Nicolai/Mojo GeoMetron build/riding/Development Thread - Page 11- Mtbr.com
Page 11 of 11 FirstFirst ... 7891011
Results 1,001 to 1,027 of 1027
  1. #1001
    Jan 2018
    Quote Originally Posted by the_pilot View Post
    Iíve been so busy at work I have been quiet. Also pretty happy with my bike!
    Due to get G1 springtime along with Selva and EXT. Iím confident it will be almost exactly the same as my bike but with slightly more upright pedalling position and lower BB, which was the plan. The fork will be better than my current fork but we shall see on the shock. Iím still old skool with 2 lengths of X2
    Iím also going to flip between 27.5 and 29 front as a bit of an experiment on trails I ride.
    I didnít know Jack was leaving. I would say money probably is tight and Brexit probably not helping, but Iím not sure heís doing better than before he took on the bike which could also be a question in his mind.
    I do know they canít make enough ebikes... not my bag but everywhere I turn these days.
    Iím beginning to look at natural riding more to avoid being buzzed and the lack of etiquette. I donít know if it was always there but I didnít see it or if itís a whole new type of new rider.
    Clearly doesnít apply to all, just my recent experience.
    Hey @the_pilot any news on your G1? I see the GeoMetron guys are building & shipping at the moment so preume you were one of the early orders
    Keen to hear your thoughts on frame/shock/fork as & when you get a chance
  2. #1002
    Quote Originally Posted by bathbill View Post
    Iím not! So busy at work! Waiting for Chris to come back to me..
    Aka chainline...
  3. #1003
    Oct 2016
    Can't wait to see more G1's build up the next weeks on Instagram!
    Cornelius, Nicolai's team rider has his one built up too last week and its the first one i saw in black with black decals and looks damn good!
    In the meantime i'm looking for a new shock for racing purposes for my G15, as the Monarch Plus is good but not as good as it could be (especially for my 100kg rider weight).
    DHX2? Vivid Coil? Unfortunately the EXT Storia v3 is too expensive for me, although it would be a dream come true to have one on my bike!
  4. #1004
    Oct 2018
    Quote Originally Posted by tallguy3001 View Post
    well vivid coil is significantly cheaper yes ( I could get new 216mm one for 270euro in Slovakia), but I donīt know where you are from, if US than ok, DHX2 is cheaper there, but in europe DHX2 with SLS spring is pretty much as expensive as Storia, which is tragicomical all things considered.
  5. #1005
    Reputation: thegromit's Avatar
    I have a van rc which is the same thing as the new marz shock. Itís pretty damn good. I sent it to Craig at avalanche and would say itís probably the best feeling shock ive had. So for under 400 you can have a custom tuned damper that is actually shimmed for you. Hard to beat. Mines on a g15 but I long shocked it to 165mm rear travel matched with a 170 marz bomber.
    On another note Iíve been thinking of throwing my 650b rear wheel on after rotarua to see what I think of a hybrid set up.
    Life is like riding a bicycle. To stay balanced, one must keep moving. - Albert Einstein
  6. #1006
    Nov 2015
    I've just got a Storia V2 222x17 (175mm) for £600 from Mojo....may still have some in stock comes with 2 springs for your weight......lovely bit of kit must say
  7. #1007
  8. #1008
    Quote Originally Posted by thegromit View Post
    This is very interesting, what did you do when you changed the travel of G15 from 145mm to 165mm? Or did I misunderstood the above?
  9. #1009
    I just put a longer stroke shock on it. Stock is 8.5x2.5 if you put a 8.75x2.75 shock you get 20mm more travel. Its how it is done on the g16.
  10. #1010
    Thanks, that's what I suspected! My earlier understanding was that there's not enough room for additional rear wheel travel.
    Did you use offset bushings to compensate any changes to geometry due to different shock lenght?
  11. #1011
    Jun 2017
    What is max tire width you can put on g1? I am currently considering between geometron g1 and pole stamina. I really like versatility of g1 and available color choices but stamina has a lot of clearance in the rear, can take up 29x2.8 also has multiple bottle mounts which geometron bikes seems to be missing completely.
