2010 Niner Jet 9 - help needed...- Mtbr.com
Results 1 to 2 of 2
    When coronavirus hit I thought it would be a good idea to completely take apart my bike, clean it, and look at replacing some parts. What started out as replacing my pivot bearings went from pivot bearings to replacing my shock, to replacing my fork, to replacing my wheels. Now, I think I’m going to also try and replace my drivetrain. My frame is a 2010 Niner Jet 9. I really like my frame, and don’t want to replace that.
    I would like to go to a 1x12 setup, but I have questions... Shifter, chain, and cassette (10-50) seem easy enough. The derailleur seems easy as well, there appears to only be one size and I’m assuming that will work. Where I need help with is the crankset. With DUB, is there now just one crankset option and “it just works” with whatever BB shell size you have, provided you have the right bottom bracket? In my case that would be BSA correct? What about Boost, does that even matter? Would a Boost crankset work?
    Anyone out there running 1x12 or a similar setup on a 2010 Niner Jet 9?
    Oct 2007
    DUB was designed to be a universal crankset, so you just have to get the correct DUB BB for your frame and you can use a DUB crankset. There is no difference between a boost crankset and non-boost. BUT, the chainring has a different offset for a wider chainline. So if you buy a boost crankset, you will have to replace the chainring with a non-boost one, or you will have some serious cross chaining when in the 50T cog.
    2020 Canyon Neuron 9.0 LTD
    2015 KHS Sixfifty Team
    2019 Salsa Warbird
    2019 Canyon Endurace
    1987 Haro RS1
  1. Replies: 23
    Last Post: 11-08-2014, 10:33 AM
  2. Replies: 0
    Last Post: 03-29-2012, 12:39 PM
  3. specialized epic 29 VS 2010 Niner Jet 9
    By leonidas 119 in forum 29er Bikes
    Last Post: 08-23-2011, 08:27 PM
  4. My first custom build-2010 Niner Jet 9
    By Radical Rad in forum 29er Bikes
    Last Post: 03-26-2011, 01:31 AM
Members who have read this thread: 8
