Anybody route an internal dropper on their jet9 RDO?- Mtbr.com
Results 1 to 10 of 10
    Not the fake Jay Leno
    Reputation: Chinman's Avatar
    Dec 2014
    Currently I have the stock KS Dropzone 125 externally routed dropper on my 2017 Jet9 RDO. Iím looking to get a longer dropper and Iím thinking about going internal routing. The newer Jet9s have easier cable routing, which the 2017 frames didnít have. Has anybody done this upgrade? Iíve taken the plastic covers off the bottom of the frame. I think it should be doable. Looking for any tips or advice if youíve done this. TIA!
    Start at the seat tube, the only tricky part is the bend around the bb, it's a little tight there but once you get it around that because getting up the down tube is pretty easy.
    Sent from my LEX727 using Tapatalk
    Chilling out
    Reputation: bear's Avatar
    FWIW, I split the difference on my RIP9.
    I switched to a 150mm KS LEV DX, which has the external/fixed cable mount point, and routed the cable down behind the seat tube through the upper link to the same port the rear-d cable comes out, and internal from there to the head of the bike.
    Easy peasy setup and maintenance and only housing exposed is adjacent to rear-d housing jump to the rear triangle.
    I just didn't want to fuss with getting housing past the BB and liked the easy attach/detach of the KS LEV DX cable port.
    Dec 2014
    Thanks guys! I bought a OneUp (internally routed) and Iím going to give that a go.
    Reputation: Tri Geminy's Avatar
    Jun 2016
    I have internally routed my One Up dropper post on my 2017 Jet9. It's not easy but doable.
    This must be why the mechanics at my shop say Niners are pia to work on
    Dec 2014
    HG
    Quote Originally Posted by Tri Geminy View Post
    I just installed my OneUp last nite. I got er done, but it was a curse fest. I canít say that I would recommend this task for anyone but the overly determined. I fished the cable down the seat tube and under the BB to the opening on the bottom of the down tube. I then ran a spare cable from the grommet opening at the top of the down tube down to the opening at the bottom. I joined the two pieces of cable with a small screw that I had cut the head off of. I was then able to pull the new cable up thru the down tube and thru the grommet opening.
    After getting everything installed, Iím not real crazy about the actuation at the lever. The post works fine, but lever actuation feels weird. The OneUp dropper actually needs the cable to be able to move a few mm in the frame. The cable is so tight in the frame, that I Think it is not allowing smooth throw. OneUp actually came out with a v 2.1 actuator for certain Santa Cruz bikes where there are tight spaces in the frame. I think I might give that other actuator a try as I think these Niner frames have the same issue. Thereís some more info in this forum:
    https://forums.mtbr.com/components/oneup-dropper-v2-1101344.html
    Jun 2016
    What I found was that you can't push the OneUp dropper post all the way down. It will activate the lever. It needs a few mm of clearance from the frame. Not sure if that is what you are experiencing.
    I didn't have the same problem with my PNW dropper post.
    Dec 2014
    I have a couple of inches of the post extended from the seat tube, so Iím not having this issue. I went for a couple of rides this weekend and the post worked fine. The lever actuation does not feel as smooth as my other KS posts, but it works just fine. The extra 25 mm of drop is very nice!
    Reputation: antonio's Avatar
    Jan 2005
    I just did the same on a 2017 frame. Seemed not too difficult.
    1) Remove bashguard on bottom of down tube to expose opening into frame.
    2) Run housing down the down tube. Pull housing out of frame opening a good distance (12 to 18 inches or so). Don't try to run housing straight through downtube, over bottom bracket, directly into seat tube. The direct angle makes it a challenge to get it up the seat tube.
    3) Run housing that is sticking out of down tube openng a good 12 - 18 inches or so before routing it back into the frame, over the bottom bracket, and fishing it up the seat tube.
    4) Adjust the housing back and forth from both ends to get the right length to the dropper and to the lever. Cut and feed the cable.
  1. Replies: 2
    Last Post: 02-28-2017, 07:28 AM
  2. Replies: 31
    Last Post: 04-29-2013, 07:32 AM
  3. Niner Air9 RDO (small) and Jet9 RDO (large) 30% off
    By EskimoFriend in forum Where are the Best Deals?
    Last Post: 01-23-2013, 03:03 PM
  4. Replies: 3
    Last Post: 09-03-2012, 10:17 AM
  5. Replies: 0
    Last Post: 03-01-2012, 09:26 AM
Members who have read this thread: 8
