Sir 9 rear tire widths- Mtbr.com
Results 1 to 8 of 8
    What is a reasonable max width tire on a 30mm internal rim for the rear of the latest 2018-2019 Sir 9? I know the website says 2.4 but with that newer wider yoke and the ability to put 27.5 x 2.8 in the rear, one thinks that it could be greater than 2.4.
    Feb 2018
    This is a slight pain point for me. It comfortably fits a 27.5 x 2.8" tire on a 40mm internal rim width, but a 2.35" Nobby Nic on an Industry Nine Trail 29" 245 (24.5 internal rim width) BARELY FITS. Not a hugely aggressive tread and not on a wide rim, would say 2.4 could be pushing it. Seriously. Tried fitting my Hightower's Aggressor 2.5" fitted onto a Reserve 30 29" and no dice.
    Let me know if you have any questions, I'd personally recommend 27.5+ for it though.
    I'm late here but I could use some help too. I also have 30mm internal width rim. I tried a Maxxis High Roller II 2.3 and it would pick up rocks and shove them right into the chainstay yoke, which is now extremely scratched up. I'm going to try a Maxxis Ikon 2.35 that should pick up less rocks and has a bit of a rounder profile. Niner currently specs a Maxxix Rekon 3C/EXO/TR 2.4 WT on a 26mm internal width rim, which seems like it would also be an incredibly tight fit. I'm open to suggestions! Thanks.
    Quote Originally Posted by Rodmunch View Post
    Didn't work out. The clearance is still really bad. It rubbed the frame a few times. Back to the drawing board!
    I also found that Niner has a spec with 30mm internal width rims and a Rekon 2.4 WT. How do they make that work?
    Mar 2020
    I recently purchased a SIR 9 from Jenson USA. It has 29" 30mm wheels and came with 2.35 Knobby Nic's. I didn't check clearance with the Knobby Nics before replacing them with 2.35 Vittoria Mezcal. With this tire, there is not much clearance at all. It was tight enough that I replaced the rear with a 2.25" Mezcal. Clearance is still tight. I've measured the 2.35 as a true 2.35 and the 2.25 comes in at 2.3.
    I don't know how a 2.4 could be used in the rear.
    Thanks! Yeah I have the Jenson SIR9 also. I'm going to try a 2.25 Maxxis Rekon and report back. For the time being I've been running a tubeless 2.35 Nobby Nic.
    The Rekon fits! But the sidewalls stick out just a bit wider than the tread making them more vulnerable. I'm happy so far until I can get a narrower rim.
  1. geometry and ride: old SIR vs new SIR
    By koudja in forum Niner Bikes
    Last Post: 11-07-2014, 06:13 AM
  2. Tire widths - what combo
    By kikoraa in forum Singlespeed
    Last Post: 11-13-2011, 11:03 AM
  3. Choosing Tire Widths
    By Sundragon in forum Wheels and Tires
    Last Post: 05-26-2011, 01:57 PM
  4. Hand-wringing over tire widths?
    By Lule in forum Wheels and Tires
    Last Post: 04-18-2011, 05:25 AM
  5. Stupid question for tire widths
    By mustangous in forum Wheels and Tires
    Last Post: 02-27-2011, 10:44 AM
Members who have read this thread: 17
