Loose Rocker '14 JRDO- Mtbr.com
    Reputation: pedaler845's Avatar
    Howdy Ninerds
    I just replaced the first eyelet bushings on this and still have a slight clunk when lifting the bike from the seatpost.... Twisting the rear wheel and one end of the bars I can see the left rear lower rocker bolt has some movement behind it, yet the bolt is tight.
    When I inspected the bearing (in the bike) everything seemed fine. The bolts seemed fine.
    I guess this indicates a bad bearing or ???
    P4300154a by pedaler845, on Flickr
    I couldnt find shit for info on their site, or I wouldnt be asking here.
    I'd like to find the bearings to order, and which if any of the bolts are reverse thread. Thanks.
    trail "cleaner"
    Quote Originally Posted by pedaler845 View Post
    The bearings are Enduro Max and can be found here...
    Niner Bikes Bearing Kits from RWC
    On the JET RDO's, there are no reverse threads for the pivots. Good luck with the rebuild.
    Sweet! Thanks a ton!!
  1. Cassette is loose ( its loose with itself)
    By rkrider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-29-2014, 10:45 PM
  2. Rocker arms for Giant NRS
    By lslance in forum Giant
    Last Post: 11-09-2012, 08:17 AM
  3. Just a bike pic. "Spot Rocker"
    By dstrong in forum Singlespeed
    Last Post: 08-14-2011, 11:31 PM
  4. 6 Pack Rocker Availability?
    By Dougal in forum Turner
    Last Post: 01-08-2011, 03:24 PM
