The G1 Thread- Mtbr.com
Results 1 to 60 of 60
Thread: The G1 Thread
    Jul 2016
    The G1 Thread
    Thought I'd start a thread dedicated to the G1 for folks to share info and experiances.
    I've been off a "proper" bike for 15 months due to pretty complicated wrist injury.
    I wasn't sure if I'd be able to ride again at one stage so sold my G16 but recovery has gone better than expected.
    I've been wobbling around on my fat bike for the last few months as I've built strength and fitness back up but now its starting to get a bit "exciting" trying to ride 5" tyres hard on loose and dry trails!
    I've got a Longer G1 frame, Formula Selva R forks, Cura 4 brakes and 185mm Bike yoke dropper on order with Geometron.
    The bike is going to be built up as 160mm 29er running the new shimano 12speed drive train.
    I'm building up 30mm LB carbon rims onto 28hole XT hubs using CX rays and brass nipples. I'm trying to keep weight down to a reasonable level on this wheelset as I do quite a lot of climbing and long XC sections on my typical trail rides.
    This bike will be my only bike as I found that swapping between the G16 and a more conventional sized trail bike was a recipe for disaster in terms of body English and riding position etc.
    I'm a bit of an odd shape in that I'm relatively light and slim at 63Kg's and 179 - 180cm's but have short skinny legs and carry all my weight in my top half so forward of the saddle. I'm really interested to see how the higher stack of the G1 compares to the G16 as I tend to prefer a higher front end due to my physiology.
    I'll post updates once it all lands and I start to build it up and ride it.
    Sounds good, we are almost the same shape to I知 a touch heavier.
    I must get around to checking sizing but was thinking of porting from my lOngest G16 to a Longer G1. Tho a touch worried about the drastic ETT change even if smaller reach change.
    Aka chainline...
    Jul 2016
    In an ideal world I would have driven down to Wales to ride both the longer and Longest as I too was a little concerned about the ETT but I kept reasoning that the reach value was what counts so I've just gone with it.
    There is now a beautiful frame plus an array of boxes of goodies sat in my workshop. Just waiting on the rims now. It took me a few minutes to work out where the port for the dropper cable was hidden, the frame is like a work of art!
    Yeah, I told Chris I壇 go with Longer this time. I値l run a 35mm stem and put the bars back to std roll. Which will give me the same effective bb to bar reach which is my important measurement!
    Aka chainline...
    Reputation: polarflux's Avatar
    Can I just pipe in here? I think the G1 may be the pinnacle in the new school geo revolution not to mention the multitude of ways it can be configured makes the G1 one the most interesting bike of the year, IMHO. Only 4 comments in this thread, and not a single major magazine review of the G1 either. Are we going into recession?
    Mar 2012
    Just ridden my G1 xl for a week now. Started with 29/29er and built up fir curiosity, a 27.5 rear wheel to try the hybrid concept.
    First ride was really disappointing and actually ended with a crash, cause of the wet roots and rocks and me not used to the bike at all.
    Had to go from a 33 to a 40 Renthal Apex stem and go to a more narrow bar at 780mm to force myself going more forward. Also rides with the Ergon flanged grips tilted so much forward that I cannot stay other then over the front wheel.
    So after a few rides now, it starts to get more and more natural feeling. I need to remind me all the time about going more forward, but the bike is getting better and better.
    The hybrid set up, was better than I thought too. The 27.5 wheel that I was afraid should hook up is not a concern, and it makes the bike turn more easy to handle in turns.
    I have built up the bike with 200mm OneUp seatpost, 1x11 Sram XX1 with Race Face Next R and 28t chain ring. It climbs really well, but of course it is not a sprinter. Btw the 27.5 with same rubber as the 29er, Maxxis DHF is way more grippy, and brakes much better.
    Uses a Fox 36 Kashima set at 174mm travel, with smash pot coil on it.
    Quote Originally Posted by Pigglet13 View Post
    Reputation: honourablegeorge's Avatar
    I'm trying hard not to order. I've got a G16 (and G13 ) in the shed, and even though the G16 is second hand and has a good few years on it, it's still basically as new. Hard to justify changing when the bikes are so durable and high quality.
    That said - the heart wants, etc. I sort of have the money squirrelled away for a frame and fork.
    Is the G1 using Metric shock or Imperial? If Imperial; 8.5x2.5 or 8.75x2.75?
    The G1 uses a 230x65 metric shock.
    Dec 2017
    Thoughts on 5'11" (180cm) person on a Long (small) G1 in 29er configuration?
    Would it be too small?
    My sweet spot for reach is about 470-480mm, based on the bikes I've demo'd in the past 6 months and felt comfortable on. (Transition Sentinel, Whyte G-170, Bird Aeris).
