New fork for 2009 RIP 9- Mtbr.com
    Sep 2004
    Hello, I am looking for a new fork for a 2009 Niner RIP 9 frame, frame is in great shape so instead of trying to sell and buy something else I am going to maybe change the fork. I am looking at Maybe a Pike 130 or 140mm or a Yari 130 140mm. Cost is also a factor here so leaning maybe toward the Yari. I am an older rider so no big drops but for central Pa. trails, not going boost as my wheels are for 100 mm thru axle, also I just like to get the air pressure close and not mess with the shocks after that. I am also not sure which offset to be looking at 51 or 46. I'd like any input I can get, thanks.
    Chilling out
    Reputation: bear's Avatar
    Personally, I'd go with the Pike as the Charger damper in that is much better than the Yari's Motion Control damper, and the Pike is lighter - if that kind of thing attracts you.
    I had a Pike on my 2012 Yeti and it never let me down, and it's currently on my backup hard-tail. Even lighter it'd be more than durable enough.
    Reputation: terrible's Avatar
    If you don't run tires over 2.3" a non boost dvo diamond can be found pretty cheap. Very nice forks.
    Sep 2004
    I thought I should add that I have Marzocchi 44 Ti fork on the bike right now, set at 140 mm. At one time I used a 120 mm Fox Float but switched to the Marzocchi for more travel which worked well but from what I have read the newer forks are a step up in performance.
  1. New Rip 9 Alloy vs Rip 9 RDO
    By Highlander944 in forum Niner Bikes
    Last Post: 09-16-2014, 10:10 PM
  2. Rip 9 vs Rip 9 RDO
    By Menachem in forum 29er Bikes
    Last Post: 07-12-2014, 07:46 AM
  3. Upgraded alloy RIP 9 alloy to RIP 9 RDO - awesome!
    By albertdc in forum Niner Bikes
    Last Post: 07-19-2013, 10:45 PM
  4. RIP + Talas 34/140 w/CTD = a much better RIP
    By LeftyMax in forum Niner Bikes
    Last Post: 10-04-2012, 06:21 AM
  5. Difference between '11 RIP & '12 RIP?
    By megalops in forum Niner Bikes
    Last Post: 11-08-2011, 06:28 PM
