Eagle on Jet 9 Carbon - 2016. which crankset?- Mtbr.com
Results 1 to 5 of 5
    Feb 2013
    Hello
    decided to move to Eagle GX on my Jet 9 Carbon 2016. BB shall be PF 30 with 73mm length. Big doubt on which is the proper crankset to avoid chainline issues....
    What do you suggest?
    Most of the crankset I see online are for boost but since this frame is not boost I think those doesn't fit....or they fit but I'll have issues with the chain line...
    I'd like to limit bor budget reason to GX and not move to X or X0 versions.
    Paolo
    Reputation: Th3Bill's Avatar
    Jan 2016
    Should be able to buy a crank separately from the chainring and then just get a non-boosted chainring.
    Sent from my SM-G975U using Tapatalk
    I'm not overly fast, not slow, kinda halfast
    Jan 2016
    https://www.chainreactioncycles.com/.../rp-prod180923
    Yes, says 11sp...but at this price point, you're getting a really good set of arms that work with the 30mm axle. Their bottom bracket is like 45 I think and you can get a non-boost chainring for likely under 50.
    If you're insistent on using a sram crank, go for DUB, as that's their new standard and will be what they're developing for going forward.
    Reputation: In2falling's Avatar
    Jan 2005
    Quote Originally Posted by bertello80 View Post
    Hello
    Paolo
    You don't need new cranks and probably do not even need a new chain ring. 11 speed chain ring should work fine with a new 12 speed chain as long as your current 11 speed chain ring is in good shape.
    A 3mm offset chain ring is for Boost spacing and a 6mm is standard (142), non-Boost spacing.
    For a new chain ring, this should work fine on your existing Sram cranks.
    https://www.jensonusa.com/SRAM-Eagle...rged-Chainring
    Feb 2013
    Hello
    actually I've an old 2 * 10 Sram X9 crankset, therefore I'd like to move to a GX native 1 * 12
    Ciao
    paolo
  1. Replies: 1
    Last Post: 01-02-2017, 08:15 AM
  2. Jet 9 RDO or Jet 9 Carbon
    By Bailey44 in forum Niner Bikes
    Last Post: 04-22-2014, 12:46 PM
  3. Replies: 4
    Last Post: 07-04-2013, 07:02 AM
  4. 12 Jet 9 RDO vs 13 Jet 9 Carbon - buying advice!
    By Juliecoleman in forum Niner Bikes
    Last Post: 06-07-2013, 02:16 PM
  5. Help Sourcing Titanium Bolts for Jet 9 RDO V.1 (Jet 9 Carbon)
    By Dry Cownty Brewer in forum Niner Bikes
    Last Post: 02-13-2013, 08:17 AM