    I owned a Longest G13 in the past but it was simply too long on some of the tighter trails. Totally fine on the steeper, wider stuff.
    HI NG13,
    I am 181.5cm and went with a Longer G1 (medium). I wouldn't want it any shorter in the reach.
    I have had 2 bikes the same as the longest to, about 515mm reach and I did okay on them but wasn't 100 percent happy. However I did ride a mates X longest at 535 reach on a particular track and I had fun to. But I know for use over varying terrain it would be unwieldy. I digress, coming back one size from the longest (515) has brought the bike back to me and I can utilize it more to my liking.
    The Longer reach seems pretty sweet. I get good manoeuvrability and still have speed stability. And you can mutator to, so when I go to higher speed bike park stuff I use a longer rear end. The G1 is so good, tune it to your ride.
    A longer with a 30mm stem would do you well I think.
    Cheers
    I知 ~175cm on a G16 MOJO 29er Longer w/35mm stem. What that means to you; likely nothing but I feel apart of this conversation now.
    Hey Punky, You were always apart of it, you are a mojo bro, can't get any better than that.
    Here is a pic of my mate and his Extra Longest G16 and me crouched down by my G1
    Both sensational bikes
    Dec 2017
    Quote Originally Posted by WilliamK View Post
    HI NG13,
    Cheers
    Thanks, I appreciate the reply. Food for thought!
    Quote Originally Posted by NG13 View Post
    I agree, longest to long is a huge change. At your height Longwr would be the go to recommendation but if aggressive or very dh focussed Longest is good but not for everyone.
    I have Longest and very happy, I知 178cm but am going to go Longer this time as my riding is more all round than totally descent focussed these days.
    I set up the Longest to have same key dimensions and effective reach as my previous Longer using stem/bar/crank adjustments so it feels familiar but is just physically a tad longer in wb with the stability that brings but also the extra commitment and effort which can be more tiring on a long day (and I知 getting older)
    So on balance I think a Longer would work well and you could adjust it + or - 20-30 mm with stem and bar position if necessary.
    Aka chainline...
    Jul 2016
    My rims finally arrived, typically on a Thursday so by the time I got the rims measured and spokes ordered it was another weekend gone. Anyhoo, got the wheels build up on Friday night, finished the bike on Saturday so got out for preliminary set up on Sunday.
    If you've not seen one of these in the metal then they really are a work of art. Everyone who sees it comments on the quality of the frame.
    Anyway, initial thoughts...
    The back end is in another league compared to my G16. I'm not comparing apples to apples as the G16 was running 27.5 hoops whereas the G1 is running a 29" rear at the minute but I always felt my G16 with X2 was a over damped for me. Not so with the Storia. It's plusher than a super plush plush thing, really composed and yet still supportive and not wallowy.
    Believe the hype kids, it's the badgers nadgers!
    I have been making use of the climb switch which isn't a full lock out but firms up the shock significantly for longer, smoother climbs. I'm currently running an oval chain ring because on my hard tail and shorter travel bikes I found they offered a noticeable advantage on technical climbs but on the G1 it feels as though it may be fighting the suspension and initial thoughts are that a regular ring with the shock open may work better on rocky, rooty and technical climbs. Tonight I switched out the spring I was running on Sunday for the 5KG heavier spring and initial thoguhts are that it has resulted in a better balance between the front and rear of the bike from a suspension perspective.
    On to the front end: The Selva R seems a really nice fork straight out the box. For a set up nerd like myself the CTS system is a great feature as is the dual air system. I'm just waiting for a socket to be able to open up the air shaft to try removing a Neopos as I'm not getting full travel out of it at the moment.
    I'm still sussing out bike fit, mainly bar height and roll and reach adjustment. On my first ride the cockpit felt too short so I was fighting the bike a bit going into turns and nose diving landings but rolling the bars almost 90 degrees forward made a huge difference when I went out tonight. I didn't ride the same trails tonight as I rode on Sunday so will go back to compare performance with the revised bar position hopefully tomorrow.
    The Formula brakes are great, really powerful yet with great modulation. I was a bit concerned as the lack of lever adjustability compared to my trusty Hopes but there's plenty of reach adjustment and initial thoughts are they are a solid option.
    Jul 2016
    Been out out again on the local DH track this morning which is a great testing ground as there are a lot of features in a short run and at the moment its hard as hell and dusty so if your weight distribution isn't spot on then you will lose either the front or the back.
    My first ride on Sunday left me with the feeling that there was a front to rear suspension imbalance and that the bike was too small. I was struggling with front end grip and the back was bucking/nosediveing up over jumps which in the past I've found has been caused by my hands being too low and too close to my hips.
    I was also struggling a bit with getting the bike to turn in properly.
