I think you should get the XL. Adjust with stem choice. The XL comes with a 70mm stem, the large and medium come with a 60mm. I swapped out the 70mm to a 50mm and so far I like it.
    Jun 2012
    Thanks for the feedback. I feel like I need an XL. The issue is the dealer doesn't have any in stock to know for sure. They think I need an XL too, but I'd really like to sit on one before I commit to ordering one.
    Jan 2015
    I hear ya and if you were local I'd offer to let you try mine out.
    Jan 2015
    OEM parts weights:
    Sun Ringle Inferno 25: front = 1023g (+150g for rotor) rear = 1176g
    WTB Volt Sport? saddle: 298g
    Maxxis Ardent 2.25 comp? Wire bead = 740g
    RaceFace 60mm stem: = 169g
    Norco lock on grips: = 84g
    Norco 760mm handlebar: = 373g
    I'll add more weights as I get them.
    Jan 2015
    Finally got the wheel and handlebar weights. See above.
  1. 2015 Norco Sight
    By lb2 in forum Norco
    Last Post: 06-19-2018, 08:45 PM
  2. Replies: 3
    Last Post: 11-27-2014, 04:56 AM
  3. My Norco Sight 7.1
    By jeffgre_6163 in forum 27.5
    Last Post: 06-03-2014, 02:31 AM
  4. Norco Sight (26") - frame weight?
    By bigfruits in forum Norco
    Last Post: 06-20-2013, 05:58 PM
  5. Norco Sight 650 B1
    By dwt in forum 27.5
    Last Post: 08-27-2012, 01:21 PM
