Niner One 9 crank question- Mtbr.com
Results 1 to 2 of 2
    Reputation: 9-18 Fast's Avatar
    I have a 2016 One 9 that I run with a Bio-Centric II BB. I have been running a set of 175mm cranks and now I'm wanting to switch to a set of 170mm cranks.
    With this switch I would like to move to a Sram XX1 bb30 crank for the stiffness. The problem is when I add the threaded bb30 (Wheel MFG) bottom bracket into the Bio-Centric BB, the spindle is to short because of the added stack. (I do have the longer 106mm Spindle)
    Any suggestions?
    I thought about maybe going to a set of Rotor hawk cranks but unsure if I would get the same problem. (Race Face is not an option because i'm not going to put up with the creaking.)
    www.29er918.blogspot.com
    Avoid the Clap, signed……Jimmy Dugan
    Reputation: RacerLex's Avatar
    Can you exchange it for a XX1 GXP crankset?
  1. Replies: 3
    Last Post: 11-29-2016, 05:35 PM
  2. Niner One 9 headset question
    By kendrab in forum 29er Bikes
    Last Post: 01-10-2012, 12:28 PM
  3. Salsa El Mariachi vs. Niner SIR-9 vs. Niner One-9
    By crestlinefarm in forum 29er Bikes
    Last Post: 11-21-2011, 10:17 PM
  4. Race Evolve XC Crank Arm Removal w/o One-Key Crank Bolt?
    By three.ten in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-13-2008, 01:02 PM
  5. Generation One Niner One 9 rear tire clearence help
    By nickcapriotti in forum 29er Bikes
    Last Post: 01-10-2008, 08:17 PM