    After a chat with the guys at Geometron they suggested rolling the bars forward and lowering them.
    I've never run bars in anything other than a standard roll position before so this looked weird when first adjusted. I've rolled the bars from a "normal" position to around 60 to 70 degrees forward. This has resulted in the bars rise now moving the bars forward and the rear sweep contributing to the rise.
    It looks weird and feels a bit strange but what it's done has moved my hands 55mm forward from the standard position.
    I've measured this by clamping a string at the centre of the grip ends and then measuring the distance from the string to the centre of the steerer and the top of the head tube.
    Initially I was running 35mm stem, 40mm riser bars set up pretty flat/zero roll with 30mm of spacers under the stem. That resulted in my hands being pretty much central/level with the steerer in terms of forward axis and 108mm above the top of the head tube. (I deducted half the grip diameter from my measurements to give a measurement to the centre of the bars/grips)
    With bars rolled forward I've ended with my hands 55mm forward of the steerer and about 110mm above top of the head tube. My hands are now sitting in front of the stem which seems a little weird but hey ho!
    With this set up I feel I have noticeably more room to move on the bike, turn in and grip has improved dramatically and the bike now feels natural and balanced in the air.
    If you'd tried to convince me that it would have made such a difference before trying it I would have called BS!
    I did try removing some stem spacers but this instantly flet worse in terms of turn in and flight attitude. so went back to 20mm with the exaggerated bar roll.
    In terms of fork performance, the Selva has around 20mm of stantion still showing at bottom out so I was actually getting more travel out of the fork than I initially thought.
    Now I've got bike fit sorted I'm going out tonight to start pushing the bike harder to fine tune suspension as I have a 2 day enduro race in 10 days, my first post accident so keen to get as comfortable with the bike as possible before the red mist descends on race day!
    Jul 2016
    A few more pics
    Please don't judge me on the state of my garage, my mother has dumped a load of stuff I have had stored at hers with us and it's become a bit of a tip this last week!
    Made some build progress this week, waiting on a bb tool to finish.
    Still need to figure out the chain length. I'm used to air shocks where you can bleed all the air out to compress suspension for chain length. Not sure what to do with the coil spring.
    Jul 2016
    Looks good!
    I went out last night and got a few hours out on the DH track and local trails and the bike is feeling better all the time.
    Without doubt the back end of this bike is the best suspension platform I've run on a trail/enduro bike. The faster I go into rocks and step downs the better it's feeling. It just begs you to push harder. It's so well damped and responsive.
    My G16 with X2 didn't feel quite as refined as my Switchblade or SB6, but the G1 with Storia is next level.
    Now I'm going faster and hitting stuff harder I need to up the pressure in the fork and possibly put the Neopos back in.
    Annoyingly my shock pump hose blew out while adjusting a mates rear shock on the first run so I couldn't tweek my forks.
    Based on last nights ride I'm now pretty convinced I've ordered the wrong size and should have gone large/longest. The bike is infinitely more balanced with the bars rolled right forwards and the attitude in flight is now pretty neutral but I'm still feeling a bit too far over the front wheel on really steep terrain.
    On the subject of chain length, I made a cock up due to rushing to get the bike finished.
    Earlier in the thread I said that it felt like the oval chain ring was fighting the suspension when climbing. That was due to me cutting the chain too short.
    I wrapped it round the big ring and front ring as normal and just added 4 links.
    The new shimano XT 12 speed derailler has noticeably bigger jockey wheels than the 11 speed range so coupled with the longer travel it was pulling a bit tight in 1st and 2nd gear.
    After my first ride I put a new chain on with 6 extra links and it's fine.
    Super smooth shifts and no pedal feedback when climbing in 1st and 2nd.
    With the chain fitted correctly through the derailler the cage is just off it's stop in 12th gear ie there is just a little bit of tension on it with the chain on the smallest sprocket on the cassette.
    I'm running XT 12 speed with a hope upper chain guide and the clutch on the mech disengaged and it's super smooth, completely quiet with no chain slap or noise.
    It's the quietest chain set I've run on a mountain bike.
    The XT hubs are an absolute bargain at 」150 for the pair as well. The only negative is that the rear hub is almost silent so doesn't give hedge creepers lurking round a blind bend any advance warning of your approach!
    Loving the G1s
    Time to add some more G1 love. What great bikes, I like the purple anno above and the black one is looking mean. Nice bikes guys.
    Here are some more pictures of my G1 jigger. I saw on GMs insta or fb page they were checking about the eeWings. I have bashed these for ages, tick, all good. Love them.
    And reaching the Top of the World with my mate and his G16
    And we also meet a brother, brother Nic
    The G1 is a great bike, perfect in Whistler. And we went to Squamish and pedalled up for some classic trails, loam and sneaky tech runs. Mullet is king of the tech
    If you love adventure, the G1 is the gun.
