RIP9 still rippin' - 3 years in- Mtbr.com
Results 1 to 12 of 12
    Chilling out
    Reputation: bear's Avatar
    This probably jinxes my bike, but I just got back from a 9 day drop in Moab, and my '17 RIP9 sure was a fabulous bike for that.
    Great mix of trails, up down and over, from Bar-M to Ahab to Porc Rim, never let me down and had a great time.
    2nd trip to Moab on the bike, last trip was 27.5 wheels with 2.8, this one 29er with 2.6, still lovin' it.
    Peace.
    Mar 2018
    So whatís you verdict? 27.5+ or 29. I had one Moab trip on the plus wheels and second on 29 x2.6. I donít think Iíll go back to 27.5.
    Chilling out
    I think if I was Mr. Freeride and looking towards truly beat-down dropping and DH style that the 27.5 may be better, but for me ... I don't like flying more than 4 or 5 ' vertical, the 29x2.6 (Maxxis Rekon) were definitely fabulous.
    Not a lot of room in the rear triangle though with the tire, would not want to ride wet in some areas.
    Mar 2018
    That was my exact feeling too. I also went with the 2.6 Rekon. What rims are you running?
    Chilling out
    Quote Originally Posted by Five0 View Post
    Flow Mk 3, wrapped on I9 Torch hubs.
    Aside from the infrequent crash induced damage they've been bomber, very little maintenance (great local wheelbuilder at Sicker's Bikes in Clarkes Summit PA). I can build good wheels but it takes me about 4 hours to do right.
    Reputation: offrhodes42's Avatar
    WTF!!! How can you be riding a bike that old with outdated geometry? I am surprised it has not exploded on you....
    Wait...
    I am still riding my 2011 SIR 9 (though I purchased the frame new in 2016) and having a blast.
    Reputation: terrible's Avatar
    Still hanging in there with mine too. Just got back from NC and riding Dupont and Pisgah (black mountain). I still really dig this bike and have ridden several other during demos but I still see no reason to switch.
    I've been keeping my coil shock on more and more. Even with rides with more than 2500' of climbing fire roads I'd rather have the bike on a coil.
    I did just swap to 800mm bars before this trip. Was running 750mm with a 70mm stem and now the 800 bars with a 50mm stem feels more connected.
    Also swapped in the taller lower headset cup for more BB height. Didn't see any adverse affects and it maybe calmed the bars down just a bit.
    These are still great bikes. Anyone who is looking at new bikes should take a second to ride this previous model Rip and check sites having blow out sales. There are some really good deals out there. If I can find a new orange frame I may pick it up.
    That is all, terrible out.
    "I'm the fastest of the slow guys"
    Reputation: BacDoc's Avatar
    Been riding a Rip 9 RDO for last year or so, time flies when youíre having fun! Amazing ride in sketchy terrain and pedals way better and lighter than the bike weight, as I was coming off an earlier Jet 9 RDO that was under 25lbs. The Rip is probably way more bike than I need but so much fun to ride.
    My only complaint is those damn pedal strikes! Thought it was something I would figure out and eventually go away with some technical adjustments but still getting whacked. Even though it doesnít look like that in pic, the bottom bracket is low!
    Chilling out
    yeah, the bb is *just* on that cusp of too low. in NE PA I definitely favored 29x2.4 or x2.6 and never thought about it and rarely hit pedal, but with 27x2.8 I did noticeably more.
    in NC, CO, UT, no real issues with pedal strike though with either wheelset. Just different per region I guess. {shrug}
    Quote Originally Posted by BacDoc View Post
    Look into the taller lower headset cup. Just did that with mine before a ride in pisgah and it helped a lot.
    Can't complain myself either. Camo RIP rdo is a great bike!!! Singletrack, bike park, it does it all pretty well.
    Curious how you've installed the lower CVA link, dry, loctite on threads only, greased the bolts/bearing surfaces etc? I am trying to silence a creak, turbine cinch interface/chairing mount always seems to creak, XT cassette pins seem to creak, threaded bb should be fine, checked crank and crank arm bolts, anything else obvious you've found creaking? Or any setup you do specifically?
    Found the creak. My i9 freehub is worn enough that the cassette rings creak under hard load. I lightly greased and now things are stealth.
  1. Anyone still rippin' on a 26" Intense?
    By Hobine in forum Intense
    Last Post: 02-22-2016, 05:17 PM
  2. amir kabbani rippin hard
    By akiracornell in forum All Mountain
    Last Post: 04-03-2012, 05:19 PM
  3. Video of KHS crew rippin the Rampage site
    By A-NON-A in forum Downhill - Freeride
    Last Post: 02-11-2012, 10:17 PM
  4. 29er SS Rigid Rippin' up Bear Creek and Pinhoti 1,2 Video edits
    By DavidNeiles in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 01-02-2012, 09:09 PM
  5. Castle Rock Rippin'
    By NastyNick in forum Oregon
    Last Post: 12-25-2011, 04:04 AM
