18 Jet 9 RDO - 44mm or 51mm offset?- Mtbr.com
Results 1 to 2 of 2
    Reputation: OttaCee's Avatar
    Jul 2013
    Building up a Jet 9 RDO frame. Question on crown offset.
    Finding 44mm offset forks in 130mm is almost impossible. Interesting that Fox supplies 44mm forks to Niner but Fox does not mass produce them for purchase.
    But there's plenty of 51mm offset forks by Fox.
    Can I use a 51mm offset for a Jet 9 RDO?
    Reputation: In2falling's Avatar
    Jan 2005
    Quote Originally Posted by OttaCee View Post
    See that Niner is putting 44mm offsets on the 2018 bikes and 2017 (same frame/geo) had 51mm.
    I would think that 44mm offset would not work so well with shorter reach and steeper HA, 44mm offsets are mainly being used on "new geometry" (long reach and slacker head angles). I would stick with 51mm, 44mm will probably make the front wheel feel like it is tucked in under frame more and make going down steep stuff sketchy.
  1. 2016 Fox FIT4 51mm to 44mm conversion possible ?
    By kermit_xc in forum Shocks and Suspension
    Last Post: 09-03-2018, 02:16 PM
  2. jet 9 rdo works angled headset?? 2014 jet 9 rdo
    By Juan Flores in forum 29er Bikes
    Last Post: 05-04-2015, 10:18 PM
  3. Jet 9 RDO 2012 - Worth upgrading to latest Jet 9 RDO?
    By Kuttermax in forum Niner Bikes
    Last Post: 03-31-2015, 09:32 AM
  4. Jet 9 RDO with Fox 120mm Float with 51mm offset
    By shreddr in forum Niner Bikes
    Last Post: 01-25-2015, 03:06 PM
  5. Replies: 6
    Last Post: 02-09-2014, 02:12 PM