    Tell us more about the Mojo conversion on your 36.
    on a routine expedition
    Reputation: Marshall Willanholly's Avatar
    Quote Originally Posted by honourablegeorge View Post
    Yes please!
    Well Mojo sell the kit and I think they sell the complete set up. In my case, this is an early pre-etched version. I was desperate and had a trip to Whislter coming up, and the guys at Mojo and GeoM are just fantastic and so supportive. They made me an early kit. I had to supply the lowers.
    I had a friend who wanted the rest of the Fox fork, so I bought a new one, kept the lowers and inserted the 1 metre stanchions in. Holy heck they are long.
    Set up they are very supple off the top and are magical to me. Soft off the top, good mid support for steeps and pop and a controlled bottom out. Which I used once I sorted the right air pressure for me.
    A lot of people have ridden DH bikes with triple crowns, but to restate the obvious. These are amazing. Big G outs, big high speed compressions all are laughed at. There's a couple of local compressions I ride regularly and when I rode it with my G1 I was amazed to discover how much my trail bike flexs in the fork.
    Riding down some tigher flow and ripping turns, I had to adjust. The first 3 turns I rode into the bush on the inside of the exit. I thought the first one I was asleep and needed to get up to speed, but repeating it had me questioning what is going on. The fact is, the bike is more direct and normal steering input was too much steering. It is so direct, you will need to adjust. And once you do, it is a strength and you start to capitalise on this ability. I found riding steep black tech stuff that you can change line far more easily. And in fact, I tended to look for that option as it was so controlled. These forks lift your level of command.
    It is another level of playing field for the front in terms of stiffness. As I said, I rode some hairy tech with tricky tight turns between trees that are 780mm apart when my bars are 800mm and I can negotiate these turns fine. I mention this as the steering lock is limited by the frame buffers on the stanchions. I was initially worried about this but it didn't limit me from going past my limit.
    Super tough forks, these are performance forks. Oh, the offset is great however I already run short offset forks, so I was accustom to this aspect.
    I hope that helps. Again, amazing guys at GeoM and Mojo, so helpful and so into riding and sharing the experience. Their service is second to none.
    Here is the fork assembled on the work bench before fitting to the bike.
    As you can see, these were pulled out early in the manufacture and missed out on the etching phase. This doesn't worry me, I just want to use them.
    Mar 2012
    Also want the Morc 36 kit on my G1. Also having second thoughts about the limitation in turns with dc fork.
    So you are saying that it is not limiting your turn radius in tight corners?
    Hi Rumblefish,
    Yes that is correct, I though it might, but it didn't. I got around some steep tight and narrow stuff that would be hard to get anything around.
    But, that could be a ride approach on my behalf. If you drive it around a corner like a bus, then you will feel the lock stop touch your frame.
    There are so many factors to getting around, lock is one, but lean angle, approach, any room to skid, stop and hop the back around are all in there as well as more.
    I was pleasantly surprised and after the first couple of good attempts, it didn't stop me from having a crack at anything. Didn't hold me back. But I know its there, so that might worry some people, knowing it could can put people off.
    Maybe it depends on mindset and riding style.
    For its strengths though, it is well worth it.
    Not sure I helped....
    Hi,
    Did you measure the weight of this bad boy? And what is the travel and a-c length?
    Sunshine & Slippery Trail
    Reputation: andyb721's Avatar
    Wow. There are some beauties in here! And that MORC36, I really hope to try that.
    I thought it fitting to share my new G1 with everyone. There's a story on the build on NSMB and if anyone has questions pop them in here, or there, and I'll try and help with answers. Note, the 36 is no longer on there and I've been quite impressed with the ヨhlins RXF 36 m.2 it's good.
    Jul 2016
    Some really nice looking builds guys!
    WilliamK, The MORC 36 looks great. I built up the G16 I had with 40's and that was revelation in terms of plushness and stiffness.
    I honestly didn't find any problem with lock limitation due to the steering bumpers.
    I went single crown on my G1 and whilst the Selva's are great forks, I can't help feeling that the back end of the G1 is so good that it makes the forks feel a little outclassed on really fast and more extreme terrain. That may on part be used to me running bikes that have had more travel up front than out back.
    I still need to get the fork properly dialled as I've not been riding in the last couple of weeks but in my gut I feel a double crown fork will really open the bikes capabilities in more extreme terrain. I was trying to keep things sensible from a weight perspective on this build as it's now my only bike but even still, the lure of the MORC is calling!
    On another note, what are folks running spring and travel wise in relation to their weight and how do you find it?
    I'm around 64kg and running a 275lb spring for 31% sag in 29er flavour and 160mm travel. I have a couple of scales for checking front to rear balance and I'm running at around 62% rear, 38% front.