  12. #1012
    ^2.5" says tech sheet on Nicolai's web page:https://docs.google.com/spreadsheets...DOP9Y6/pubhtml
  13. #1013
    Quote Originally Posted by TuomasR View Post
    No I was just riding with it in the low position but I also put a 170mm fork on it.
    I did order a offset bushing to try an experiment with a 27.5 rear wheel.
    Currently I have one on with about a 63* HTA 76ish STA and a BB about 330ish.
    The offset should put me at about 63.5HTA 76.5STA and BB 338.
    Should be a pretty fun set up I think.
  14. #1014
    I have stock set up currently, with 160mm fork ,which unfortunately doesn't support longer airspring (Fox 36).
    Is my following logic more or less right assuming I mount 6 millimeters longer shock (216=>222) to my G15:
    1) the head and seat angles become 0,5-1 steeper and bb raises by let's say +5 millimeters.
    2) Two offset bushings would compensate the changes
    3) -2 degrees angle set would approximately compensate the increased bb height (I have one waiting for installation) but would of course steepen seat angle.
  15. #1015
    Oct 2018
    Is my following logic more or less right assuming I mount 6 millimeters longer shock (216=>222) to my G16:
    with leverage ratio close to 3:1 at the beginning of the stroke the BB height change would be closer to 15-18mm, 2 offset bushings should bring it down to 5-6mm and head angle at this point should be 0.25-0.5 deg steeper. 2deg Angleset will lower bb by 3-4mm, so it should be pretty close to stock.
  16. #1016
    You should be able to mount the 222 without any change just use the 222 (old low) mount on the shock lever.
    I assume you were using the 216 in that mount hole.
    The front will already be lower/steeper with 160mm fork unless of course it is set up 29 both ends. Which I guess it is based on your expected changes to stock.
    Apologies if I missed this information earlier!
    Aka chainline...
  17. #1017
    Just to clarify: I have G15 not G16, made a typo in my latest post (earlier I have mentioned G15, now corrected). Sorry for confusion.
    Did you the_pilot and ghostbiker reply assuming G16 or G15?
  18. #1018
    I replied based on G16
    Aka chainline...
  19. #1019
    If you long shock it but put it in the low position you pretty much have the same geo as if you had a short shock in the high position.
    What do you want to do? Make it lower and slacker or higher less slack.
    If you use the angleset to make it slacker you get a steeper seat tube angle, which I think is good.
    If you use the offset bushing to make it slacker you'll get a slacker seat tube angle, which I think maybe not as good.
    But you might want to use a combo of both.
    EG: Long shocked so you have like a 64.5 hta plus a offset bushing in the steep position, then the angleset in the slack position giving you like a 63 head tube angle and like 78 seat tube angle.
  20. #1020
    My primary objective is to get more travel for bike park days, without messing up the geo. I also would like to understand the changes made, and to test / play with different geos.
    Slacker hta and steeper sta are intuitively ok, lower bb is not because the bike feels low enough already. In summary more travel, bit slacker and same or bit higher bb height
    You guys are super helpful, thanks!
  21. #1021
    Aug 2016
    How are recent experiences regarding 29er front and 27er rear?
    Best case if someone did it on the G16...
    At the moment I am on full 27er and think about going 29er front. But this means a new fork.
    Or buying a full 29er bike somewhen in future is a better option?
    Donít mean the details in angles or heights. Just interested if there is really an improvement for riding when putting a 29er wheel on a 27er bike?
    Cheers
  22. #1022
    Quote Originally Posted by joey12345 View Post
    Cheers
    Iím afraid thatís hard to answer. It depends on what Ďimprovementí means to you!
    I have used mine 29 front 27.5 rear G16 for a long time now. I really like the way it reacts to inputs, both steering and overall. I like the way it carves.
    But I loved it 27.5. I liked the way the front was so reactive
    The upside of going with a 29 fork is you arenít tied. Itís the same a2c as the 180mm fox so you can drop in the 27.5 wheel anytime and use it as a 160mm/155mm bike or even a 175mm/160mm depending on your current shock.
