27+ Configuration Niner Headset - ZS Lower Cup- Mtbr.com
Results 1 to 3 of 3
    Oct 2012
    Can someone tell me if these replace the lower headset cups that press into the frame to correct the geometry from 29" to 27+ wheels?
    15mm stack lower cup for Niner ZS headsets - corrects geometry when using 27.5" Plus wheels
    Thanks in advance.
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    I'd be interested in knowing also.
    If you have to knock the old lower cup out and press a 15mm one in that is not something you want to do more than once or twice so would it not be a good solution if you want to be swapping between 29 and 27.5+ wheels with any regularity.
    Reputation: Rocket88R's Avatar
    Jan 2013
    I put a Works Components -1 degree Angle headset on my 2013 RIP 9 when I converted to 27.5 plus. I wanted a slack HA. I now have a set of 29" wheels and I swap between the two wheel sets with the same headset. No issues, it rides fine.
    _______________
    Schwinn: 1999 46 Banger-21"
    Banshee: 2015 Phantom-L
    Guerrilla Gravity: 2018 Shred Dogg-M
  1. Replies: 0
    Last Post: 10-30-2014, 08:06 AM
  2. Headset Q : using FSA upper cup and Cane Creek lower?
    By guim in forum Downhill - Freeride
    Last Post: 06-27-2012, 11:19 PM
  3. Need a lower headset cup for a tapered fork
    By epoch2k in forum 29er Components
    Last Post: 04-15-2012, 06:55 PM
  4. Hope Headset - Lower cup question
    By OldHouseMan in forum 29er Components
    Last Post: 01-29-2012, 11:29 PM
  5. Fix For Loose Lower Headset Cup
    By JJY in forum Frame Building
    Last Post: 09-26-2011, 11:09 AM