    I'm going to try a 300lbs spring at the weekend as I'm running quite a lot of damping at the moment and suspect a heavier spring with a little less damping may improve speed on rough natural terrain.
    At this point I should re-state I'm a tinkerer and constantly like to experiment so it's not that I'm un happy with the bike, I'm just constantly searching for an improvement (that's the reason I have about 15 almost new tyres in the garage).
    Reputation: jazzanova's Avatar
    I am seeking an advice.
    I am getting a warranty replacement frame from Santa Cruz and will.lost likely get a Tallboy 4. Since I am between sizes and am intrigued with these new forward Geo bikes like G1, I am thinking to upsize to a Large.
    Compering the TB4 Geo with other American brands bikes in the same category, TBs # are pretty standard. Reach, STA, WB # are very close.
    However, if compared to more progressive, forward Geo of some European brands (Nikolai, Pole, Mondraker...) SC is fairly conservative.
    I like steep ST, and would run the saddle all the way forward.
    Also, most likely CS in longer setting (440mm), to help balance the bike and keep more weight on the front.
    5'8" and 31" inseam
    Reach on L is 470mm.
    Good idea going with L, since this is a shorter travel 120mm bike?
    This is pretty wild to me. It looks amazing. But why run a dual crown 36 over the full 40/49 - is that purely a weight consideration? I would imagine that the offset is the same with either MORC offering... You also mentioned that you were pedaling in Squamish - is the Mojo dual crown setup your standard build for trail riding or did you swap that on just for the Whistler trip? I hate pedaling my DH bike and it's not just the back end that makes it suck - I can't imagine trying to clean tech climbs or pedal uphill for any distance with that (Avy tuned) RS Boxxer RC either. Do you have a single crown setup for your "normal" / no shuttle/lift access riding?
    Hi Jazza,
    As a long time past SC owner I was excited to see the new TB4. Finally SC are back. I was thinking the new TB4 is the new blur trc - in a fashion. Fun fun and fun.
    I would not be concerned at all with the L for you. Personally at 5'11' I would go for the XL, so L would be fine for you.
    You would be so close, and the saddle can be your adjustment, 5mm forward wouldn't hurt. I have had a Pole and I like the steep SA. For me if I were to do a TB 4, I would go XL, run it long in the back, and slack it out 1 deg at the headset(steep the SA a smidge then), make sure I run a 30mm stem and as low as possible on the fork offset. It would rally hard and still pop. Perfect bike for hooning. Light and all day climbing still possible
    Just my twisted thoughts mate.
    Cheers
    Jan 2013
    For me, the G1 is not my one bike solution to everything, even though I am confident it could be. I mainly ride it as a park bike. I致e also got a Knolly Fugitive (shorter travel setup) that I enjoy riding quite a bit when I am not looking for as much bike and want something that is more playful. I have a hardtail as well, but I consider that a different animal altogether.
    I am 511.5 with a very long inseam of just a bit over 34. I weigh about 175-180lbs dry in the morning. I chose to go with the large version of Nicolai痴 G1 and received it in the spring. I built it up pretty promptly with a similar spec to the following list, but made some changes to get to where I am.
    - 29 wheels front and back - I have considered trying a mullet setup, but just haven稚 gotten there yet.
    - MRP Hazzard Shock medium tune.
    - MRP Bartlett dual crown fork @ 180mm - I might try 190, since it won't change the geometry anyway.
    - GX Dub 165mm cranks - I originallY started with 170mm cranks.
    - Default mutators, so nice and low/slack - I had ordered it with a set of shorter chain stay mutators as well, which gives a slightly higher BB and steeper HTA. I liked it in that setting, but like this more.
    - Deity Micro DM 30mm stem - I tried a 50mm stem and like this a lot better for handling
    - OneUp V2 210mm dropper post - yes I ride it mostly in the park, but I have actually pedaled this bike for laps at a local trail center and it's pretty great!
    - Eagle drivetrain w/ OneUp switch chainring to make my gearing versatile.
    - Onyx hubs laced to Spank Oozy Vibrocore 350 rims.
    - Magic Mary tires front and rear.
    Compared to my previous bike, a Pole Evolink 150, it doesn稚 seem as fast over roots and rocks which I am starting to think is a function of shock tune rather than suspension design. During my last park day (this weekend), I backed the compression damping all of the way off and that was a big improvement over having it somewhere in the middle.
    Overall, the geometry is spot on. I don稚 know how it will pedal on trails with only 165mm cranks, but it痴 excellent when pointed down.
    Mar 2012
    First of all, I do not know why you did choose a MRP Hazzard over the EXT Storia V3 custom made with negativ spring and spherical bearings?