    So itís not like you are stuck if you donít like the hybrid.
    I think itís very unlikely you wouldnít like it, just make sure you get a 29 fork with an offset between 42mm-46mm
    Aka chainline...
  23. #1023
    Aug 2016
    Thanks for your answer and your thoughts.
    Sure this is not an easy answer cause everybody likes different stuff and styles
    What kind of setup are you using at the moment?
    May itís really as you said and I should be happy with my agile 27,5er and look for some other options somewhen in future.
    A new fork and wheel is not a cheap thing
    So do you feel the efficiency of the full the scaled setup is comparable to full 29er or is it very different compared to a full 29er?
    Others:
    Whatís the downside of full 29 compared to scaled?
  24. #1024
    Aug 2014
    Demo Day at eastridge was interesting yesterday.
    Firstly the Megatower, what an underwhelming bike, CC with carbon wheels, 36 grip 2 fork. Felt like a long legged trail bike than a big travel Enduro bike. Bike was harsh and such that there was far too much feedback through the bars and pedals, couldnít push the bike. It skipped all over the place and had to fight it to keep it on line, or somewhere near!
    Now onto the geometrons. Rode a G1 27 first off before the Megatower, first trail had to adjust to how it wanted to corner, after that it just wants you to get off the brakes and throw it in. Rear tyre was dead so tricky to get it slowed down at times. Bike was a bit rattly, needed the clutch sorting on the mech and some 2224 tape on the back end. I hate noisy bikes!
    After the underwhelming Megatower, was onto the g1 27. Fresh set of boots on this one! Also went a bit softer on the rear spring and and was on the formula fork (was riding the one in the milner video). Fork took a little getting used to, been on a Lyrik since Christmas, which is more sensitive (g1 27 was on a Lyrik). Felt more comfortable the second time round on the G1, even with a wheel size change. Can really lean on the front, more notable when it gets steep, you can still drive the front end without the fear of going over the bars.
    Managed to snag a ride on a g1 27 at the end of the day when Mojo/Santa Cruz were going for a quick run round some of the trails at eastridge. Extra mileage helped to really learn the bike and the way it wanted to be ridden, good to be back on the Lyrik again. Rear tyre wasnít a problem this time as I knew Iíd need to scrub speed a little earlier.
    Rode some tight, steep switchback turns, bike had no issue turning, its super stable, yet still wants to change direction.
    When it comes to replacing the enduro at the end of the year, G1 is currently the only one on the list. Last enduro was eating bearings on a regular basis, see how the replacement goes!
  25. #1025
    In about 10 days I should have a freshly [Sprung] serviced Fox X2 for sale [222mm from my G16]. PM me if that helps. I also have a 222 Stoy which was serviced just before i bought the G16 so hasnít been used for more that 2 weeks.
    neil
  26. #1026
    Joey, hybrid is THE way, Its carves so beautifully and rolls over nicely too. You do need to wrk the front and lean the bike a bit more so thatís great if thatís your style.
  27. #1027
    Quote Originally Posted by Mebaru View Post
    Mebaru,
    have you tried a 2.8 tyre, they are very bouncy and generally with weak carcasses or they's be super heavy, no way would I run a tyre like that on the rear.
    Get a Geometron, its SO much nicer a bike (I've been on G16 since 2015 and am about to get a G1) I might put a 2.5 WT Maxxis on the back, maybe DD but I expect I'll stick with the DD 2.3 Aggressor til it gets sloppy again, then a Shorty
  1. Replies: 65
    Last Post: 09-05-2017, 03:14 PM
  2. Nicolai GPI/Geometron Ride/Info/Pics
    By the_pilot in forum Nicolai
    Last Post: 01-17-2017, 04:28 AM
  3. the futures here... Nicolai Mojo GeoMetron
    By nauc in forum All Mountain
    Last Post: 09-30-2015, 06:19 PM
  4. delete
    Last Post: 09-28-2015, 09:29 AM
  5. Mojo Nicolai, GeoMetron, Forward!!!
    By Legbacon in forum General Discussion
    Last Post: 06-26-2015, 06:51 AM
Members who have read this thread: 188