    My suspension set up is the best ever on any bike. You will get a much more agile feel and a much better steering feel with the mullet set up. Have you tried different kind of coil springs? Mine felt a bit dead with to soft spring, and it was a lot better suspension with a 25lb/in firmer spring.
    Quote Originally Posted by syntheticreality View Post
    Jan 2013
    This picture was with a 170mm dropper, 50mm stem, and the 170mm cranks.
    In regards to your question:
    I can tell you why. I have MRP Ribbon forks on my Fugitive, my Pedalhead and my wife痴 Rune. I have a Hazzard on my Fugitive and on her Rune. I ran a Raze on my Evolink 150, my Canfield Jedi, and my Banshee Darkside. I like the brand and have been happy with their products. They池e responsive and give me prompt, direct attention when I need service or help of any sort. They will also rebuild/resize the shock for me if I ever switch bikes (which happens more than I would like to admit) at a reasonable cost. Lastly, I get a good price on them through my dealer.
    Did you change mutators for the mullet set up?
    Quote Originally Posted by Rumblefish2010 View Post
    Mar 2012
    Yes I have the 15mm mutators instead of 8.5mm on the seat stay, to maintain the correct BB height. Of course I understand your attention to MRP, and I think it is a great products. I really do think there is a great upgrade to use the EXT Storia V3 with spherical bearings. The initial plushness, mid stroke support and the bottom out feature puts the EXT on top of all coil shocks out there. If you read comments under the test in Pinkbike.com you will see riders preffering EXT over the Push shock too. Another thing, are you running the progressive coil from MRP too? Here is what Chris Porter is saying in the interview about the G1 in NSMB.com:
    "Have you done anything with other shocks and how would you work with someone who has something else they may wish to use?
    The G1 is developed to use the new EXT shock. If you use a 'normal' shock absorber you take a step backwards in terms of stiction and bushing friction. When you side load a 'normal' bushing it binds and creates a lot of friction. By going to the spherical bearings in the new shock we've taken a massive leap forward in how the bike feels and reacts when you push it to the limit. Of course, you can use any shock in there but it won't work as well!"
    Hi, I am 6'2.5" and have recently moved to X-Longest G1. A G13 is quite a different beast to a G1. One of my pals rode my pals Longest G16 and even my X-Logest G1 and loved both, he bought a used Longest G13 and is still making changes to try get it to suit him in steep corners. That 29 rear is harder to turn I guess.
    I went XL G1, Partly because the longest G1 is a bit shorter than my old G16 Longest. I do really like the additional length. I'd be very reluctant to go shorter. Pilot (on here) is about your height and on Longest I think. He was thinking of Longer a while back though, I know.
    Mar 2012
    Will highly recommend to have it set up with 27.5/29, since it get a lot easier in the corners. I was really skeptic since I always had a feel of the 27.5 wheel size hook up in roots and holes, but thanks to the awesome suspension and EXT Storia V3 it just feels almost as good. It even helps when you want to lift the front wheel.
    Quote Originally Posted by mudfish801 View Post
    I'm looking at a G1 as a replacement for a DH bike, thinking it might be a little more nimble and encourage me to use it in some pedal areas rather than my 2 races and 2 park weekends a year.
    Anyway that's irrelevant to my question which is just clarifying what I've read elsewhere -
    If I want to run a Fox 40, the best bet is to use a 27.5" version with a 27.5" wheel. In that case is it still required to reduce travel to 180mm or can it stay at 200 ?
    Pretty sure you can stuff a 29" wheel in a 27.5 fox 40, does this work with the travel reduced ?
    My preference would be to have the option to try a 40 with both a 29" and 27.5" front wheel, assuming the 29" would definitely have to be reduced to 180.
    I currently own a 2015 27.5" fox 40 which has an ATC of 586.
    Not sure I'm phrasing the question correctly, I'm obviously just trying to understand what the permutations would be using a 40, running either 29/27.5/hybrid.
    Hi Preston, pretty sure I saw one running a 200 set up with 27.5.
    The main thing though is to make sure of your offset. The shorter offset works best with the rest of the bike.
    Hi Preston
    I vote for hybrid, more manouverable. [I have 160 travel lyric with 29 wheel upfront)
    You totally have to talk to Chris or Marcel @ Mojo about this, Chris runs a 65B/40 on his G1 (mind he has a 29 wheel in his with the crown relieved). Maybe you should consider the Mojo MORC 36 with a 29 front wheel, its lovely - that痴 what Marcel runs.?
    G1 27.5, hybrid and 29 versions are same frame just with different mutators & lower headset cup
    with a 40 as its long A/C you'd likely need to reduce travel (easy) and use the "no stack' lower cup of the 29 set-up. You must ask the experts.
    29 is VERY tight in a 650B 40 - almost no mud room and you definitely can't get a mudguard in - some owners machine out the 40/650 crown to give 29er mud room.
    Neil
    Quote Originally Posted by Preston67 View Post
    The MORC 40 "corrects" the 40 offset.
    I think the front would be pretty high with a 40 set to 200
    I don't think MORC 36 is available yet.
    I put a 29*2.5 WT DHF with some wear in my 27.5 40 yesterday, it wasn't really that tight at all. Of course you have to raise it high enough for bottom out clearance. ATC was 587 after sliding the crowns up for bottom out clearance. This is only 10mm higher than a 170mm Fox 36 (29).
    This was a 2014 Fox 40 which seems to be a bit more compact than the newer ones at least according to Fox's drawings.
    Mar 2012
    Could you post a picture of how much clearance?
    Well it was tighter than I thought, but tolerable. If I ran this way I would probably go at it with a flap disc for mud, it spins freely like this.
    I know its mentioned somewhere in this thread, but is it straightforward to reduce 40 travel or does it require a new air spring ?
    I remember that in testing they actually took some material off the arch. Yes it is tight.
    Mar 2012
    Hi William K, still satisfied with your Morc36?
    I have heard that you are able to adjust travel by filling the positive or negative chamber so the fork travel sucks down? What travel are you using? What offset are you using, and what stem and stem spacers?
    Any tip about adjustment will be great!
    Sorry for all questions, but I am about to order a kit, and are so exited to hear about it.
    Hi again,
    All good, very good. A small story, after riding the fork exclusively for weeks and over a variety of terrain and up to high speed. I jumped on my Trail bike and the very first trail that I started to hit over 35km/h I noticed a vagueness. The communication went. I was searching for the feel I had become accustom to. It was so stark and so interesting to experience. The next trail was 40+ and it was very evident if not disconcerting. Until you try it, you don't realise how much control single crowns give up. And high G dippers, you will notice how single crowns flex.
    Anyway, it was back on the trail bike and I have had a few weeks off the big bike and have been riding my trail bike exclusively. Then I had a friend borrow the G1 and he was blown away by the fork. I then had my trail bike in for a service and new tyre and I jumped back on the G1. On yeah, that is so good.
    Dominate control. And attacking the harder stuff much harder. Just amazing, Chris has it so good off the top, the mid is great and then you hit something monsterous and it eats it up. Coming back to it is great, you get impressed all over again.
    I have it at 170mm. It is the least offset, 41mm I believe. And it is a standard short DH Spank stem,30 or 35mm. If you have the right size bike, go with no more than 35mm stem. The short offset deserves it. I have a riser bar to give me a little more height, otherwise I would have had to use spacers.
    It's a great fork, stiff and commanding and has a high quality feel to it and a high quality performance.
    No single crown can match it and it has a better offset than most DH forks. A win win
    It is for going hard. It loves going hard.
    What was the weight difference ?
    Is there a link to this kit ?
    What is the ATC you're running it at ?
    (You are using with 29" wheel I assume)
    Mar 2012
    Here is the link, that says it is not available. It is during a month according Mojo. https://www.mojo.co.uk/morc-36-dc-of...kit-1082-p.asp
    The extra weight added to a original Fox 36 is if I am remembering correct around 350 grams.
    It should take both 29er and 650B. I am waiting to get a kit, so sorry for the vague answers.
    Mar 2012
    Awesome to hear about the riding experience you have! I am just a bit in doubt, when you say you use your trail bike instead of your G1, since I am using my G1 as "do it all" bike :-).....anyway can bother you with some technical quesitons?
    -Do you need any special head set or is the kit fitting right into the standard ones?
    -You say you run it in 170mm, how are you adjusting travel, and is it 2 independent air chambers with their own filling valves?
    -Also how do you experience the Fit 4 damper unit compared to the Grip 2 unit?
    Hi again,
    Ray,
    If you can find a loving home for the G16, I say go for it. The frames do last really well, so they have a good long long life ahead of them - that doesn稚 all have to be with you though. The EXT is a bloody great shock, well worth the swop especially with those spherical bushings. G1 has better rear clearance too, we have sticky mud, right! I am also enjoying being able to tune in BB height.
    Enjoy what you have but don't feel bad when the grass is greener.
    My first G16 found a great home as you know, my 2nd went to Jakub and he is loving it, do both got great new lives.
    neil
    [QUOTE=NG13;14279541]Thoughts on 5'11" (180cm) person on a Long (small) G1 in 29er configuration?
    Yeah, I'd say that痴 too small
    Consider Long or even Longest, talk to Chris and marcel about your riding
    Yep, agree, I've tried 29/29 and definitely prefer 650 rear. My last 2 Geometrons have been set-up that way
    Mar 2020
    Hi, read the discussion about sizing Longer vs Longest for G1. I'm 180 with long legs. Tested Longer - the seatpost had to be quite high, bike felt short plus my hands were too low, carying to much body weight. But on a trail while standing in pedals it was a blast, felt great, much more balanced than on my current bike (Bronson. V2).
    Tested Longest too, with adjusted (447?) chainstays. The seated body position was much better, but I struggled with berms - was 'late' to turn, overall fel bit cumbersome (comparing to Longer). Struggling with the decision if to pull the trigger on Longest... Plus also new Raaw Madonna v2 came to the picture - Like the look of it too, got good reviews.. Any thoughts?
    How much have y'all fiddled with the v3 Storia settings after getting it? I have left mine as-is from Nicolai as they told me that the Storia V3's custom tune was developed for the frame, and didn't recommend additional adjustments beyond that, regardless of riding style or weight. I am 210 lbs R2R, and am using the 400 lb spring with 170 mm cranks in 162mm travel position, with a couple turns of preload.
    Any input on appropriate sag? I have adjusted a lot of shocks in the past, but getting a custom Avalanche damper for my 36 really took the wind out of my tinkering sails as all the adjustments on a stock damper (F or R) pale in comparison to a custom damper. I just want to be sure I'm getting all I can be out of this fancy work of art on the rear.
    For a fun experiment, I rode my Mullet setup with CushCore back to back today with 29er setup without CushCore (yes, I Mutated, similar tires). Weirdly, on a mostly XC track with only a couple hundred feet of elevation change throughout the 4 miles, the Mullet with CushCore was marginally faster - 20 seconds on a 25 minute lap, despite the significant difference in rotational weight. Based on my experience with this track, I anticipate the 20s gap to be a slight underrepresentation of reality. I am shocked by this as the CushCore Mullet setup is noticeably slower to accelerate. Now, I have only 4 miles on the 29er setup, but I was impressed with the way the rear moved over bumps vs. the 27.5" rear, again, surprising me that the Mullet-CushCore setup was faster. Smooth is fast though, as they say, and 16 PSI in the front with 17 PSI in the rear makes for a very smooth trail. Had 20F 21R on the other setup.
    Also, at 6' tall, I LOVE the Longest G1 - it helps me get over the front, and I feel much more in command of my bike, but don't feel at risk of going OTB. I have 170mm 36 on there with 30mm stem and 20 mm of spacers underneath, Enve high-rise bars in a conventional position. I did have to learn to retime my riding slightly (happened within 2 rides) as the rear is a little further back than it was on my Long Geometron. It is such a nice feeling to be able to weight the front appropriately without fearing OTB. Maybe it's my inferior skillset, but I don't know how others weight the front on those short bikes without risking OTB constantly. I feel lucky to have this "crutch" to be able to ride better and better weight F vs. R, without risking OTB or riding the rear tire too much and letting the front wash.
    In other news, anyone want my Long Geometron? It's up for sale, along with a number of other parts from that build. It would be best for a rider shorter than 6' tall, and since it's Mullet-friendly, or 27.5" F&R, it would be best for someone shorter than me anyway, or someone wanting a tad more playful ride.
    May 2020
    Hi G1 owners,
    I知 about to purchase my first G1 frame and would like to ask options of other G1 owners regarding the size?
    I知 58 or 172cm and can稚 decide whether to go with the long(small) or longer(medium) frames.
    Reputation: OldHouseMan's Avatar
    Quote Originally Posted by Poser79 View Post
    Hi G1 owners,
    Came here looking for a G1 thread to ask the same question. If I stand up tall, I can stretch it to 175cm or just under 5'9 with bare feet.
    I'm also wondering about the Ion G15. I think I'm more interested in this bike than the G1 due to the geometry. Will this bike continue in the line-up? Any feedback on the G15 vs the G1.
    G15 does not seem to be in production anymore, at least it is not listed in Nicolai web pages. Perhaps you should consider Saturn 14, which is a trail bike.
  1. Carbine with 650b G1 dropouts!
    By techfersure in forum Intense
    Last Post: 05-26-2012, 10:36 AM
  2. Intense G1 650B Dropouts
    By Waterat Pat in forum 27.5
    Last Post: 05-01-2012, 01:42 PM
  3. G1 142x12 Syntace dropouts in Europe
    By Danish Dynamite in forum Intense
    Last Post: 04-15-2012, 01:12 PM
  4. G1 Rig - need geometry
    By cdouble in forum Gary Fisher
    Last Post: 03-03-2012, 04:32 AM
  5. Bontrager G1 Any Good?
    By aaron_reigler in forum Wheels and Tires
    Last Post: 03-10-2011, 03:50 PM
Members who have read this thread: 83
